Old 11-03-2010, 08:51 AM   #1
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
could new tires be too wide?
I started renovating my 74 Argosy 28 that I picked up a month ago. The previous owner had new tires put on 100 miles ago. When I exposed the black plastic outer wheel well, there was a rub through at one of the 4 tires. The curb side rear. There is not much space between any of the tires and the inside of the wells. The owners manual shows 7.00x15.
That is also what the new tires are. But could they be wider causing the rubbing?
GeocamperAS is offline   Reply With Quote
Old 11-03-2010, 09:41 AM   #2
SteveH's Avatar
Common Sense , Texas
I would doubt its the tires, however I would check the axle....they've been known to let the wheel and brake assembly move out when they get too old and the rubber has turned hard.
But, you say the problem is on the inside....in that case, the PO has most likely installed different wheels with offset to the inside. That would be my guess.
Regards,
Steve
Old 11-03-2010, 10:14 AM   #3
1974 Argosy 28
Images: 37
I do believe they are to original rims. Even though they have full size hub caps, they have clips for the baby moons.
Old 11-03-2010, 10:17 AM   #4
SteveH's Avatar
It's been a long time, and so I might be wrong, but I owned a '74 Argosy and don't remember them having baby moons.
Regards,
Steve
Old 11-03-2010, 11:16 AM   #5
Jackson , Wisconsin
I'd lean towards 'The wheels have an incorrect offset' if you know that you have the correct tires on the AS.
streamair is offline   Reply With Quote
Old 11-03-2010, 02:15 PM   #6
1974 Argosy 28
Images: 37
How would I know if I have the correct rims? Are there any markings on them?
Old 11-03-2010, 05:12 PM   #7
SteveH's Avatar
They are supposed to be 0 offset, but it's hard to measure with the tire on the wheel. 0 offset means where the hub flange bolts to the wheel is exactly in the middle of the tire. Here's an illustration:
http://kmhafer.datsun510.com/wheel_offset.jpeg
Regards,
Steve
Old 11-03-2010, 06:09 PM   #8
1974 Argosy 28
Images: 37
So if I have the 0 off set, could I go with a negative off set to get them centered in the wells? Better question: If they are 0 off set, why would they be that close to the inside? I mean I can not fit my finger between the tire and the inside but can fit my fist between the tire and the out side. This goes for both curb and road side.
Old 11-03-2010, 07:01 PM   #9
SteveH's Avatar
If it's to that extreem, I would really suspect you have the wrong wheels. It might be worth it to take one off, remove the tire, and measure it.
Regards,
Steve
Old 11-09-2010, 04:04 PM   #10
1974 Argosy 28
Images: 37
OK, took wheel off camper. With a straight edge on the edge of the rim
Back of the lug holes to the outside is 3-1/4".
Back of the lug holes to the inside is 4".
So I guess this would be a 3/4" negative off set?
Going with a 0 off set and getting rid of this 3/4" would help.
Old 11-10-2010, 05:00 AM   #11
1974 Argosy 28
Images: 37
Or is that a 3/4" positive off set?
Does the tire need to be centered, or more room on the outside for changing a flat?
Old 11-10-2010, 05:17 AM   #12
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Based on your measurements, your wheel is very wide. My 15" wheels are 6" wide and yours appear to be 7 1/4".
Offset is measured from the center line of the wheel. Since there is a 3/4" difference on yours, it would be a 3/8" offset and I believe yours are a positive offset.
Richard
Old 11-10-2010, 06:08 AM   #13
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
IMHO, it also sounds like the wrong wheels to me. Wrong offset and too wide.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 11-10-2010, 06:12 AM   #14
SteveH's Avatar
I was thinking that also, but the measurement of width of a wheel is taken from the inside of the wheel, where the two tire beads go. Since Tiger measured his wheels from the outside, the wheels are narrower than he measured, but hard to say how wide. That is why I suggested he dismount one tire to get a true measurement. Anyway, it does appear the wheels are offset to the inside.
Regards,
Steve
tires radials or bias ply tires larry b Tires 22 06-27-2010 05:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
How wide is my Excella beemergb 1981 Excella II 0 05-09-2009 12:20 PM
Wide Body George Jr. Buyer Guidelines 0 04-25-2009 05:22 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
