Old 02-08-2012, 07:02 PM   #113
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Originally Posted by perryg114
I want to put a data logger in my trailer and measure actual g-forces. I have everything at work accept a g-sensor.
A before and after Centramatics would be good data. It looks like putting Centramatics on my 81 with stock aluminum rims is going to be a pain. I think it will require spacers to make them work.
Perry
My trailer had kodiak disc brakes and the aluminum wheels with 1/4 spacers already installed when I got my trailer. The centramatics I ordered from Inland RV Andy luckily fit.
Good luck on your research.
desertair27 is offline   Reply With Quote
Old 02-09-2012, 09:09 AM   #114
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
I'm a little surprised by the unwillingness of people to ride in their own trailer. What do they expect it to ride like? For the record, it rides just like a motor home without the engine noise. I DO NOT suggest you ride in the trailer frequently or for long periods, but I DO suggest that if you find yourself on a very quiet, safe, and very low traffic piece of road, put your significant other in the trailer or ride back there yourself for a couple miles so you get some real life imput into what goes on back there. We did it recently while traveling from Savannah to Jacksonville. Between Woodbine and Kings Island there is Hwy 17 which parallels I-95. We take Hwy 17 because it is a very good, very smooth, low traffic road. I saw a portion of it as a perfect place to check the ride back there, so I had the wife go back and ride in the trailer for about 5 miles.
We used the walkee-talkees to communicate. She found it to be very much like riding in a motorhome without the engine noise. Really, we should have expected that! Other than that, there was no detectable shimmy from the tires in speeds up to 65 mph. None was expected as we have the Centramatics. There was the usual squeeks and flex noises you would hear in a motorhome. Actually, it was quite serene with the exception of a rattle from the stovetop cover. We placed an old towel over the burners and put the lid down. Problem solved. My wife also noted firm bumps when the trailer tires would encounter a transition from roadbed to bridge. I dropped the trailer tire pressure from 50psi to 40psi and that smoothed it out quite nicely. We're running LR E tires on the trailer and I was curious if there stiffness was having any impact on the ride back there. Maybe a little stiff at higher tire pressures, but not a problem otherwise.
So Long!
Bob Thompson is offline   Reply With Quote
Old 02-09-2012, 09:26 AM   #115
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I always thought it was illegal to ride in a moving trailer! I'll be mounting a video camera in mine to record part of my next trip.
Tire psi is a matter of preference but again I've read manufactures max tire pressure to be preferred by most.
Everyone's different and whatever works for ya!
Old 02-09-2012, 09:35 AM   #116
1981 31' Excella II
New Market , Alabama
It is illegal if you get caught. So is breaking the speed limit which most of us do on a regular basis. Tire pressure is a big factor in ride. Tires absorb all the little jolts and other high frequency stuff. Suspension can't bounce up and down that fast as a result of the mass of the wheels , and drums and spindles etc. There is a happy medium between too much air and not enough. Making temperature measurements across the face of the tire is a good way to determine proper pressure not the max inflation on the sidewall. Putting higher load range tires on your trailer than it needs and higher pressures that it needs is just going to beat your trailer to death. Proper balance is essential as well. Also the more pressure in the tire the more potential energy is going to be released if it blows. A tire with 50psi in it is going to do a lot less damage than one with 70psi in it when it blows.
Perry
Old 02-09-2012, 10:06 AM   #117
Images: 67
You'll be surprised to find that riding in the trailer is perfectly legal in a number of states. I used to have a listing which shows the states where it is legal, but can't put my hands on it. Here it is:
http://www.towingworld.com/articles/TowingLaws.htm
Ride in travel trailer is over on right side. By my count: 13 states. Surprised? Makes me wonder, there is a YES but the list doesn't show the NO's just blanks.
So Long!
Old 02-10-2012, 08:44 AM   #118
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Bob, that's a pretty old list. It still shows lots of states that don't allow trailers wider than 8'. The other stuff on the list may be wrong too.
Gene
Old 02-10-2012, 09:06 AM   #119
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Bob, do you have concern that 40lbs. might be too soft for load range E tires?
Thanks for sharing,
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 09-24-2012, 01:17 PM   #120
1981 31' Excella II
I said I would post the dimensions of my wheels a while back to see if anyone could tell me if the Centramatics would fit my wheels. Here is a drawing of what the inside of my wheels look like. I made this drawing to see if I could use disk brakes with my wheels and the answer is no, they won't fit without some spacers. The question is if the centramatics will fit. If the Centramatics are bigger than 11.5 inches they won't fit.
http://www.motorcycleproducts.org/AS...Rim%5B1%5D.pdf
Perry
Old 09-24-2012, 02:20 PM   #121
Ottawa , ON
Photo won't open for me, Perry...
If it's to be, it's up to me.
Old 09-24-2012, 02:49 PM   #122
Perry
Your photo opened just fine for me.
That drawing shows that there is a 11.5 inch flat surface on the backside of the wheel.
If that's the case then the Centramatic that we have made will fit just fine.
Old 09-24-2012, 03:15 PM   #123
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
It is a pdf file.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 09-24-2012, 03:17 PM   #124
airperson
2006 25' Classic
Ft Worth , Texas
Was told that they were on my Airstream. Can I tell if they are without taking off tires.
Airperson is offline   Reply With Quote
Old 09-25-2012, 07:32 AM   #125
1981 31' Excella II
Andy what is the outer diameter and thickness at the outer diameter of your balancers?
What I need to do next is draw the drum. I think the main problem is how far the drum surface is from the plane of the mounting bolts. The boses for the lug bolts stick out past the drum surface a good bit so I don't think it will be a problem. I think the problems occur when newer drums are used with older rims.
Perry
Old 09-25-2012, 07:53 AM   #126
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Why not call the Centramatic Company. Located just south of Ft. Worth, Texas.....they are great folks and will do all to help you out. Drive in there with your vehicle and they will even install the Centramatics while you wait.
Motorhome Archives Update ViewRVs Airstream Motorhome Forums 15 09-06-2006 06:58 PM
Water pump recycling update.... Guitars Water Heaters, Filters & Pumps 6 11-27-2002 07:33 AM
RDM update from Myrtle Beach rdm General Motorhome Topics 0 11-18-2002 07:32 PM
New Owner-tow vehicle discussions JodynJeep Our Community 28 10-15-2002 10:43 PM
