Old 03-29-2013, 10:39 PM   #169
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by dznf0g View Post
I've been running them 2 years.
That makes me feel better, how many miles?
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 03-29-2013, 10:46 PM   #170
If 1/16 on an inch offset is harmful to nevr lubes, then what happens if you install hub caps?
I really think the nevr lubes belong on farm equipment and not RV's.
Sometimes, trying to be extra fancy, has some negatives.
Old 03-29-2013, 11:07 PM   #171
dznf0g's Avatar
Oswego , Illinois
Probably only about 5000. I did run a van with conventional bearing set for about 50,000 with them. The theory is the same regardless of bearing set design. IMO.
-Rich-
Old 03-29-2013, 11:11 PM   #172
Jim Clark's Avatar
Thanks Rich,
That calms my fears, first hand experience trumps guess work. I will do the annual endplay test which is no big deal.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 03-30-2013, 12:41 AM   #173
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
It seems that Centramatics and Nev-R-Lube bearing do not mix. The Nev-R-Lube bearings require a 0 offset wheel, adding the Centramatics changes the 0 offset. This was information was published in the Blue Beret from what I read. I found information on failures which was caused by a manufacture using 10 mm offset wheels, much more of an offset than a Centramatic would cause. A couple of threads are active on the subject. This pains me as I have a new set of Centramatics on my trailer which have not turned one revolution.
Gene do you happen to have Nev-R-Lube bearings? I really don't want to remove my Centramatics.
Hi, the mounting plates on Centramatics [sheet metal] are probably between .020" to .060" thick [just guessing, I haven't actually measured them, and won't] this amount of off-set is basically nothing.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-30-2013, 06:51 AM   #174
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I put centramatics on our trailer upon delivery in May of 2010. I also installed a hub-odometer.
35,000 miles, one set of seperated Marathons replaced, no blow outs, all the cabinets still on the walls, the door still shuts, no loose lug nuts, and a happy customer.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 03-30-2013, 10:44 AM   #175
Jim Clark's Avatar
Regards,
JD
JD, thanks for the information, tell me more about the Hub-Odometer.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 03-30-2013, 10:46 AM   #176
Jim Clark's Avatar
Andy thanks the makes sense. If they are that delicate I don't know how they can be used in the real world.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 03-30-2013, 11:26 AM   #177
dznf0g's Avatar
Oswego , Illinois
They aren't delicate. They have been in cars and SUVs for several decades.
-Rich-
Old 03-30-2013, 11:58 AM   #178
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Jim,
I do not have never lub. They came sometime after 2008.
We've used Centramatics for at least 30,000 miles.
I haven't looked at the thickness for quite a while, but I think they have to be somewhat less than 1/8". The offset, something I never thought about regarding Centramatics, is a valid concern. But there have been no problems with ours.
I have read posts from people who bought wheels that had another offset despite being warned against it. I haven't seen any problems posted about that, but contrary to what some may think, I don't read every thread.
Gene
Old 03-30-2013, 12:11 PM   #179
Jim Clark's Avatar
Thanks Gene.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 03-30-2013, 12:11 PM   #180
Originally Posted by Gene View Post
Jim,
Gene
Gene.
I just measure one of the plates.
With the paint removed, the thickness is .050 inches. (50 thousands)
If that messes up the Nevr lubes, then "holy cow".
Old 03-30-2013, 01:26 PM   #181
Gene's Avatar
Gene.
Or, 1/20". A lot less than 1/8" as I suspected, but don't trust my memory anymore.
Gene
Old 03-31-2013, 07:06 PM   #182
jdalrymple's Avatar
Jay , Oklahoma
This model comes with a threaded stud mounted on the back. 5/16, as I remember.
I simply drilled a hole in the center cap and mounted it.
It is kinda handy, no more estimating mileage for service intervals.
Regards,
JD
Jeff & Cindy
'91 350 LE MH
Motorhome Archives Update ViewRVs Airstream Motorhome Forums 15 09-06-2006 07:58 PM
Water pump recycling update.... Guitars Water Heaters, Filters & Pumps 6 11-27-2002 08:33 AM
RDM update from Myrtle Beach rdm General Motorhome Topics 0 11-18-2002 08:32 PM
New Owner-tow vehicle discussions JodynJeep Our Community 28 10-15-2002 11:43 PM
