09-28-2012, 09:14 AM
#141
Corona
Originally Posted by ZoominC6
Sure you can. If your wheels are spoked aluminum you won't be able to see through them as the metal pan of the Centramatics blocks the view. One cool modification is to take the Centramatics off, clean them with a good solvent or denatured alcohol and then paint them flat black with a heat resistant type paint or epoxy. The spokes of your wheels will show much better. Good luck and happy trails.
The "specials" that we have made, are indeed painted "flat black".
In that way, they do not distract the looks of the mag wheels.
09-29-2012, 07:41 AM
#142
airperson
2006 25' Classic
Ft Worth
Thanks ZoominC6 I will check it out today.
09-29-2012, 07:47 PM
#144
airperson
2006 25' Classic
Ft Worth
zoominC6 I checked it out and I have them. Thanks again for the information. Airperson
10-01-2012, 09:20 PM
#145
Port Orchard
I just checked the Centramatics that I bought recently direct from centramatic. The face that you see through the wheels is finshed in a black wrinkle finish.
Ken
10-02-2012, 05:18 AM
#146
2004 30' Classic Slideout
2021 33FB Classic
Colleyville
, TX
It's great that Centramatics now pre-finishes the units in black as I would imagine their finish would be much more durable than our homemade solution.
In dog years, I'm dead!
10-02-2012, 06:19 AM
#147
1994 30' Excella
alexandria
, Kentucky
I have Centramatic balancers on my pickup truck and recently I had to have them warrantied. The Centramatic folks do back up their warranty which is good.
The truck seemed to be having an annoying vibration while out on the highway at speeds over 60 mph and was really bad around 70 mph. On a hunch I took off the Centramatics and found that on 3 of them the balancing material inside the ring did not make any noise. The truck drove very smoothly thereafter. I have the new warrantied balancers but I have not installed them yet. After talking to the Centramatic folks I don't think this is a very common problem. I think there was a time several years ago when the sealer they used went bad. Apparently they have changed sealers since then.
Something to think about anytime you have a tire dismounted is to make sure the Centramatics make the proper "noise" when you spin the hub.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
10-02-2012, 06:21 AM
#148
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
Thanks for posting this, Steve. Will make sure I hear the "swishing" sound next time I spin a wheel!
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
10-02-2012, 09:40 AM
#149
2021 33FB Classic
Colleyville
, TX
No kidding. Thanks Steve! I purchased ours back in '05 or '06 so will check that out as well.
10-02-2012, 02:34 PM
#150
Oswego
Steve, could you see evidence that the oil had all leaked out. I have heard of that in a few cases before.
-Rich-
12-10-2012, 05:34 PM
#151
1999 34' Excella
Joshua
Will they fit the Dexter axle with drum brakes? A friend has a 6-lug Dexter axle...
History doesn't repeat itself, people do!
12-10-2012, 05:39 PM
#152
Corona
Fitting the drum, is not the issue.
Yes, they will fit.
BUT.....the shape of the back side of the wheel, can cause a problem.
The back side of the wheel, must have a minimum of a 10 inch flat circle.
If it does, as all the steel wheels do, then no problem.
If the trailer has Mag wheels, then the back side must be checked.
12-10-2012, 05:41 PM
#153
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Joshua Texas? Jeeze!!!! You are about 20 miles from the factory store. Call 'em....ask 'em....go over there! They install for free.
03-29-2013, 02:53 PM
#154
i just had new tires installed at discount tire. i had wanted them to put on the centramatics i had bought for my bambi bu the manager shared that 1. with properly road force balanced tires they should not be needed. 2.that there was concern about the centramatic plate against the wheel and that particles could get between and possibly cause the lugs to need to be torqued every hundred miles. the the aluminum wheels were made to fit directly against the thing (drum?) with nothing in between no matter how thin for the ultimate fit and functioning. i got scared of course and deferred the installation until i could get some feed back on these thoughts. i have not heard responses by folks saying that the lugs were loosening in such a frequent way. the discount tire manager just was not feeling in was a wise thing. i can have them put on when i finally go to have the axle serviced. i know i can be a scaredy cat but is what this manager says correct? any help welcome.
03-29-2013, 03:02 PM
#155
1977 Argosy 24
Milltown
, Wisconsin
Road force balancing while the best method to balance a tire and wheel, does not take into consideration an out of balance brake drum. The centramatics balance the whole rotating mass not just the wheel and tire.
03-29-2013, 03:09 PM
#156
Oswego
I have never had the lug nuts loosen after one retorque a few hundred miles after a rotation. Make certain the hub face, the centramatics, and the wheel are clean.
-Rich-
03-29-2013, 03:16 PM
#157
2021 33FB Classic
Colleyville
, TX
We've had our Centramatics on since 2004 and we also have aluminum wheels. We are careful to check our lug nuts with a torque wrench before and after each trip which I feel is a good practice. We've never had a problem. Good question however. Happy trails!
03-29-2013, 03:17 PM
#158
Corona
Your discount tire store manager has grossly mislead you.
First of all, the Centamatic plate rests against the drum.
Two, he obviously knows nothing about an Airstream, it's suspension system or it's design.
If the aluminum wheels have a minimum of a 10 inch flat surface on the back side, the Centramatic will fit correctly.
Third, if any dirt got on to the balancer, it will get off the same way it got on.
Fourth, if what he says was true, then when we get a rock in a tire, everything goes to kapot?? NOT!!!
Lugs always get loose, WHEN they are not properly torqued.
Install the Centramatics, and the next time you need tires, ask the opinion of those that are familiar with what your doing, and not a stranger to technolgy.
03-29-2013, 03:44 PM
#159
Master of Universe
2008 25' Safari FB SE
Grand Junction
Never a problem since using Centramatics—no loose lugnuts.
Gene
Gene
03-29-2013, 03:54 PM
#160
2005 19' Safari
GLENDALE
, AZ
Same here. Centramatics for last 15,000 miles, and no loose lug nuts.
