Old 03-10-2008, 09:00 PM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I had planned on ordering 16" aluminum wheels and the BF Coodrich Commercial T/A 225-75-16 LRD tires in late April but one of the other threads mentioned that a call to their dealer said the D range was no longer available. I might be able to have my local dealer find 4 tires but if not, I'm worried that the LRE tire would be a little tough on my '86 Sovereign. If I went with them then what would the appropriate tire pressure be? I couldn't see running them with more than 60-62 psi. I currently have 2 C rated Marathons, 1 D rated Marathon and one D rated Maxxis which replaced a C rated Marathon in October. The C rated Marathons are early 2000 and the D rated is a 2001. This is why it is time to replace them. Should I try to locate the D rated Commercial T/A's or just go with the E rated T/A?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-10-2008, 10:00 PM   #2
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Hi Craig, I just went to the B F Goodrich website and sure enough, they only list LRE tires in the size you indicated. In fact, they also list a 15" tire, but no longer list any LRD tires! I would definitely go with the "E's" because if you were ever to damage a tire, you would beable to get an E replacement. Also, reducing the pressure as you indicated seems logical and appropriate.
So Long!
Bob Thompson is offline   Reply With Quote
Old 03-11-2008, 05:30 AM   #3
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
I'm on my 2 set of commercial TA 15" on stock alum rims and have not had a single problem . First set was changed because of age , over 10 years and still showing no signs of deterioration.
jkcru is offline   Reply With Quote
Old 03-11-2008, 08:29 AM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
tigki2 were those rims the origional 1976 Airstreams ?
Old 03-11-2008, 08:57 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you inflate E tires at the proper pressure there will be no ill effects on your trailer. Weigh your trailer and use the manufactures inflation chart to find the correct tire pressure. Do not inflate E rated tires to the pressure printed on the side wall of the tire. That pressure is for a fully loaded tire. In the case of my 265 75 16 that I run on my trailer that would be 3415 per tire @ 80 lbs. or a trailer weight of 20,490 lbs.
I will post the Goodrich chart in a few days as they are putting one in the mail to me today.
2004 Excursion 4x4
Old 03-11-2008, 01:34 PM   #6
1976 25' Caravanner
Campton , New Hampshire
Yes , they are original
ticki2 is offline   Reply With Quote
Old 03-11-2008, 01:36 PM   #7
1976 25' Caravanner
Gee , this sounds like my post , and mine is gone ?????
Old 03-11-2008, 02:11 PM   #8
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
From the peanut gallery
Apparently, swift Action was taken to make sure the thread conforms to forum guidelines.
I did not, however, see your post, so I have no idea why it is missing. The thread IS a little disjointed without it.
Tom
Old 03-11-2008, 03:03 PM   #9
1976 25' Caravanner
Tom
Tom , it is my post with the wrong name, your missing jkcru's post. Also the thread title when I posted was tires,tires tires. Has someone combined threads?
Old 03-11-2008, 03:34 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
On the topid or LRD vs. LRE tires, I switched my Marathons (D) for a set of BFG Commercial T/A LRE tires before last summer's trip and I had NO problems or issues. I Just like having real truck tires on the CCD which also just happen to match the tires on the Sprinter TV.
Old 03-11-2008, 03:51 PM   #11
TomW's Avatar
1967 26' Overlander
Wrong tree.
I saw the post.
I was wondering who "tigki2" was since there were no other posts before your post that helped me figure it out.
Tom
Old 03-11-2008, 06:02 PM   #12
davidz71's Avatar
1986 25' Sovereign
ticki2,
The moderators moved my posted question under "tires, tires, tires" to a thread of it's own. I was concerned that with the D rated Commercial T/A tires no longer available that the E rated would be a little harder on my 25' trailer.
Lewster,
I was thinking about the psi vs load chart as a possible guide but wasn't sure if airing down from 80 to 60 would be too much for the sidewalls thereby causing heat/early tire demise.
Craig
AIR #0078
3.73 rear end
Old 03-11-2008, 06:17 PM   #13
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
It was your post. Sorry in moving the posts to create this thread I lost your post and had the question. So the least I could do was at least post the question.
Sorry I lost the original.
The reason I moved these posts from the original thread was the original thread was several years old and 10 pages long. So anyone wanting this data may have to drill down 10 pages to get to this relevant question. The thread starter gets more attention this way and answers to questions is what this forum is all about.
Again sorry for the mix up.
>>>>>>>>>>>>>>>>>Action
Old 03-11-2008, 06:55 PM   #14
1976 25' Caravanner
I figured that's what happened , had me laughing , there are just day's like that .
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
How not to load a vehicle dpandorf Tow Vehicles 11 06-28-2007 07:45 AM
Load range D or E? Bing-Bing Tires 5 05-30-2007 01:26 PM
Which Load Range sander17 Tires 27 05-04-2005 06:53 AM
steel radial vs load range c skip Tires 7 05-13-2004 08:39 AM
