Old 09-26-2015, 01:09 PM   #1
2012 27' FB International
Boulder , Colorado
Correct tire pressure for aftermarket tires?
Well, the OEM Goodyears finally bit the dust, fortunately before they came apart and damaged the trailer. I had a slow leak in one tire and our rv repair shop noticed that the tire carcass was separating. Quite timely as when they removed all four tires, two of them were several inches taller/shorter than the others due to the tire construction failing.
At any rate, I bought a set of National tires (which I've never heard of, but our rv guy stands behind what he sells). He said to run them at 80psi, but the Airstream manual says to run the tires at 65psi for our 27FB. Do I use the tire manufacturers recommendation or Airstreams??? The National tire site does not have a load/inflation chart online. Any knowledgeable help appreciated.
motozen is offline   Reply With Quote
Old 09-26-2015, 01:35 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Tires should be inflated to a pressure set by the load they are carrying. Weigh the trailer as loaded for a trip and use this chart.
http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
Yes it is a Goodyear chart but the Federal regs require all tires of a given size be made to the same standards. Not sure how it happened that Goodyear tires have so many problems if our Government is really looking out for us.
65 is probably closer than 80 to the correct pressure.
2004 Excursion 4x4
Old 09-26-2015, 02:50 PM   #3
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Motown,
Look at the side wall of your replacement tires. It should have the Max pressure on it. 50 for a "C", 65 for a "D", 80 for a "E" rated tore.
For your 27, it had "E" rated tires, so the 80 psi. Your tire shop should have replaced them with a comparable tire rating capable of your trailer weight rating, GVWR. If not, the they could be at fault and you could have poor handling, or much worse!......
Sphere
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 09-26-2015, 03:19 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Do keep in mind that the listed max air pressure may not be the correct tire pressure. Over inflation in my opinion is a major cause of many trailer tire issues. Right along with gross under inflation and excessive speed. Maybe Tireman will jump in on this.
MICHAEL
Old 09-27-2015, 06:40 AM   #5
CapriRacer
CapriRacer's Avatar
I'm in the , US
Motozen,
Tires are standardized, so the inflation requirements doesn't vary by brand. So if you didn't change size, there is no reason to change inflation pressure.
- BUT -
Collective experience says that trauiler manufacturers have not done a good job of sizing tires and many trailer would benefit from a larger load carrying capacity (and one way to do that is increase the inflation pressure.)
Do we know your trailer is one of those that could benefit from more load carrying capacity? No, we don't. But you can, if you weigh your trailer. Just keep in mind you need to account for side to side and front to rear variation, and speed. (ST tires are restricted to 65 mph!)
CapriRacer is offline   Reply With Quote
Old 09-27-2015, 08:14 AM   #6
Boulder , Colorado
The tires are 'E' rated. I appreciate all your input, but there is no clear consensus. The most logical, but perhaps not optimal, seems to be to use the max rating on the sidewall.
Tireman?
Old 09-27-2015, 09:09 AM   #7
HowieE's Avatar
Images: 12
If you want a reasonable and detailed explanation of tire pressure you may want to read this site.
https://toyotires2-1524598101.netdna...0623_Final.pdf
It all come down to the pressure is a function of the load on the tire.
2004 Excursion 4x4
Old 09-27-2015, 09:37 AM   #8
Mission , Texas
Another that talks about trailer tires specifically.
http://m.discounttire.com/dtcs/infoTrailerTireFacts.do
Our new to us 75 Overlander with twin axles had 7.00x15 STs, 27.8" diameter (one of which could have been original).
The replacements are slightly smaller in diameter, 27.1", (to prevent contact with the front edge of the wheel wells) ST205/75 load rating D, 2,150# @ 65 psi (as indicated on the side wall of the tire). The GVWR of the AS is 6,500#.
