Old 07-31-2007, 11:11 AM   #1
jerome , Michigan
C or D range tires?
Opinions? 1970 Ambassador. Load range C or D tires?
metalhead is offline   Reply With Quote
Old 07-31-2007, 11:21 AM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
I'd say D, or even E.
tphan is offline   Reply With Quote
Old 07-31-2007, 12:04 PM   #3
1984 31' Excella
Norfolk , Virginia
Images: 11
C or D
What is the Gross weight(max weight)?
Reguardless of which type or size of tire you go with I recommend you also purchase a tire pressure monitering system.
You can't feel when a tire is comming apart much less when the pressure is dropping.
Beginner
Beginner is offline   Reply With Quote
Old 07-31-2007, 01:20 PM   #4
1992 34' Limited
Falls Church , Virginia
TV or trialer?
Metalhead -
Guessing you are asking for trailer tires, right? TV tires would be a seperate and likely different answer....
Get a gross weight for your trailer, add your gear weight, fluids, propane, and etc.... Then add in a safety margin..... See what you come up with, buy tires that will handle your weight, and you'll be a 'happy camper'...
On the TV tire question, that is a far more involved answer....
Hope that helps.
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 07-31-2007, 01:31 PM   #5
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
Good Advice...
Originally Posted by SilverToy
Metalhead -
Hope that helps.
Axel
SilverToy
mr toy,
excellent advice, and i'm going ot take it.
i'm the guy you always see along the hwy w/ a blowout; but by golly i got the best deal on the planet on my Zody's load range A super duper RV retreads, and my spare is always flat, or i forget it at my other brothers house.
kevin
Kevbo10 is offline   Reply With Quote
Old 08-01-2007, 10:40 PM   #6
1992 34' Limited
Not "THE" Kevbo.... no...!
Kevin -
You, from the land of Uber-woodpiles.... travel with enough juice, between the 2 Honda's, the AGM batteries, the Cowboy Beer and the Hemi (outta OD of course) to run AT LEAST a small compressor (its GOTTA be under the CornHole game, somewhere....) so that you can get those retreads rollin again.
I done tol'd youse bout gettin dem cheap retreads.... always go to Lefty's Tire Extravaganza and Pawn, for the bes't off brand 2nd's - from Ecuador maybe.... They'se jus run a 'little' hotter... if'n youse get it outta the ditch ok.... Oh, and 'balancing' is really over rated! Why balance it if its only gonna go 10 miles max!?
Oh, and the rug really DID tie the room together....
Ciao my friend! Everyone else too!
Axel
SilverToy
Old 08-02-2007, 05:33 AM   #7
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
From the 1970 catalog ....
Here are facts instead of opinion:
"... 700 X 15 Truck-type extra strength wheels with nylon tubeless tires (6 ply on 18 foot Caravel and 21 foot Globe Trotter; 8 ply on 23 foot Safari; 6 ply on all tandem models)"
In the 1950s and 60s, the tandem axle trailers used tires with one less ply (or ply rating) than used on the largest single tire trailer. Hope this helps.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 08-02-2007, 05:46 AM   #8
1976 25' Caravanner
Campton , New Hampshire
Specs for '76 were , all tandem axle units came with load range C , all single axle units came with load range D. Now if you like to read , hit the search tab and type in tires .
ticki2 is offline   Reply With Quote
Old 08-02-2007, 06:44 AM   #9
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
I had also read that tandem tires should be "C". My question is what would it matter if you put "D" on a tandem?
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 08-02-2007, 09:48 AM   #10
47WeeWind's Avatar
1948 16' Wee Wind
Denver , Colorado
Images: 20
Hi Yuki:
In my opinion, I don't think it matters greatly if you put Load Range "D" as opposed to LR "C" tires on a vintage tandem axle Airstream. The ride will be slightly harsher, but can be adjusted with lower tire pressure (for those who don't feel obligated to "max out" their tire pressure). I think the LR "C" tires were spec'd for tandem axled trailers because they met the engineering rerquirements at a lower cost than four "D" tires, which would have provided more load carrying headroom than the engineers thought necessary in 1970.
Airstream Life
"From the Archives"
Old 08-02-2007, 10:12 AM   #11
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by Kevbo10
mr toy,
kevin
mr. bo
Wait until I get my hands on you in ABQ (sorta rhymes, no?)........you ain't gonna have no more tire problems ever again when I'm done!!!!!
Old 08-02-2007, 10:16 AM   #12
1976 25' Caravanner
Originally Posted by 47WeeWind
Hi Yuki:
I agree ,with one exception, you will need to determine if the wheels are rated for the higher load and psi rating of the D's. Some wheels will have this stamped on the rim, others not .
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
need advice re. 1969 tires, brakes, etc. Dave Cole Tires 6 01-29-2007 06:04 AM
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
Whitewall Tires 66whitebread Tires 0 09-17-2002 06:29 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
