Old 05-23-2011, 12:20 PM   #1
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
changing tires on 34' triple axle
Has anyone changed the tires on a triple axle? Did you do it on ramps or is there a jacking point on the 34's.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 05-23-2011, 12:48 PM   #2
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I use a piston jack when i take the tires off mine. Make sure you catch the frame. I am sure there are other ways to do this as well.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 05-23-2011, 01:25 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Loosen lug nuts on rim to be changed (note - only loosen them not take them off) Put 2x8x12 inch blocks in front of two tires not being changed. Pull forward - it helps to double stack them to 4 inches. Remove rim and tire with flat and replace - pull trailer forward off blocks. Stable, safe for side of road, no working parts to fail and cheap to buy. Blocks have many uses in camp as jack stabilizer pads, emergency firewood, etc.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-02-2011, 09:51 PM   #4
Hodum's Avatar
1995 34' Excella
Corinth , Mississippi
There is a jacking point behind the rear wheel. it is marked "JACK" underneath the trailer and to the rear of the axles, however it is marked near the edge of the trailer for visability and you must jack on the frame member.
Why settle for anything less?
1995 34ft Classic Excella 1000
2012 Kings Ranch F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
Hodum is offline   Reply With Quote
Old 12-02-2011, 10:02 PM   #5
That is not a good place to jack up the trailer, as the jack can slip off very easily, AND, often does, since the trailer will be tilted.
The very best and safest place to use to jack up the trailer is to use the axle mounting plates.
You can even use a floor jack on those, if you wish.
Old 12-02-2011, 11:59 PM   #6
1974 Argosy 20
Kooskia , Idaho
Yes, Andy is correct for sure. I had a single axle AS blow a tire on the Alaskan highway years ago. I had it jacked up using the "jack point" and a truck came buy and the bow wave pressure blew the AS off the bottle jack, which then punctured the belly pan and the floor of the AS, coming out in a storage compartment. What a mess.
I learned the hard way. Listen to Andy (what happened to me was prior to the AS net)
Old 12-03-2011, 12:17 AM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I bought a Trailer Aid Plus for my trailer.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-03-2011, 05:27 AM   #8
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I vote for Trailer Aid or equivalent ramps. Even floor jacks slip, unless you are working on a perfectly level concrete floor like Andy does at his shop. Bottle jacks are definitely less safe. Doing it on gravel or a tilted driveway is definitely out.
Old 12-03-2011, 07:48 AM   #9
1985 31' Limited
Nellysford , Virginia
I vote for the Rrailer Aid. Easy to use. "new"model has one inch added to lift height for better clearance.
RTurnConn is offline   Reply With Quote
Old 12-03-2011, 07:50 AM   #10
1985 31' Limited
Trailer not Rrailer! Fat fingers and small iPad keyboard.
Old 12-03-2011, 06:39 PM   #11
Hodum's Avatar
1995 34' Excella
Thank you very much Andy. I have only had to jack once and used a floor jack at the jack point OK, but I was in my level concrete driveway.
If on the road I would probably call road service but I often wander if they would be as particular with my trailer as I would like.
TAC # MS-8
Old 12-03-2011, 08:03 PM   #12
Probably not, since they don't know what a torsion axle is all about.
Old 01-27-2016, 08:38 PM   #13
Old Sailor
McArthur's Avatar
1983 34' Excella
Victoria , Texas
Trailer Aids
If it's the middle tire on a triple axle, wouldn't you need two Trailer Aids?
McArthur is offline   Reply With Quote
Old 01-27-2016, 10:49 PM   #14
Salem , Oregon
Images: 18
Hi, I have the Trailer Aid "PLUS" which is the one that has the rubber pad making about one inch taller than the Trailer Aid. I believe that one "Plus" would be enough for a 34'er. Also you would only be able to use one because they won't fit between the wheels.
2005 Safari 25-B
Towing a 34' triple axle airstream floidoip Towing, Tow Vehicles & Hitches 17 02-22-2013 10:32 AM
Airstream excella 1000 1992 34 ft / triple axle 1 owner from new fabulous cond ! eBay Watch Airstreams on eBay 0 11-16-2011 01:00 PM
1985 Triple Axle 35 foot Airstream Sovereign Trailer with two awnings! eBay Watch Airstreams on eBay 0 11-08-2011 07:00 PM
35 foot Triple axle Airstream with rear beds, side bath eBay Watch Airstreams on eBay 0 09-18-2011 06:30 PM
35 foot Triple axle Airstream with rear beds, side bath eBay Watch Airstreams on eBay 0 08-14-2011 07:10 PM
