Old 08-05-2012, 09:54 PM   #1
1954 22' Safari
Little Compton , Rhode Island
Correct 1954 Safari tires
New tires and wheels are needed for my 1954 Safari. The original brochures and specs call for 7.00 x 15 tires, however, the tires (quite old) presently on the Safari are 7.00 x 16. What's particularly confusing is the fact that the trailer has, what appear to be, original split 16" rims.
15 inch ST tires and new rims are readily obtainable but I can't be sure they are right and might lower clearance height.
Any advice would be greatly appreciated.
Collapso is offline   Reply With Quote
Old 08-05-2012, 10:59 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I use 700 x 15 tires on my Cloud and they are great. I use 225 x 75 x 15 on the Bubble..they are great. Get rid of any split rim rig....dangerous and almost impossible to find a shop that will chance working with them. If your really worried about ground clearance install the axle below the springs.
Old 09-20-2016, 12:57 PM   #3
1955 30' Liner Commodore Vanderbilt
Linden , Michigan
Tire Size and Manufacturer?
So, what did you end up using on your Safari?
StevieB is offline   Reply With Quote
