Old 12-11-2008, 12:15 PM   #15
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Originally Posted by azfiredog300 View Post
Those indentations are actually caused by damage done to the rubber at the bead while the tire is being put on the rim. Generally nothing to worry about because the bead still holds firmly in place. If the worry is too great usually the dealer will replace due to it being improper mounting practice.
Your comment puts a different slant on the issue of indents versus the Tire Tech report referenced by other.
The report states "......the overlap where the sidewall cords are lap-spliced may sometimes cause a slight indentation", and offers no reference to improper tire mounting.
I think that I will tow the trailer to a Goodyear store and have them look at the tires.
SRW
SRW is offline   Reply With Quote
Old 12-11-2008, 09:12 PM   #16
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Our Marathons have the same indentations at 2 or 3 points around the tire, and from what I understand (as stated by others here) this is normal thing resulting from the manufacturing process of overlapping belts. When I first noticed them I was concerned, but after researching it, I am no longer worried about them. Bulges, however, are a different story, and the tire should be replaced.
TB & Greg and Abbey Schnauzer
#3954
Goodyear Marathon Failures Surman1322 Tires 677 05-03-2011 01:48 AM
Goodyear Marathon tread separation ... and our solution RossFam05BH Tires 226 06-26-2010 10:27 AM
Goodyear Marathon Separation Steve Heywood Tires 5 09-19-2006 12:46 AM
Goodyear Marathon "C" out of production Wabbiteer Tires 13 07-18-2006 04:24 PM
Goodyear Marathon Source Jabba Tires 28 02-22-2004 11:16 AM
