Old 09-28-2012, 09:14 AM   #141
Originally Posted by ZoominC6 View Post
Sure you can. If your wheels are spoked aluminum you won't be able to see through them as the metal pan of the Centramatics blocks the view. One cool modification is to take the Centramatics off, clean them with a good solvent or denatured alcohol and then paint them flat black with a heat resistant type paint or epoxy. The spokes of your wheels will show much better. Good luck and happy trails.
The "specials" that we have made, are indeed painted "flat black".
In that way, they do not distract the looks of the mag wheels.
Old 09-29-2012, 07:41 AM   #142
airperson
2006 25' Classic
Ft Worth , Texas
Thanks ZoominC6 I will check it out today.
Airperson is offline   Reply With Quote
Old 09-29-2012, 02:48 PM   #143
1981 31' Excella II
New Market , Alabama
Ok here is the assembly with all the pieces there. As you can see it fits.
http://www.motorcycleproducts.org/AS...r-assembly.pdf
Perry
perryg114 is online now   Reply With Quote
Old 09-29-2012, 07:47 PM   #144
airperson
2006 25' Classic
Ft Worth , Texas
zoominC6 I checked it out and I have them. Thanks again for the information. Airperson
Old 10-01-2012, 09:20 PM   #145
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I just checked the Centramatics that I bought recently direct from centramatic. The face that you see through the wheels is finshed in a black wrinkle finish.
Ken
Old 10-02-2012, 05:18 AM   #146
ZoominC6's Avatar
2004 30' Classic Slideout
College Town USA , Virginia
It's great that Centramatics now pre-finishes the units in black as I would imagine their finish would be much more durable than our homemade solution.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 10-02-2012, 06:19 AM   #147
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I have Centramatic balancers on my pickup truck and recently I had to have them warrantied. The Centramatic folks do back up their warranty which is good.
The truck seemed to be having an annoying vibration while out on the highway at speeds over 60 mph and was really bad around 70 mph. On a hunch I took off the Centramatics and found that on 3 of them the balancing material inside the ring did not make any noise. The truck drove very smoothly thereafter. I have the new warrantied balancers but I have not installed them yet. After talking to the Centramatic folks I don't think this is a very common problem. I think there was a time several years ago when the sealer they used went bad. Apparently they have changed sealers since then.
Something to think about anytime you have a tire dismounted is to make sure the Centramatics make the proper "noise" when you spin the hub.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 10-02-2012, 06:21 AM   #148
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Thanks for posting this, Steve. Will make sure I hear the "swishing" sound next time I spin a wheel!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 10-02-2012, 09:40 AM   #149
ZoominC6's Avatar
No kidding. Thanks Steve! I purchased ours back in '05 or '06 so will check that out as well.
Old 10-02-2012, 02:34 PM   #150
dznf0g's Avatar
Oswego , Illinois
Steve, could you see evidence that the oil had all leaked out. I have heard of that in a few cases before.
-Rich-
Old 12-10-2012, 05:34 PM   #151
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Will they fit the Dexter axle with drum brakes? A friend has a 6-lug Dexter axle...
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 12-10-2012, 05:39 PM   #152
Fitting the drum, is not the issue.
Yes, they will fit.
BUT.....the shape of the back side of the wheel, can cause a problem.
The back side of the wheel, must have a minimum of a 10 inch flat circle.
If it does, as all the steel wheels do, then no problem.
If the trailer has Mag wheels, then the back side must be checked.
Old 12-10-2012, 05:41 PM   #153
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Joshua Texas? Jeeze!!!! You are about 20 miles from the factory store. Call 'em....ask 'em....go over there! They install for free.
Old 03-29-2013, 02:53 PM   #154
dsrtgrls's Avatar
2010 19' Flying Cloud
Clarkdale , Arizona
i just had new tires installed at discount tire. i had wanted them to put on the centramatics i had bought for my bambi bu the manager shared that 1. with properly road force balanced tires they should not be needed. 2.that there was concern about the centramatic plate against the wheel and that particles could get between and possibly cause the lugs to need to be torqued every hundred miles. the the aluminum wheels were made to fit directly against the thing (drum?) with nothing in between no matter how thin for the ultimate fit and functioning. i got scared of course and deferred the installation until i could get some feed back on these thoughts. i have not heard responses by folks saying that the lugs were loosening in such a frequent way. the discount tire manager just was not feeling in was a wise thing. i can have them put on when i finally go to have the axle serviced. i know i can be a scaredy cat but is what this manager says correct? any help welcome.
"Open paddock 9!"
dsrtgrls is offline   Reply With Quote
Motorhome Archives Update ViewRVs Airstream Motorhome Forums 15 09-06-2006 06:58 PM
Water pump recycling update.... Guitars Water Heaters, Filters & Pumps 6 11-27-2002 07:33 AM
RDM update from Myrtle Beach rdm General Motorhome Topics 0 11-18-2002 07:32 PM
New Owner-tow vehicle discussions JodynJeep Our Community 28 10-15-2002 10:43 PM