I have no idea what the owners manual says about tire inflation for the 7.00x15s, their load rating, or psi from the sidewalls.
nrgtrakr is offline   Reply With Quote
Old 09-27-2015, 12:32 PM   #9
1967 26' Overlander
Spartanburg , South Carolina
This seems to be a never ending debate. I have been running GYM's for nearly 15 years on a '67 Overlander with never a problem. The set on now was made in China in January 2015. The set before was made in Canada. Both appear to have been well made and I take care of them by shading them when in storage, spraying them monthly with ArmorAll Tire Foam when using the trailer and ensuring correct inflation pressures even when stored . The tire pressure chart shown by HowieE above is universal and is the same chart shown to me by my tire dealer. My trailer weighs approx. 5,600 lbs with the weight pretty evenly distributed on its 4 wheels. At 40 psi, the chart says I could weigh 1880 lbs per tire, so I have a safety factor of approx. 480 lbs per tire. I see absolutely no reason to beat my trailer to death running max pressure (65psi) on normal roads at speed limit or less. Approximately 60K trouble free miles on one set of tires confirms it.
I too am puzzled by the stories of GYM's and others not giving good service unless there is something in the way the tires are cared for before or during service on an A/S. My guess is that such tires may have been stored poorly and/or for a long period of time before use. BTW I am a retired Mechanical Engineer but certainly not a tire expert.
Jacob D is offline   Reply With Quote
Old 09-27-2015, 03:15 PM   #10
2007 28' Classic
Ivanhoe , Virginia
To add to the confusions; our new to us '07 Classic 29' load range d tires were replaced with load range e. Ok to run at 65# per AS recommendations, even though sidewall max is 80#? Don't want to over heat, nor do I want to beat the trailer apart.
Thanks.
senioryakker is offline   Reply With Quote
Old 09-27-2015, 03:34 PM   #11
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Tireman?
Trailer Tire Load/Inflation Chart | Maxxis Tires USA
Here is Maxxis chart for 15 inch ST tires rated at E (80 lbs). As you see you gain several 100s pounds of carrying capability with the E tires at 80. If you want, as some suggest, to lower the pressure to 65 or even lower, for a smoother ride and because you are still legal to carry your trailer weight, that's fine. However, understand that you have given up the tire's ability to carry that extra weight and in essence, at 65 psi you are running a D tire. If you lower psi to 50 you are running a C tire that will carry 2150 pounds. If you buy a 10 ply tire that has way more muscle to carry your load than needed and makes you feel comfortable when and if you do have a flat and need to run on the one tire for a while, air your E tires up to E tire pressures--or at least close. We run Maxxis 225/75 15 "Es" on our 2012 30 FC. I run them at 75 cold and nothing moves inside the trailer during tow, so can not comment on why others get a rough ride with 10 ply tires.
Another issue, if you run over 65 mph with your ST tires, you need to add 10 or even 20 psi to chart listed pressures for the weight you are carrying with those tires. In doing that, you need a tire that you can add that air pressure to and still be under the sidewall PSI. So whether needed or not, a E/10ply tire gives you extra security in a number of ways--but only if the pressure is there.
Howard L. is offline   Reply With Quote
Old 09-27-2015, 05:40 PM   #12
Boulder , Colorado
A couple of more data points, just in case someone will actually venture to recommend a definitive # for the tire pressure. Fully loaded the 27FB wights in at a hair under 6,500 lbs, and I believe we have 16" aluminum wheels. We run exclusively out west and often at 70 - 80 mph...except when in California with the (unbelievable) 55 mph limit.
Old 09-27-2015, 05:58 PM   #13
Mission , Texas
I think you'll need to provide the exact and complete tire data if you want a specific psi recommendation.
Me, again I'd go with what the psi max from the sidewall info, use trailer tires and never exceed 65 mph. My father was a chemical engineer who worked product improvement for Gates rubber and an avid RVer. On his towables he used STs and stayed under 65 mph - never had a blow out or other tire problems, good enough for me.
Old 09-28-2015, 06:06 AM   #14
CapriRacer
CapriRacer's Avatar
I'm in the , US
Thanks.
Yes. In effect you are running the Load Range E tires at Load Range D conditions - and the tire doesn't know the difference.
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Calculating the correct tire pressure to use MrJim Tires 122 10-20-2014 04:43 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Correct tire pressure Centerfielder Tires 16 06-21-2004 06:15 AM
