Old 02-03-2007, 03:13 PM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Tire cupping
What I've noticed on the old tires is that the curbside tires are evenly worn. The streetside tires have some cupping on the outer edge of the inner tread bar. Appreciate any thoughts.
Old 02-04-2007, 09:43 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Look at the bottom of this link from Goodyear.
Goodyear RV Tires - Tire Care: Load & Inflation - Factors Affecting Tire Wear
Your tires need to be rebalanced. Depending on how severe you may want to rotate the tires after the rebalance. Also the shock in that location has been given a work out. Is it shot too?
>>>>>>>>>>>>>>>>>>>>>>>>>>>Action
Old 02-05-2007, 06:52 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
On ours, the way the tire was worn in a diagonal pattern from the center of the tread to the outer edge, it turned out we needed an axle.
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
