Old 08-13-2007, 10:08 AM   #1
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Canadian Tire's $129 Tire Pressure Monitoring System
Has anyone tried this tire pressure monitoring system from Canadian Tire. It seems to provide everything someone with 2-4 tires on their AS would want. Price is only $129 CDN$ this week.
Canadian Tire
Any comments would be appreciated.
SilverCottage is offline   Reply With Quote
Old 08-13-2007, 10:28 AM   #2
cameront120's Avatar
1972 25' Tradewind
I've only seen their commercial for it. I'll be curious to hear any real life reviews of the product.
North Vancouver, BC
Old 08-13-2007, 10:54 AM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I bought it and tried it out this week on my truck. It works pretty good. It gives a constant readout of of tire pressure moving from tire to tire. If the pressure goes up or down a set precentage it shows a problem with that tire. If it has a rapid decrease in a tire it sounds an alarm and flashes a red light.
I called the company and they say it will read from 30 meters. I haven't taken the trailer out with it but it does read the pressure on the trailer tires.
The kit comes with locks to keep the sender on the valves and with weights to stick on to counter balance the sender. I used it on the truck without the weights and didn't notice any balance problem.
It was interesting seeing the change in pressure as we travelled. The pressure rose as the speed increased and fell overnight as the tires cooled.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 08-13-2007, 11:59 AM   #4
Road Ruler's Avatar
Images: 38
Thnxs Doug for giving us the low down. I too saw them advertised this week in the CDN tire flyer and thought they would be a good idea.
I guess there are 4 sensors and 1 moitoring panel per pkg???
Old 08-13-2007, 02:43 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
That's right Wayne, 4 screw on the valve stems sensors, and the monitor that plugs into the lighter socket. If you only have a single axel trailer, you could put two on the trailer and two on the back tires of the truck.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Old 08-13-2007, 02:49 PM   #6
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Country of origin
Please tell me this product is made in The Great White North!
Not the other place that starts with a C.
Looks like a good value, transfer from one trailer to another easily.
I'm likin it so far. Is that Canadiaen dollars or US ?
Thanks DG
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 08-13-2007, 06:34 PM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
That's Canadian dollars for a Chinese product. Where else?
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Old 10-30-2007, 07:14 PM   #8
fred bartlet's Avatar
2001 31' Excella
Bluffton , South Carolina
Hi, I looked at the web-site and they only deliver to Canadian addresses. How would a state side AS get some of these units?
Fred Bartlett
30' S/O 01 Excella, maple floors in Galley, HA Hitch, Hyd. Disc Brakes, P3 Controller, SS Kit. Bk Splash, LED RL's, 2K/Tri Fuel Gen's & RV on TT
04 Chevy HD, CC, D/A, Curt Magnum V Rec., Full Amsoil Syn.,Dual Filters, ARE, MX Topper with lift Gate Door, Bed Rug, TPS & Bk.up Camera.
fred bartlet is offline   Reply With Quote
Old 10-30-2007, 07:46 PM   #9
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Don't bother trying to get this. I took mine back for a refund as it only works for about an hour then goes all out of wack. Others, I know, have had the same problem.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Old 10-30-2007, 07:55 PM   #10
Road Ruler's Avatar
Images: 38
Thnxs for the update Doug. Seems like a good idea. Maybe they need to perfect the technology or improve quality control with the product.
Tire covers Andy Fay Tires 1 11-16-2002 06:03 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
What tires to replace with? Charcigar Tires 1 04-09-2002 01:08 PM
