Old 09-16-2008, 05:25 PM   #1
2006 19' International CCD
Philadelphia , Pennsylvania
'bumps' in sidewall - Goodyear Marathon
We just purchased a 2006 19' int'l and noticed today some lumps or bumps or whatever you would like to call them on the sidewall of one tire.
Not sure if this is normal but thought i'd post a pic or two and ask your opinions.
thanks
ericwarren is offline   Reply With Quote
Old 09-16-2008, 05:26 PM   #2
ok..that didnt work...lets see if i can figure out how to post pics
Old 09-16-2008, 05:27 PM   #3
Pics
I think i figured it out!
Old 09-16-2008, 05:36 PM   #4
_
hi eric
BIG thanks for posting photos....
we can't resize or open your pix in a new window, so good resolution is an issue...
the pic on the right looks like a NORMAL belt overlap indentation...
see this thread and the LINKS in my post #9...
http://www.airforums.com/forums/f438...-do-44306.html
your photo on the left looks more troublesome, as a bulge...
u can change tire pressures (go from 30 psi to 70) with the wheel OFF the trailer....
IF the bulge changes with pressure, OR when pressed on with a finger it flattens (fluctuations) ....
THAT IS BAD, get a new tire.
depending on the gy dealer u may have a debate about defect vs damage as the cause...
here are some pics of my factory replaced tire with fluctuant bulges
http://www.airforums.com/forums/show...8&postcount=79
as the tire rack link above shows these bulges are bad, but depressions are ok....
cheers
2air'
Old 09-16-2008, 06:24 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ditto on normal belt overlap. It's hard to make out the photo on the left.
Old 09-16-2008, 06:36 PM   #6
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Eric,
I can't really tell from the fist picture, but it looks like the trailer tire is pretty hard against a wheel chalk. Does the tire exhibit the same bulge in the same place when the tire is not against the wheel chalk???
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-16-2008, 06:39 PM   #7
good question....i don't know. i put the chock in after the trailer was stationary.
i can remove it and check.
would this be a typical cause?
Old 09-16-2008, 06:48 PM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The bulge being from a wheel chock is normal, a bulge there all by itself is a bad thing.
Indents along the sidewall are the areas the steel belts that reinforce the tread area are attached to one another, and is completely normal. Not so a bulge. A bulge in any area of the sidewall of a tire tat has no load on it is at the beginning stage of a belt separation, and eventually could cause the tread to detach from the casing of the tire.
Old 09-16-2008, 06:52 PM   #9
DEITZ645's Avatar
Eric,
Might I suggest removing the chalk. Mark the bulge with masking tape or something, and then move the tailer a little to see if the bulge moves or disappears. You could also jack the trailer up under the axle to see if the bulge disappears with no load on it.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 09-16-2008, 09:09 PM   #10
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
It looks like a bulge on the left pic to me. If so, I believe I would replace ASAP to avoid endangering any precious aluminum. The previous post recommending marking the spot and moving the tire to see what it does seems to be an excellent idea.
94Tri is offline   Reply With Quote
Old 12-10-2008, 06:43 PM   #11
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Great Info
Originally Posted by 2airishuman View Post
hi eric
cheers
2air'
I have the same indents (or undulations) on two of my 2 year old Marathons, and I am happy to learn that such features are normal on radial tires.
Although I am concerned that the indents have appeared only recently and at multiple places around the circumference of the tires.
Worth noting that there is nothing that looks like a blister or bulge on any of the tires.
Interesting that the guy I spoke with at the local Goodyear had no idea what I was talking about.
Thanks for the info.
SRW
SRW is offline   Reply With Quote
Old 12-10-2008, 07:07 PM   #12
azfiredog300's Avatar
Surprise , Arizona
Those indentations are actually caused by damage done to the rubber at the bead while the tire is being put on the rim. Generally nothing to worry about because the bead still holds firmly in place. If the worry is too great usually the dealer will replace due to it being improper mounting practice.
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 12-10-2008, 08:55 PM   #13
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Indentations
Please read this article.
Tire Tech Information - Sidewall Indentations, Undulations and Protrusions
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-10-2008, 10:02 PM   #14
Well Preserved
1993 21' Sovereign
Generally, indents are nothing to worry about, it is where the steel belts are attached to each other. Bulges, on the other hand, could be the beginning of separation. Replacement would be a good idea.
Goodyear Marathon Failures Surman1322 Tires 677 05-03-2011 01:48 AM
Goodyear Marathon tread separation ... and our solution RossFam05BH Tires 226 06-26-2010 10:27 AM
Goodyear Marathon Separation Steve Heywood Tires 5 09-19-2006 12:46 AM
Goodyear Marathon "C" out of production Wabbiteer Tires 13 07-18-2006 04:24 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
