Old 09-12-2003, 06:13 PM   #1
1994 30' Excella
New Smyrna Beach , Florida
changing tires?????
I pulled my tires to repack my wheel bearings and I had a very difficult time trying to put the tires back on the trailer. We have a 2001 Bambi and I had the tires to 60 lbs. pressure. It seems that the wheel well is very tight and when you have to lift the tire and angle it up, there is very little room to work. We live in florida and it was hot so I expect that the tire pressure was more than the cold pressure of 60 pounds. Could this make it so difficult. I finally let about 2o pounds of air out and the tire went in. Has anyone else encounter this challenge? Can anyone give me some advice on making it easier.
thank you'
bob caldwell
rcaldwel is offline   Reply With Quote
« Tire recalls | Top | Tires »
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
"We don't normally balance trailer tires....." Pick Tires 36 07-16-2012 02:30 PM
Tires Causing Sway? Pick Tires 14 12-03-2006 04:38 PM
Questions about trailer tires... cactushead Tires 2 10-22-2003 05:58 PM
tires? trailer will sit after move goodgrey Tires 4 12-06-2002 02:10 PM
