Old 08-25-2016, 08:03 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Correct psi
2015 FC 28 Rear Queen: I replaced the 15 wheels and Marathons with 16" wheels and Michelin 225/75's LTX. Max PSI is 80. I run 75 PSI. Interested in what others are running. I have been reading here that many recommend 65 PSI. Would appreciate any input. I have had several inside rivets to pop.
DeltaRon is offline   Reply With Quote
Old 08-25-2016, 08:33 PM   #2
2016 28' Pendleton
East central , Illinois
I run the same tires and rims at 60 psi. If you look at the Michelin web site they have a table showing the recommended pressure for different loads. For my Pendleton they recommend 55-60. I would expect your FC 28 to be the same but you should check their table.
GinaNBob is offline   Reply With Quote
Old 08-25-2016, 10:24 PM   #3
silverlabs's Avatar
2014 25' Flying Cloud
Waxahachie , Texas
I run 65psi as well on my 2015 28FC. Check the Michelin chart as previously mentioned to review the weight/pressure recommendations. The popped rivets can be from a combination of things including tire pressure, hitch setup and road conditions.
Chuck
silverlabs is offline   Reply With Quote
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 10:11 AM
Manual says ST225/75R15LRC 50 psi -- PO used ST225/75R15LRD at 65 psi Driver1 Tires 3 06-23-2008 08:26 PM
What PSI should I have my tires? silversled Tires 7 03-03-2008 12:05 AM
Tire PSI? ldetsf Tires 9 11-10-2006 08:18 AM
Shurflo regulator_50 psi is not 40 femuse Water Heaters, Filters & Pumps 6 03-28-2003 09:54 AM
