Old 01-22-2013, 12:53 PM   #15
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Here's the best chock-trailer aid that I have found. Light and easy to use.
http://www.genuinehotrod.com/itemgroup/trailer-aid
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 01-22-2013, 01:08 PM   #16
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by 100ProofDera View Post
The trailer I bought had been sitting for years and the tires are dry rotted. My two ton floor jack isn't enough. So my question is whats the easiest way to get those tires off the ground? Thanks!
Hi, not really your question, but I find it hard to believe that a 4,000 lb floor jack can't pick up, an about, 4,000 lb trailer enough to change the tires. Mine will!
If your jack looks like the one in the first picture, I guess I can understand.
If your jack looks like the one in the second picture [not mine, but looks just like it] you should have no problem picking up your trailer to change tires.
ID:	177231   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
