Old 06-21-2011, 07:06 AM   #15
calivw78's Avatar
1969 31' Sovereign
Larkspur , Colorado
We bought our Airstream with one tire that was shot. We just put a Carlisle tire on it and have had no issues. But.... then I ran across this thread which has quite a few reviews over the past years. I need to replace the other three tires, but definitely want to figure out if there are better alternatives. Did something change in Carlisle's manufacturing that has reduced the issues recently?
Carlisle Radial ST Utility Tire Reviews. Buying Guides & Consumer Product Reviews - Epinions.com
1969 Sovereign Restoration Project
http://airstream.calivw78.com
calivw78 is offline   Reply With Quote
Old 06-21-2011, 08:42 AM   #16
2004 30' Classic Slideout
Kerrville , Texas
I just recovered from a very expensive Carlisle tread separation. I replaced all four tires on my 30' s/o with load range E Carlisle. All four failed with separation, last one did the most damage. I had one left of the four and it had a bulge and the dealer said it was ready to fail. Went thru the ropes with Carlisle and they just told me the tires were out of warranty after two years. Discount tire replaced all four with same brand but I am going to go with the 16" truck tire next.
Richg
richg is offline   Reply With Quote
Old 06-21-2011, 08:48 AM   #17
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
After my GYM blew up on my Safari I put on Carlisle from Discount Tire. They are load range E and i run them at 70 lbs. No problems with about 4000 miles. If you look over the tire threads you will find that many of the GYM troubles happened with American made also.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 06-25-2011, 03:20 AM   #18
calivw78's Avatar
1969 31' Sovereign
Larkspur , Colorado
Looks like Carlisle has announced improved manufacturing to their radial trailer tire product this month, and we'll probably be rolling these for this season.
Long winded version of this at Carlisle Radial Trail RH tires on an Airstream trailer
Old 06-28-2011, 07:36 AM   #19
Just had a blowout with a 3 year old Carlise load range E 225 75 15 ST tire on a 6000 gvw 25 Safari.
The trip was from Tucson to Colorado and I aired up the tires to 75 pounds before the trip.
It was 100 + degrees all the way from Tucson to Santa Fe where we overnighted.
The next day the tire blew a few miles north of Espanola.
I travel in hot weather and have had many blowouts of ST tires of various makes.
I am shopping for LT tires. You will have tire trouble with ST tires in hot weather.
handn is offline   Reply With Quote
Old 06-28-2011, 01:18 PM   #20
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Interesting.. Pump 'em up, blow ;em out...
Noticed post above and recalled only blowout we've experienced was on trip where I incresed tire pressure to max cold number on warm weekend as well.. We normally run our Carlisle's at 56 pounds (we tow below max GVWR with empty tanks and low fresh water tank..).
Just wondered if anyone else has experienced blowout after pumping up tires (presumably LT's). I felt after failure that tire carcass had set with pressures in mid-50's, and bump to 65 psi may have been partial cause of failure..
I do temp checks of wheels, brake drums, sidewalls after travel, and ours run cool (relative to ambient) at those pressures. With 4 tires carrying load of ~ 1600# each, they are not really straining.
Condoluminum
Condoluminum is offline   Reply With Quote
Old 06-28-2011, 02:09 PM   #21
1967 22' Safari
South East Idaho , South East Idaho
There are better brands out there. "you get what you pay for"
Grad67 is offline   Reply With Quote
Old 06-28-2011, 02:20 PM   #22
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I just replaced my rims and tires with the 16 225 LT Michelins. HINT: If you're anywhere near to the factory do it there, it's cheaper. As it was, I spent quite a bit more AND had to take off the old rim/tires and put the new ones on by myself. I did impress quite a few men in the campground by doing it, but talk about walking like a woman and smelling like a GOAT, whew!
I recently completed a 4000+ mile round trip from Virginia Beach to San Antonio and back - right after I'd replaced the old Marathons which had tread, but sidewall separation from sun damage.
In spite of the 100+ heat for most of the trip, the new tires and rims performed beautifully. I spent quite a bit of time OFF the major interstates, but could run with the big dogs on I-40 when I had to.
Really could feel the difference, but I also added centramatics so?
Going to Montreal in September. (Give a woman tires that will do 70 mph safely and she turns into Travelling Tilly.
Paula
Old 06-28-2011, 02:20 PM   #23
txairlover's Avatar
2007 25' Safari FB SE
Woodbury , Minnesota
I just put 4 new load range E RH's on my 25' Safari for a trip out to Cali and back (3000+ miles)...traveled thru New Mexico and Arizona in 109-110 degree full sun...traveling 7-8 hours per day...tires performed well (they stayed at consistent pressures and ran cooler than the GYM's I replaced). I guess the proof of quality will come with time;-) Plan on another 3200 mile trip in about 3 1/2 weeks up to Wisconsin...will let you all know how it goes.
Paul
txairlover is offline   Reply With Quote
Old 06-28-2011, 02:21 PM   #24
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
I would be leary of any tire running at cold max temps in extreme heat conditions. The blacktop on a 100 degree day can be pushing 130 degrees surface temp or more. The tire pressures could well exceed cold max pressures and stress the tire beyond its limits. When im running in those temps I usually back the pressures down to 70 psi(assuming we are still talking about E rated tires) and give my self some wiggle room.
Just my opinion anyways..
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 07-01-2011, 07:50 AM   #25
1977 Argosy 24
Milltown , Wisconsin
The trick is you have to ask for Carlisle USA Trail ST tires. Most Carlisle tires are made overseas except for the USA Trail tires, which are trailer only tires. I found this online and none of the tire dealers that I called knew about this. I got them mounted last night and stamped in the side-wall is MADE IN USA.
ventport is offline   Reply With Quote
Old 07-03-2011, 07:04 PM   #26
2010 27' FB Classic
N/A , Texas
Don't know what RH's are. Please decode for me.
Thanks!
Old 07-03-2011, 08:06 PM   #27
r carl's Avatar
Lin , Ne
Hmmmm, they must have raised the minimum age of their workers from 12 to 14.........
Old 07-03-2011, 08:08 PM   #28
1988 25' Excella
Images: 13
RH is simply the model of Carlisle tires....
Condoluminum
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
White letter tires on Airstream Road Ruler Tires 2 03-09-2011 07:14 PM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
