Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 07-09-2009, 08:45 PM   #1
Profile:
Centramatics
I just installed my new Centramatics today. Mine are aluminum.
I had to put the doughnut out because it would rub on the calipers for the disc brakes.
I also put a set on my antique semi tractor. They really smoothed out the front end.
Hickory
hickory is offline   Reply With Quote
Old 11-12-2009, 06:33 PM   #2
Profile:  2000 34' Limited S/O
Jamestown , North Carolina
Hickory
I ordered my Centramatics today from Andy. I'm confused in reading posts where some are saying that they need to be reversed in order to work properly on their trailers.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 11-12-2009, 06:39 PM   #3
Wingeezer's Avatar
Profile:  2005 30' Classic
Burlington , Ontario
I think it will just depend on the style of wheel you have fitted.
Its no big deal either way, you will find out as so as you install them if you need to reverse them.
I didn't need to with the stock Alcoa wheels on our Classic 30.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-12-2009, 06:47 PM   #4
Brian
Thanks. I also have the Alcoa wheels.
WBCCI #4358
Motorhome Archives Update 1985air345 Airstream Motorhome Forums 15 09-06-2006 07:58 PM
Water pump recycling update.... Guitars Water Heaters, Filters & Pumps 6 11-27-2002 08:33 AM
RDM update from Myrtle Beach rdm General Motorhome Topics 0 11-18-2002 08:32 PM
New Owner-tow vehicle discussions JodynJeep Our Community 28 10-15-2002 11:43 PM
