Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 04-02-2003, 03:57 PM   #1
pap
Profile:
Question Denman Tires
Does any member have info on this brand of tire?
Supposedly made in U.S.A. in Leavittsburg, Ohio.
Their website leaves alot to be desired.
www.denmantire.com
I would like to know if Denman is still American owned even if the tires are made in America if anyone knows how to find this out.
pap is offline   Reply With Quote
Old 04-02-2003, 06:09 PM   #2
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Small World...
That's about 45 minutes from me! I never heard of them. I know a few folks around that might know. I'll check around and see what I can find out. I suppose you could just call them on the phone and ask. I would guess that they are a US owned company, but you never know these days.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 04-02-2003, 06:30 PM   #3
pap
Profile:
Tubeless - Nylon
(Tire Measurement Data - Inflated)
Code
Size; PlyRating; Skid Depth; Tread Width; O.D.; CrossSec.; Rim; Max Infl; Max Load-Sgl.; Weight;
*THESE ARE LIGHT TRUCK TIRES APPARENTLY AND NOT RATED AS TRAILER TIRES.(SEE BELOW FOR TRAILER)
*TOR-08
*7.00-15; 8; 15/32; 6.1; 29.7; 8; 6.5X15; 60; 1800; 33;
*Apparently these are marketed under the Tornel brand name tag.
~~~~~~~~~~(DENMAN Trailer TIRES)~~~~~~~~~~
DST-08
225/75-15; 8; 11/32; 6; 28.5; 8.7; 6x15; 65; 2540; 31;
DRT-58R
225/75-15; 8; 11/32; 5.4; 28.5; 8.3; 6x15; 65; 2540; 33;
DRT-59R
225/75-15; 10; 11/32; 5.4; 28.5; 8.3; 6x15; 80; 2830; 37;
Old 04-02-2003, 11:50 PM   #4
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
Thumbs up Special tires
Pap,
I looked at the specification under ST and, it looks like either the bias or radial would do the job for a A/S.
example:
ST225/75R15 8 DRT-58R 11/32 5.4 28.5 8.3 6X15 65 2540 33
This looks to be about the size that A/S uses now on newer models.
I like the load rating. Wonder what the price is per?
Reckon I'll have to give them a call..Thanks for bring this one up, I've bookmarked it.
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 04-08-2003, 10:44 AM   #5
pap
Profile:
Denman Customer Service 1-800-334-5543.
(following info per my call 4-07-03)
Denman is now owned by a New York Investment Company.
Tires are made in Ohio, Mexico, and China.
Have been making RV Trailer tires for only the last 5-6 years.
Trailer tires made in Mexico.
*DRT-58R radial 8ply rating 2540 lb. load capacity. retails $65-$80.
*DRT-59R radial 10ply rating 2830 lb. load capacity. retails $75-$85.
*DST-08 bias 8ply rating 2540 lb. load capacity. retails $60-$75.
*All three above size 225-75-15, (prices Houston,Texas/Columbia S.C. included mounting,balance and stems. Tax not included.)
Serial number starting with (4F) made in Mexico
Serial number starting with (DY) made in Ohio
Not informed of China made serial sequence.
Old 04-09-2003, 02:25 PM   #6
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Thumbs up
PAP
Awesome job!
>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Action is online now   Reply With Quote
Old 12-21-2004, 08:22 AM   #7
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
Airstream Registry
Send a message via Yahoo to till
Well I will be using some Denman on my return trip from Georga. I was quoted $81.00 each for 225-75R15 load range D. I will report back on how the look, feel and handle. They are raidals at that too.
Tedd Ill
AIR#3788
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 12-29-2004, 06:49 PM   #8
till's Avatar
1968 26' Overlander
Lisle , Illinois
Images: 108
Airstream Registry
After 800 miles with the Denman's I have to say they are just Ducky. So far so good. When the weather clears I will get a photo of them for you. They are made in Mexico and seem to be good quality.
Tedd Ill
AIR#3788
Old 12-31-2004, 02:14 PM   #9
till's Avatar
1968 26' Overlander
Lisle , Illinois
Images: 108
Airstream Registry
Here are the pictures I promissed.
They are load range D's. The old ones were Load range C and I have had no problems in the 800 miles I have used them thus far.
ID:	9946   Click image for larger version
Tedd Ill
AIR#3788
Old 06-29-2008, 05:29 PM   #10
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
does anyone have any current reviews of these tires?
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 06-29-2008, 05:43 PM   #11
till's Avatar
1968 26' Overlander
Lisle , Illinois
Images: 108
Airstream Registry
Mine are still kicking fine. Track great and are wearing like Iron.
Tedd Ill
AIR#3788
Old 06-29-2008, 05:47 PM   #12
Moderator dude
Action's Avatar
Phoenix , Arizona
Images: 13
(6/2008) I just bought a set of 5 from Big O tire in Scottsdale AZ for my boat trailer. These are ST 215/75R 14 load range C. 4 were manufactured in various weeks of early 2008. One was made in 2006 and I am a little concerned with it. They have a pro-rated mfg warranty and are made in Mexico. At 50 PSI max they are rated for a load of 1870 #'s each and that is where they will be inflated by me to make sure I get my load handled.
Price was $87.95 each. Total taxed, mounted and balanced was $548.51
I really wanted tires with a 2000 # each load rating. To get that I would need to go to a 15" rim. The above tire is max size and load rating for a 14" rim. I have not weighed my boat and trailer and guess it is 7500 pounds total with full fuel, water and waste tanks. I am going to weigh in the next couple of days.
I will be using these in the coming months and years and will post my experience. When not in use they are covered with tire covers to keep the sun off of them.
>>>>>>>>>>>>>>>>Action
Tires Causing Sway? Pick Tires 14 12-03-2006 04:38 PM
Tires & Wheels for a '66 Overlander 66Overlander Tires 16 05-28-2004 11:20 PM
Questions about trailer tires... cactushead Tires 2 10-22-2003 05:58 PM
"We don't normally balance trailer tires....." Pick Tires 14 01-16-2003 04:45 PM
tires? trailer will sit after move goodgrey Tires 4 12-06-2002 02:10 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
