Old 08-13-2016, 06:32 PM   #29
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
Does the suggested 15% capacity rule apply equally to single and multi-axle systems? Or should multi-axle systems be even higher because of the increased shear condition?
TheCabin is offline   Reply With Quote
Old 08-13-2016, 07:13 PM   #30
1976 Argosy 26
Henderson , Kentucky
Images: 14
C rated 15" tires 3960# 2 axles
Questions - sorry, but using your 85% rule, 15% load and safety margin, for 26' trailer GVW 4000# 2 axles: 1) Does GYM ST225/75/15 load range C, max weight 2150#, 50#psi work 2) Does ST205/75/15 load range C, max weight 1820#, 50#psi work, and 3) if no for either why, and 4) Opinion for minimum psi cold for each. Thanks.
Ky76Argosy is offline   Reply With Quote
Old 08-13-2016, 08:48 PM   #31
Ravenna , Ohio
HERE is the link on how to calculate individual tire loads.
Tireman9 is offline   Reply With Quote
Old 08-13-2016, 08:53 PM   #32
Ravenna , Ohio
The Interply Shear forces are higher on multi-axle trailers than on single axle trailers.
BUT having a 15% capacity reserve is good practice for any tire application.
Old 08-13-2016, 09:37 PM   #33
Ravenna , Ohio
If all we have to go on is GVW we have some additional factors to deal with. This is why learning the actual loads on the tires is important. lacking the facts we need to apply some adjustments.
Since we don't know the load balance between your axles we apply the 53/47 load split factor.
Heavy axle carries 53% of 4,000 => 2120
Heavy end of the heavy loaded axle 53% of 2120 =. 1,124
Now we apply the 85% factor.to learn the needed load capacity of the tire
1,124/.85 => 1,322#
A tire that is rated to support at least 1,322# would be OK.
BUT I think you can see how much easier it is if you know the actual tire load.
You still need to confirm you have not exceeded the 2000# rating for each axle.
Old 08-20-2016, 07:03 AM   #34
2014 25' FB International
Metuchen , New Jersey
Following discussion.
GenXair is offline   Reply With Quote
Want E-rated 20" tires for 2010 Expedition funkill Tow Vehicles 37 11-19-2015 11:10 AM
Forget about your wimpy 8 ply rated tires... robert claus Tires 5 10-05-2015 07:20 AM
15 '' D rated verses 16'' E rated Tires hodges53 Tires 9 07-25-2014 07:16 PM
D or E Rated Tires? Road Geezer Tires 26 07-05-2014 06:22 PM
