Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 09-11-2009, 07:41 PM   #1
RLS
RLS's Avatar
Profile:  2004 25' Classic
Longwood , Florida
Continental Vanco 2 225/70R15C tires
Here is another tire to consider if you are getting upset with the trailer tires that are out there. I have installed these on mine. They look good and from what I have researched, should do the job without having to go to 16" wheels. They are a commercial D rated tire with a max. load of 2470 lbs. @ 65 psi. and a speed rating of 106 mph.
Oh, I have NO connections with Continental in any way
RLS is offline   Reply With Quote
Old 09-11-2009, 07:48 PM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Your post says your new tires 225/70's. Does the lower diameter tire diameter affect the stance of your trailer? I'd love to see a picture of your trailer with the smaller tires on it.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 09-11-2009, 08:52 PM   #3
RLS
RLS's Avatar
Longwood , Florida
Hey Brian, it does sit about 1/2 " lower. The Marathon's diameter is 28.3" and the Vanco 2 are 27.4 " A will get a photo up later.
Old 09-11-2009, 09:07 PM   #4
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 45
Look interesting
Continental Vanco 2
Old 09-12-2009, 03:09 PM   #5
RLS
RLS's Avatar
Longwood , Florida
Brian, not sure what type of photo you are after, up close or what. So here are 2 shots.
ID:	87089   Click image for larger version
Old 09-12-2009, 05:34 PM   #6
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Interesting. How close are the sides of the tires to the insides of the wheelwells? >Lower aspect ratio means wider tire.<
(No Longer at Inland RV)
Old 09-12-2009, 05:53 PM   #7
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Are the Vancos ST or LT tires?
Pay no attention to the man behind the curtain- WoZ
Old 09-12-2009, 06:15 PM   #8
RLS
RLS's Avatar
Longwood , Florida
The Vancos are a commercial mini bus van tire. They are defiantly not an ST tire, and I do not think they are rated as an LT tire either.
I just got back from a 22 day trip stopping at 4 campsites and covering about 1,200 miles with these tires. I stay at about 72 to 76 mph on the interstate. Got into some interstate construction areas that really bounced the Airstream around with no markings or rub marks on the wheel wells. It did bounce everything we had on the rear bed off! LOL
I would say there is about 1"- 1.25" of room in the inside and about 1.5" outside.
ID:	87096   Click image for larger version
Old 09-12-2009, 06:29 PM   #9
Lumatic's Avatar
I thought the only tires that were recommended for Airstreams or for trailers in general were ST or LT tires?
Old 09-12-2009, 09:14 PM   #10
RLS
RLS's Avatar
Longwood , Florida
Good question! I'm gonna go out on a limb here and say the Vanco tire is like an LT tire since it has both the index load rating and a D load rating JMHO! I do know from the highway towing I've done with them on that there is no difference on how the trailer tracks in comparison to when the Marathon tires were on. If anything, it tracks better. Hopefully someone with more knowledge about tires will chime in about this.
Old 11-21-2009, 09:08 AM   #11
HankandLois's Avatar
Profile:  2008 27' International CCD FB
Nashville , Tennessee
In order to bring this thread back to life....are there any more actual applications from the readers who may be using the Continental Vanco 2 tires. I have to replace my Goodyear OEM tires after a blowout. I had about 12K miles on the tires and wish not to repeat that experience!!! However, the list of replacements are indeed short and quality of all is questionable. These tires are new to my list and are priced in the same ballpark has Goodyear.
Lois' Airstream Blog
Air # 20467
WBCCI Member at Large #4018
HankandLois is offline   Reply With Quote
Old 11-21-2009, 10:22 AM   #12
snake's Avatar
Profile:  1994 21' Sovereign
1999 19' Bambi
Tucson , Arizona
Question Made in ????
Where are these tires manufactured? There should be two letters in the DOT code on the side of the tire that indicate the location.
I bought a set of Carlisle tires that were supposed to have been made in the good ol' USA, but the DOT code revealed that they were from the other side of the Earth.
The required "Made in China" marking was placed on the part of the tire that is covered by the rim when mounted!
snake is offline   Reply With Quote
Old 11-21-2009, 10:51 AM   #13
RLS
RLS's Avatar
Longwood , Florida
Tires come from Germany
Old 11-21-2009, 12:52 PM   #14
2airishuman's Avatar
Profile:
Originally Posted by HankandLois View Post
...are there any more actual applications from the readers who may be using the Continental Vanco 2 tires...
hi hank
it appears this is a passenger van tire (car like ride with EXTRA load and tread life)
it is interesting that there is only 1 review on the tr site, i've never seen JUST 1 review there on a tire.
Continental Vanco 2
vanco is a class/style with 5-6 models to choose from.
Contis
and here's the conti stuff...
Continental Tires - Continental launches the Vanco 2:
so it appears this model is similar in application and design to the mich' x or lt series for vans.
good luck choosing!
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Renew old tire topic: 7.00-15 to 225/75R-15 jdnorris Tires 2 07-10-2009 03:21 PM
BF Goodrich Commercial T/A LT 225/75R16 Chitown AirStreamers Tires 7 07-29-2008 07:15 PM
Continental Travel Trailer coo978 Off Topic Forum 0 11-18-2007 02:51 PM
Trans-continental trip winner On The Road... 6 10-27-2002 09:49 AM
