Old 12-21-2014, 10:26 PM   #15
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Date code on sidewall. Tire Rack site has excellent tech section articles for details.
No Mans Land
Old 12-22-2014, 05:08 AM   #16
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by gcann View Post
How do you determine when the tire was manufactured?
Long version: Barry's Tire Tech
Short version: There is a DOT code on the sidewall. The last 4 digits are the date in a week/week/year/year format.
CapriRacer is online now   Reply With Quote
Old 12-22-2014, 07:56 AM   #17
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
If you have an 8 lug wheel like on a 3/4-1 ton truck, you can add a set of Centramatics and no telling how many miles you could get off of your new Michelins. They don't make them for any 1/2 ton TV's, but they do make them for our Airstreams. I have them on both my TV and my AS.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 12-23-2014, 08:38 AM   #18
1986 32' Excella
Albuquerque , New Mexico
Thanks everyone for info on tires
gcann is offline   Reply With Quote
Old 01-19-2015, 01:24 PM   #19
2010 25' FB Flying Cloud
Davenport , Iowa
OK Guys; Help. Somewhere on this thread, I read where Michelin no longer made a LT truck tire in a 235 75 r 15 xl 108T. I was just at my local DT and they stock this tire. I went ahead and scheduled a set to be installed along with a TPM. These are to be installed on my 2010 FC 25 ft, front bed. The tires are rated at 2138# less 10% or about 1900#. $982.49 inc balance, install, TPM and tax.
Comments, or should I have asked? Still have time to change.
mike
Airtandem is offline   Reply With Quote
Old 01-19-2015, 02:07 PM   #20
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Ideally, 1900-lbs less an additional 15%. Or, 1600-lbs per tire. A 6500-lb trailer IF there are no large imbalances across each axle.
Best to weigh the trailer at each wheel position with full fresh water, full propane and usual camping load. And WDH in tension.
You might find examples of those who claim what you have is fine, but keep in mind this recommendation as it is also with full sidewall marking air pressure.
Brand is right, AFAIK, so do a search on posts by Andrew_T and Michelin.
A reserve capacity is the thing.
Old 01-19-2015, 02:25 PM   #21
Davenport , Iowa
correction: 225 75r 15 Michelin rated at 2138#. Are you saying reduce weight capacity by 25%?
Old 01-19-2015, 02:34 PM   #22
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
De-rate per vehicle use as you did above. Then take 12-15% off of that to maintain adequate reserve capacity is the conservative recommendation. At full pressure.
With less pressure (not recommended) take off even more. Or for higher speeds. Or very hot weather. Etc.
See posts by tire engineers CapriRacer and Tireman9.
Changing from ST isn't straightforward, unfortunately.
See Andys tire recommendation if that is the path you want.
Old 01-19-2015, 03:48 PM   #23
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Using those numbers I've come to the conclusion you can either just get the XL tires or you must upgrade 16's if switching from an ST tire if you're trailer is over 25ft.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 01-22-2015, 08:30 PM   #24
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
maxxis
Have not seen much comment about Maxxis tires. After thinking about changing to 16" wheels to go Michelin LT for load rating, we are looking at Maxxis 225/75R15 as an alternative. It would allow us to stay with the wheels and moon hubcaps we have already, keeping the historic appearance. We would have a TPMS as a tool to try to avoid failures, although nothing stops a sudden blowout. Our rig also has steel skids at present, if those are smart to retain.
Wisdom to share?
Jim +Jane
JRF0st3r is offline   Reply With Quote
Old 01-22-2015, 09:46 PM   #25
Davenport , Iowa
Comments on Carilsle Trailer tires 225 75r 15 E rated?
Old 01-23-2015, 01:09 AM   #26
2005 19' Safari
GLENDALE , AZ
Our experience with tires:
  • Goodyear Marathons (GYM), LR-D ST tires
    April 2005 -- Purchased new 19' Bambi, which came with three GYMs installed.
    July 2008 -- One GYM failed due to blowout and tread separation. When replacing the first GYM, tire tech discovered that the second GYM had radial belt creep (tread still intact, but steel belt created bulge and squiggle in tread). Purchased one new Carlisle LR-E ST tire and continued roadtrip with the third, previously unused, GYM spare and the new Carlisle tire on the ground; and used the second GYM (with belt creep) as a spare.
  • Maxxis, LR-E ST tires
    October 2008 -- Purchased two Maxxis tires. Discarded the second defective GYM, and moved the Carlisle ST tire to the spare tire carrier.
    January 2011 -- One Maxxis tire failed due to radial belt creep; tread remained intact. Discount Tire refunded cost of one Maxxis tire, which was used towards the purchase of 16" wheels and LT tires.
  • Michelin XPS Rib, LR-E LT tires
    January 2011 to date -- Absolutely, no tire problems after switching to XPS Ribs.
Old 01-24-2015, 01:07 AM   #27
2007 22' International CCD
Bump to follow in app
KE4GNK/AE
Old 01-24-2015, 04:47 AM   #28
Gainesville , Florida
ST tires, three years only, according to my tire guy. Jim
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
tires radials or bias ply tires larry b Tires 22 06-27-2010 05:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
