Old 02-23-2019, 12:52 PM   #1
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
Can I get away with changing two tires at a time?
I'm going to replace the old tires on my 25'EB. I'm not going to take my AS to a tire shop because there are none around that provide easy enough access, and that I trust to use the correct jack points. Instead I'm going to take the wheels one or two at a time.
Question: Can I remove both tires on a side at the same time, relying on a jack and blocks to keep the trailer jacked up?
As you can tell from my question, I haven't done this before so any advice will be appreciated.
brad1 is offline   Reply With Quote
Old 02-23-2019, 02:10 PM   #2
1986 31' Sovereign
Miami , Florida
You could. When I did it, I did one axle at a time using my bottle jack and jack stands. That way, should the trailer roll off the jacks stands for some bizarre reason, it is still supported on both sides.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 02-23-2019, 02:17 PM   #3
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
another way is to use leveling blocks on each side. Roll up on the blocks and remove a tire from each side. Repeat for the remaining 2 tires.
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Don’t Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Old 02-23-2019, 02:24 PM   #4
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Just block the axles and take all 4 tires. Wooden blocks under the axle mounting points will be fine to support the trailer while you get the tires swapped out.
Dept of “OverKill”
GMFL is online now   Reply With Quote
Old 02-23-2019, 02:59 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I always do a side at a time with a floor jack and a couple of jack stands. I put the floor jack between the wheels and lift on the axle mounting plate.
Richard
azflycaster is online now   Reply With Quote
Old 02-23-2019, 03:29 PM   #6
2019 30' International
Pennsylvania , Pennsylvania
A couple months back I had metal valve stems installed. I just ran the front wheels up on leveling blocks high enough to take off the rears, took them to the tire shop, came back to my garage, re-installed, then ran the rear wheels up on the leveling blocks, and did the fronts.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 02-23-2019, 03:57 PM   #7
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
I used a trailer aid plus:
https://www.amazon.com/Trailer-Aid-T...iler+aid&psc=1
and involved the spare so that I could take in two wheels at a time. I also took the spare in by itself first, because I also wanted a new spare.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 02-23-2019, 04:09 PM   #8
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Jack one side and block, jack the other side and block, take all four at once.
This always wants to be done on a fairly level parking area.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 02-24-2019, 10:03 AM   #9
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
On a dual axel, you don't need jacks. Drive up on leveling blocks or 2x8's with either front or back tires, leaving the other set "hanging." Make sure to place chocks on either side of the wheels supporting your trailer and put your stabilizers down. Now you can remove the "hanging" tires from either side. After taking old tires in for replacement, repeat process for two remaining tires.
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 02-24-2019, 10:06 AM   #10
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
I changed all four at once last year. Lower the tongue jack all the way. Put jack stands under both jack points. Raise tongue jack until all four wheels come off the ground. DO NOT OPEN THE MAIN DOOR WITH EITHER JUST THE CURBSIDE WHEELS OFF THE GROUND USING THE JACK POINT OR WITH ALL FOUR. IT WON'T CLOSE AGAIN UNTIL THE TRAILER IS BACK ON THE TIRES. Using the 'blocks on axle mount points' method should avoid that problem but requires more tools and hardware.
FWIW, I ugraded from the MS2's to XPS Ribs at Michelin's suggestion. For $20 more per tire it has been well worth it. Gas mileage while towing improved 5-10%. While you are at it, check your shocks (you may be missing a mounting bolt or two). If they are original I'd just plan to replace them. If you upgrade to steel valve stems, make sure they are the type that uses a retaining nut inside the rim. Might as well check the brakes while you have all the wheels off too.
GammaDog is offline   Reply With Quote
Old 02-24-2019, 11:38 AM   #11
AlinCal's Avatar
1991 25' Excella
The main problem with doing half a set per trip to the tire shop is you use twice as much gasoline.
Do not lower your stabilizer jacks expecting anything other than the possiblity of making pretzels out of them.
Use real jack stands rated for the job.
Will Rogers
Alan
Old 02-24-2019, 03:53 PM   #12
Would you provide the weight capacity of the jack stands you used?
Also, did you put any blocking under the jack point, between the jack and the jack point?
thanks.
Old 02-24-2019, 04:15 PM   #13
AlinCal's Avatar
1991 25' Excella
Not sure that's the best treatment for the tongue jack, is it rated to lift that much? Raising the tongue while the wheels are on the ground is one thing, raising most of the weight of the trailer off the ground is another.
Will Rogers
Alan
Old 02-24-2019, 05:29 PM   #14
Mollysdad's Avatar
I didn't use the jack points <gasp>.
There're not as convenient as they seem, first you need to lay under the trailer, and then Airstream may have run water or gas lines right through that area. IF I used the jack points, yes, I'd put a block of wood on the jack.
I raised one side using a floor jack on the vertical axle mounting plate in front of the front tire, then inserted a jack stand behind the rear wheel. I didn't use the obvious place between the tires because on the curb side the plastic low water drain is asking to be broken off.
I took both left sides off, then both right sides later. There's a lot of ways to do it and they all work.
Two tire changing questions StreaminGeo Tires 27 07-05-2016 04:29 PM
Did changing to two 6 volt Batts. affect ride grizbear Towing, Tow Vehicles & Hitches 5 02-26-2015 11:24 AM
Getting 1 solar panel, should I just get 2 right away? JustSomeGuy Generators & Solar Power 24 01-28-2014 08:22 PM
From Spokane, need to get away! 76gmcCamper On The Road... 2 06-23-2012 12:59 PM
5-day so-cal get-away tvoneicken On The Road... 5 10-23-2011 10:46 AM
