Old 09-24-2012, 02:20 PM   #121
Ottawa , ON
Photo won't open for me, Perry...
Old 09-24-2012, 02:49 PM   #122
Originally Posted by perryg114 View Post
I said I would post the dimensions of my wheels a while back to see if anyone could tell me if the Centramatics would fit my wheels. Here is a drawing of what the inside of my wheels look like. I made this drawing to see if I could use disk brakes with my wheels and the answer is no, they won't fit without some spacers. The question is if the centramatics will fit. If the Centramatics are bigger than 11.5 inches they won't fit.
http://www.motorcycleproducts.org/AS...Rim%5B1%5D.pdf
Perry
Your photo opened just fine for me.
That drawing shows that there is a 11.5 inch flat surface on the backside of the wheel.
If that's the case then the Centramatic that we have made will fit just fine.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-24-2012, 03:15 PM   #123
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
It is a pdf file.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 09-24-2012, 03:17 PM   #124
airperson
2006 25' Classic
Ft Worth , Texas
Was told that they were on my Airstream. Can I tell if they are without taking off tires.
Airperson is offline   Reply With Quote
Old 09-25-2012, 07:32 AM   #125
1981 31' Excella II
New Market , Alabama
Andy what is the outer diameter and thickness at the outer diameter of your balancers?
What I need to do next is draw the drum. I think the main problem is how far the drum surface is from the plane of the mounting bolts. The boses for the lug bolts stick out past the drum surface a good bit so I don't think it will be a problem. I think the problems occur when newer drums are used with older rims.
Perry
Old 09-25-2012, 07:53 AM   #126
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Why not call the Centramatic Company. Located just south of Ft. Worth, Texas.....they are great folks and will do all to help you out. Drive in there with your vehicle and they will even install the Centramatics while you wait.
Old 09-25-2012, 08:08 AM   #127
1981 31' Excella II
I did call them and they make a special model 200-221 with a 10" outer diameter and 3/4" thickness at that diameter. This is probably the one Andy has.
Their standard model is a 300-356 which is 12-3/4" diameter and 7/8" thickness. This won't fit 15" rims but might fit a 16" rim. You have to measure the inside of the rim to find out.
These are both are a 6 bolt pattern on 5.5" bolt circle.
I will draw up my brake drums and post the entire assembly when I get it made. Hopefully this won't take as long as driving to TX. Ok so I have too much spare time at work.
Perry
Old 09-25-2012, 11:08 AM   #128
Centramatic makes a "special model" for use, that is used on most of the Airstream and Argosy trailers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-25-2012, 11:11 AM   #129
Perry
Perry.
Yes, Centramatic makes the 10 inch version, for us.
The lip dimension on the outside of the circle, is 3/4 inch.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-25-2012, 01:31 PM   #130
1981 31' Excella II
Can you define what special means in this case?
Perry
Old 09-25-2012, 03:09 PM   #131
Perry
Special, in this case, means it is made exclusively for us, and is not in any catalog.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-27-2012, 12:15 PM   #132
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Several years ago when Inland Andy started carrying them I ordered them from him and they fit the 15" wheels. When I switched to 16" wheels, they still fit.
I think I saw them on the Centramatics website back then as well.
Gene
Old 09-27-2012, 12:24 PM   #133
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
I ordered mine directly from Centramatics.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 09-27-2012, 01:07 PM   #134
dznf0g's Avatar
Oswego , Illinois
Gene
Ditto here...from Centramatic directly though.
-Rich-
Old 09-27-2012, 08:04 PM   #135
reinergirl's Avatar
Hollis , New Hampshire
I've posted this link below before, I bookmarked it because it theorizes that the 10 inch centramics are far less effective than the full size ones.... Would any armchair mechanics or those of you more technically inclined care to comment on that conclusion?
http://home.hiwaay.net/~tomorkim/Centramatics.htm
reinergirl is offline   Reply With Quote
Old 09-27-2012, 10:10 PM   #136
Ag&Au's Avatar
Port Orchard , Washington
I ordered a set a few weeks ago. The Airstream ones were not listed on
centramatic's website. I called Centramatic and told them I needed a set for 15 inch Airstream wheels. I placed the order with them. They showed up in about 5 days. They fit the drums and my new 16 inch wheels just fine. I recommend that you order them from the factory. That way you are assured of getting what you need.
Ken
Old 09-28-2012, 06:53 AM   #137
dznf0g's Avatar
Oswego , Illinois
Marginally...maybe, IMHO. Centrifugal force will be somewhat less on a smaller diameter. HOWEVER, since Centramatic says that they become effective at 35mph, a smaller diameter (2"?) may become effective at 40mph?? Who cares?
The same argument could be made for a 12" set put on a 28" tall tire as opposed to a 32" tire. Centramatic doesn't sell different models specifically for taller tires, just different wheel shapes and configurations. I think it's much ado about nothing.
Also, I don't believe Centramatic advertises this product as a REPLACEMENT for spin balancing the tire and wheel. It is used in addition to balancing the tire and wheel, so the reduction in CALCULATED ability doesn't reduce the effectiveness of the product, unless you are WAY out of balance.
There is also the assumption that the same innerds are present in all models. I don't know if that's true or not.
-Rich-
Old 09-28-2012, 07:00 AM   #138
1981 31' Excella II
Tom who did those calculations is correct. The bigger the diameter of the balancer the more effective it is in correcting out of balance issues. However, if you get your tires balanced so they are in the ball park the balancers can take care of the imbalanced caused by the drums not being balanced. The reason they are 10" in diameter is so they will not hit the older 15" rims. If you are running 16" rims and you have 12.75 inches of space in the plane of the lug bolts then use the model 300-356 if you have 15" rims you need the 200-221 special which is the standard 5 bolt 200-221 drilled for 6 bolt rims. The standard 200-221 has a 5 bolt pattern so they need to know that that you want the 6 bolt 5.5in dia bolt pattern. If you order the ones from Andy they will fit and you don't have to worry about any of this.
Perry
Old 09-28-2012, 07:53 AM   #139
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Perry is right on. Call Andy and you will know what your getting...from my experience.
Old 09-28-2012, 08:48 AM   #140
ZoominC6's Avatar
2004 30' Classic Slideout
2021 33FB Classic
Colleyville , TX
Sure you can. If your wheels are spoked aluminum you won't be able to see through them as the metal pan of the Centramatics blocks the view. One cool modification is to take the Centramatics off, clean them with a good solvent or denatured alcohol and then paint them flat black with a heat resistant type paint or epoxy. The spokes of your wheels will show much better. Good luck and happy trails.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Motorhome Archives Update ViewRVs Airstream Motorhome Forums 15 09-06-2006 06:58 PM
Water pump recycling update.... Guitars Water Heaters, Filters & Pumps 6 11-27-2002 07:33 AM
RDM update from Myrtle Beach rdm General Motorhome Topics 0 11-18-2002 07:32 PM
New Owner-tow vehicle discussions JodynJeep Our Community 28 10-15-2002 10:43 PM
