Old 11-25-2008, 10:32 PM   #21
Halimer
2006 25' Classic
New Hyde Park , New York
I get all my tires from Costco and they fill the tires with N, as part of their service. They'll also fill up my air tank and top off my vehicle tires. Since N is inert it is not effected by altitude ( used in aircraft tires).
halimer is offline   Reply With Quote
Old 11-25-2008, 11:18 PM   #22
Vintage Kin
Fort Worth , Texas
Originally Posted by ROBERT CROSS View Post
Or go to the nearest welding supply and get a tank of your own or 12v portable compressor
Yeah, agreed, but too much money yet to spend on house prep items first (build shutters, etc). If no hurry-cane in '09 then maybe I can spring for it. A nitrogen fill is on the list -- cheap by comparison.
Old 11-26-2008, 07:49 AM   #23
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
A simple and inexpensive line dryer will solve 99% of any water that may delivered. As air is mostly nitrogen, getting 100% nitrogen is just a revenue generator for those who supply this "service".
Of course I have a small portable 12v compressor in the truck with me on all trips which does not have a line dryer, but in the event I need it, I would always opt to use it or even a gas station compressor in the event of a dire need. Most times than not, I set the tire pressures at home using my main compressor with a line dryer, and off I go.
To each their own though.
Old 11-28-2008, 11:51 AM   #24
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
With five vehicles and two trailers (both double axle) I have 35 mounted and air up tires on rims. This includes spares. At $10 a tire I would be chuncking out $350.
The air compressor with dryer works well for me saving me time and cost of gas driving over to some place to install N in my tires.
I have an added bonus in the relative humidity is usually in single digit land. Except for days like today when it did rain and the humidity is 78%.
>>>>>>>>>>>>>Action
Old 11-28-2008, 02:57 PM   #25
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Oxygen and moisture are the biggest factor in corosion inside the rim,install nitrogen and you get rid of both.I have 24 tires on different vehicles,and they all have Nitrogen. I keep at least 2 tanks around,because I install medical gas lines,nitrogen must be flowed thru the lines to prevent oxidation from the heat & oxygen.Some one stated nitrogen is flamable,that is far from the truth,you can put out a fire with nitrogen. Plumber Dave
easyride is offline   Reply With Quote
Old 11-28-2008, 08:58 PM   #26
Vintage Kin
Fort Worth , Texas
I have about 18, so a tanks looks better and better.
Old 11-28-2008, 09:06 PM   #27
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Interesting, today the RF tire went rim flat on my wife's car. Pumped it up with reg dried compressed air. Found a nail in the tread. Will have to get it fixed tommorrow.
Would have used up a whole tire's worth of N if it had such. BTW humidity fell to 58% when I ran the compressor to fill the tire.
>>>>>>>>>>>Action
Old 11-28-2008, 09:10 PM   #28
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
BTW one of the advantages of AZ is the low humidity. Average rain fall in the Phoenix area is less than 10 inches. A disadvantage is the lack of rain on the road. The debris does not get washed away because of the lack of rain.
So I guess I takes the good with the bad.
>>>>>>>>>>>>>>Action
Old 11-29-2008, 12:47 AM   #29
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
[quote=Action;642972]Interesting, today the RF tire went rim flat on my wife's car. Pumped it up with reg dried compressed air. Found a nail in the tread. Will have to get it fixed tommorrow.
Hi, but if you had Nitrogen in your tire the nail wouldn't rust.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-29-2008, 07:28 AM   #30
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Good point!
>>>>>>>>>>>>>Action
Old 11-29-2008, 12:17 PM   #31
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Larry in MO View Post
I'm not sure I'd want to spend a Saturday trying to put 6 oz of glass beads in the tire valve stem, however.
The beads are usually installed by breaking down the bead of the tire, and tossing a degradable bag containing the beads into the tire, and reinflating the tire.
Old 11-29-2008, 12:29 PM   #32
1986 31' Sovereign
Miami , Florida
Just a thought -- isn't there several cubic feet of amibient air in the tire, uncompressed, as it sits mounted but yet to be filled? So you put in your $10 of nitrogen but you still have traces of oxygen, carbon dioxide, trace gasses and moisture. It'ss not like they vacuum the tire down before filling with N.
Personally, I vote for the 78% nitrogen "au naturale" product.
mike
Old 11-29-2008, 02:29 PM   #33
Larry in MO's Avatar
1957 22' Flying Cloud
Lone Jack , Missouri
Images: 27
I shoulda thought of that.............
Thanks, Terry. That oughta speed things.
Larry
"Turleen", the '57 Flying Cloud
Lone Jack, MO
Pop.528
"You better learn it fast; you better learn it young"-John Fogerty
Larry in MO is offline   Reply With Quote
Old 11-29-2008, 03:48 PM   #34
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Wouldn't the beads degrade the inside of the tire? I know the company says it won't, but I find that hard to believe. I guess it's the same principal as the Centramatic, but cheaper. How much do the beads cost? How do you get the tire installer to save them from the old tires?
Gene
Old 11-29-2008, 05:10 PM   #35
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Update - the nail ended the service life of the tire. Bought new set of French tires. Use compressed air for inflation.
Discount was the vendor. Costco was about $100 more for the same set. So I passed on the N from the Costco store.
>>>>>>>>>>>>>Action
Old 11-29-2008, 09:09 PM   #36
1993 21' Sovereign
Gene
The beads are single-use, that is, you get a new bag installed when you R&R the tire. Most bags I've seen run about $10 or so.
Old 11-29-2008, 10:09 PM   #37
Central , Mississippi
High Performance 'streamin'
We ran Nitrogen in our racing karts, but only after years of tweeking every variable and understanding the result. The only reason we used it was we would adjust airpressure in each tire independent and used +-.5 PSI to adjust the handling. The tire pressure would jump 2-3 psi as the tires heated when we used air, 1-2 when we ran Nitrogen.
When I see a need to tweek my trailer tires based on road conditions, understeer, oversteer, turn-in.... I'll start totin' a tube of nitrogen....till then I'll pump up the atmosphere and stuff it into the tire...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 11-29-2008, 10:55 PM   #38
Salem , Oregon
Images: 18
Purge the old air?
mike
Hi, [example] when doing a proper A/C service or repair, you vacuum the system to as close to 30" vacuum as possible before refilling with refrigerant; If you were to try doing this to tires and wheels, you would probably pull the tire off of the bead. so the tire is still, basically full of air, at zero pounds pressure. What percentage is the nitrogen at 65 lbs and how can you prove it? And if nitrogen is air with the moisture/water removed, what makes the molecules larger? Do the swell up or expand?
2005 Safari 25-B
Filling tires/nitrogen Gas Phil Gobie Tires 44 04-26-2009 03:31 PM
Name changed NVDeputy Member Introductions 3 03-08-2008 03:09 PM
Nitrogen in Tires? dpandorf Tires 24 04-29-2007 09:20 PM
Tire inflation with nitrogen jordandvm Tires 19 10-31-2005 11:49 AM
Poll : PURE NITROGEN ( Z ) in tires brunoffrance Tires 37 11-18-2003 09:10 PM
