Old 12-27-2006, 02:35 PM   #15
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Steel valve stems
Originally Posted by bertro
I removed my new st tires and went back to the 7.00x15LT bias 8 ply.I stayed w/carlisle and added steel high pressure valve stems....I seen a down load that told AS weights by year and model.And I cant find it now,does anyone Know. Thanks again Robert
Bertro,
Goodyear makes a big deal out of the importance of steel valve stems with tires rated 50psi and above. Seems like cheap insurance to specify this when you have new tires mounted.
I have the AS weights in PDF at home but still no internet connection following the big NW windstorm the week prior to Xmas. I can't remember which site has it posted but if no one comes up with the answer I think a google search with terms: vintage Airstream GVWR will turn it up.
What size load bars are you using with the CAT. Getting that matched properly with your HD suspension is critical to good towing performance
-Bernie
bhayden is offline   Reply With Quote
Old 12-27-2006, 02:57 PM   #16
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Go to Airstream, Inc. :: Travel in Style and click on Search. Type in faq trailer weights in the search window. It will take you to a list of the amswers tp frequently asked questions. Click on trailer weights and it will take you to the trailer weights.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-27-2006, 03:14 PM   #17
1976 25' Caravanner
Campton , New Hampshire
Bertro
I printed out that weight chart but cannot tell you where it came from . '71 23' twin =3530# with 440# tongue wt.----23' dbl =3680# with445# tongue wt. , these are dry weight.
On the tire issue I have been using BF Goodrich T/A commercials in the 15" size . There are 2 in that size , 1 allweather tread and 1 winter tread . The allweather tread has a P designation + XL(extra load) , the winter tread has an LT designation , both specs are the same , basically C rated , which was original equipment on my '76 25 footer. One pair that I replaced had approx. 15000 mi on them . They were replaced because I discovered they were 18 years old . There was not a single sign of deteriation in the tread or sidewalls . I kept the tires in hopes of finding someplace to have them tested , I'm still not convinced that tires are only good for 3 or 4 years . Good luck with whatever choice you make .
ticki2 is offline   Reply With Quote
Old 12-27-2006, 03:18 PM   #18
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Here is a link right to the chart!
http://www.airstream.com/airstream/p.../weights-1.pdf
Richard
Old 12-27-2006, 03:25 PM   #19
bhayden's Avatar
1978 24' Argosy 24
Ticki2,
Where did you find the T/A Commercial radials in a 15" size and what aspect ratio?
Old 12-27-2006, 03:31 PM   #20
1976 25' Caravanner
Originally Posted by bhayden
Ticki2,
I bought mine thru Sams Club , but any BF Goodrich dealer can get them . They are 235/75/15 XL, and had no clearance problems.
Old 12-27-2006, 07:07 PM   #21
1960 24' Tradewind
santa barbara , California
Ive used the BFG all terraine T/A on the travelall for years ,a great off/on
road tire .They have 3 ply sidewalls ,where most radials have only two .Many
in the SB 4 wheel drive club ran these tires and they all were pleased with
how tough they were.These of course are not trailer tires but its good to see
that the BFG tires are working great on the trailers as well .BF Goodrich has
many excellent tire offerings .One all time favorite for years in the car /truck
hot rod community was the BFGoodrich radial T/A ,awesome performer for
years .Ive installed BFGs on most all my cars including the 95 impala ,but those are factory installed comp T/A tires .
Scott
scottanlily is offline   Reply With Quote
Old 12-27-2006, 07:59 PM   #22
sierrajb's Avatar
Arlington , Texas
You're Scaring Me, Now!
I, too, read every post about tires in this forum in addition to talking to unbiased (pun intended) tire specialist. Everyone says about the same thing: Proper tire maintenance and driving safety seems to be key with any brand of tire.
I just purchased a set of 4 Carlisles (Load D) for my Argosy 24. Research shows to be more than enough. I will see if my fears are warranted, as well as the tires.
Airstreams are like a box of chocolates....
sierrajb is offline   Reply With Quote
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Flat tire detector Pahaska Tires 6 08-08-2002 06:38 PM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
