Old 11-10-2010, 10:51 AM   #15
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
So if the wheel is to wide, does that mean the tire is to wide also?
The users manual says 7.00-15 tires, which is what is on these rims.
Going back to my original post, the tire is rubbing on the wheel well.
When the PO got new tires, where the rims replaced also for some reason?
GeocamperAS is offline   Reply With Quote
Old 11-10-2010, 11:00 AM   #16
SteveH's Avatar
Common Sense , Texas
Very possible the wheels were replaced, and if they have offset to the inside, that's most likely your problem. If the wheels are too wide, it might be part of the problem, and if they are too wide and offset to the inside, would make the problem worse.
You really need to inspect and properly measure those wheels, and the only way that I know of to be sure is to remove the tire from the wheel.
Regards,
Steve
Old 11-10-2010, 12:09 PM   #17
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I agree with SteveH. To be sure everything is the way it is supposed to be. Take the tire off the wheel and make the measurements. I suspect it is a combination of the two. And no - the tire is 15 inch. It will expand to fit on the wider wheel as long as it is not too much wider.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 11-10-2010, 12:30 PM   #18
Gainesville , Florida
Wheel size may be on the wheel and, yes the tire must be removed to find it. zz
Old 11-10-2010, 06:46 PM   #19
richinny's Avatar
2011 34' Classic
tire shops have a giant caliper that they use to measure the wheel to determine proper spin balancing. no tire removal is required.
Ricky
tires radials or bias ply tires larry b Tires 22 06-27-2010 05:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
How wide is my Excella beemergb 1981 Excella II 0 05-09-2009 12:20 PM
Wide Body George Jr. Buyer Guidelines 0 04-25-2009 05:22 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
