Old 09-01-2008, 07:26 PM   #1
Benjo's Avatar
1949 18' Trailwind
Huntsville , Alabama
Carlisle Tires for 49 trailwind
Hey there-
I have a 18 ft 49 trailwind. I am having a new frame built for it to replace the pipe frame. I have 3 Carlisle tires that I have stored inside that i would like to use on the trailer. here are the specs: ST205/75 R14 Tread 2 poly + 2 steel Sidewall 2 poly. Max load 1760 lbs Load range C. So after the new frame is on I think the total weight of the carriage will be less than 2000 lbs. I am looking for opinions on these tires. My confidence has been shaken a little based on what I have read on the threads. Seems like people have had more bad experiences than good. Any thoughts from the Airstream community?
Thanks!
Benjo is offline   Reply With Quote
Old 09-01-2008, 08:47 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The question is how old are these tires? Even unused tires age. From the little I know if they are more than 5 years old there may be structural deterioration you can't see.
Old 09-01-2008, 09:53 PM   #3
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
You might have them mounted at a reputable tire shop then inspect them.
mustang is offline   Reply With Quote
Old 09-01-2008, 09:54 PM   #4
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
If there is a belt rpoblem they wont balance. Also I know there is moreload on single axle wheels. If questionable maybe peace of mind in new tires?
Old 09-03-2008, 07:45 AM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
As indicated above there is a date code stamped into the side wall. It gives the week and year the tires were manufactured. I would be more concerned about how old and proper inflation than brand.
>>>>>>>>>>>>Action
Old 09-04-2008, 09:20 AM   #6
Benjo's Avatar
1949 18' Trailwind
i checked the tires today and they are stamped with 2004. I rode them from LA through the southwestern states to MN (couple thousand miles or so) with no problems. I have had them stored since then. Agreed age and tire pressure are key ( i work in bike shop and see people with under inflated tires everyday). I may run them this fall to see how they do. Just hate to toss out tires that might still have some life in them.
Old 09-04-2008, 10:43 AM   #7
nypatnva's Avatar
1965 22' Safari
Amelia Ct Hse , Virginia
I had my Carlisles replaced last year and they looked brand new but I felt it was time. The old one(s) I ran for seven years. I use one of the old ones for a spare.
nypatnva is offline   Reply With Quote
Old 09-05-2008, 08:00 AM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
4 year old tires are not used up in my opinion. However there isn't much left. I keep my tires at max. Just watch them well. And stay away from road hazards as best as possible.
>>>>>>>>>>>>Action
Old 09-05-2008, 08:23 AM   #9
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
You just spent money on a new frame and now you're talking about saving maybe $200?
For piece of mind and safety buy two tires
'77 Sovereign Intl 31' CB
Old 09-05-2008, 03:35 PM   #10
Benjo's Avatar
1949 18' Trailwind
Waste not, want not is my motto bob. I like to utilize my resources to their fullest potential instead of taking part in a throw away culture. Stewardship, man. Thanks though.
Old 09-05-2008, 06:31 PM   #11
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Just don't waste the trailer with marginal tires.
I am not so convinced the brand has much to do with tire issues. And that was your original question. You said your confidence was shaken (My confidence has been shaken a little)
Usage and care have a lot to do with how well the tires preform.
Don't over load them. ~ 2000 #'s on 3520 load rating of the tires isn't
Don't over drive them. (Keep the speed less than 65)
Keep them clean and aired up. At least 90% of max pressure.
Stay away from road hazards.
With those guidelines you could get some more usage. It isn't the thread depth that makes the service life on these tires. Because the actual road miles on trailer tires gets no where near the road miles on your daily driver. Most people will drive a 40,000 mile passenger car tire for 4 years and replace because the tread depth is < 2/32". The structure of the rest of the tire may be OK, it is just worn out. Your trailer is not seeing that kind mileage so the tire will end it's life with lots of tread. Hopefully not on the trailer.
>>>>>>>>>>>>Action
Old 09-05-2008, 08:45 PM   #12
Benjo's Avatar
1949 18' Trailwind
That's some good info on caring for tires so they last. I have been a firm believer in tire care ever since I blew a worn tire on a 15 passenger van packed with friends ten or so years ago. From then on I have taken my trailer tires off in the winter and stored them instead of leaving them out in the weather to dry rot etc. I am always checking pressure and examining the side walls and tread. I guess that's where the rubber meets the road. B
Old 09-05-2008, 08:52 PM   #13
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
I say why take a chance, spend a little worry less. If you are not comfortable buy new tires.
63silver
63Silver is offline   Reply With Quote
Old 09-10-2008, 07:47 PM   #14
Benjo's Avatar
1949 18' Trailwind
Straight for the horses mouth
Ok folks, I called up the tire shop chain that I purchased my tires and rims from and this is what they told me. They have had nothing but problems from the Carlisle tires. Whether they are brand new or five years old. Apparently, the tire chain complained to Carlisle and encouraged them to do a recall on them but it was denied. They don't carry them anymore and discourage anyone from using them. He said that nine times out of ten the tires tread just came of the wheel resulting in damage to the trailer. Case closed. Thanks!
Ordering 5 Carlisle Tires and Wheels OK? Zstream Wheels, Hubs & Bearings 1 08-15-2008 03:46 PM
'48 Trailwind Benjo Trailwind 7 07-28-2008 04:39 PM
Carlisle Tires DKDarrow Tires 41 07-07-2008 01:48 PM
Carlisle or Greenball Tires Aluminati Tires 18 10-27-2007 10:14 AM
Carlisle tires??? metalhead Tires 3 08-02-2007 03:45 PM
