Old 12-09-2014, 07:42 PM   #1
1995 34' Excella
St. Charles , Missouri
Bought new tires
I pull a 34' excella 1000,1995 with a front Kitchen. I have Maxxis E range tires on triple axles. I wanted to upgrade the range on the tow vehicle from the C range stock tire to D range. Michelin doesn't make an 18" D tire so I ended up with E range tires. The tire store manager said I should run those at 45 pounds, which is what the door sticker says, when I am not towing. He said to run about 60 pounds while towing ( about 9700 to 10000 pounds ). I was under the impression that I should run at the 80 pound rating on the tire all the time. What is right?
Silver_Star is offline   Reply With Quote
Old 12-09-2014, 08:33 PM   #2
SteveH's Avatar
Common Sense , Texas
Not all situations are the same. I have the E range tires on my tow vehicle, and it handles good at 70PSI all the way around. However, the Ram with the Cummins is especially heavy in the front, so your's may respond differently.
Regards,
Steve
Old 12-10-2014, 04:27 AM   #3
"Cloudsplitter"
2003 25' Classic
Thumbs up
Ditto....70psi all around, bump up 3psi in rear when towing.
ROBERT CROSS is online now   Reply With Quote
Old 12-10-2014, 04:35 AM   #4
"Cloudsplitter"
2003 25' Classic
Thumbs up
POI...the rear TV axle is 880lb under it's 5500lb rating when hitched & fully loaded.
Tires...Tires...Tires Bob Thompson Tires 280 11-07-2021 10:46 PM
tires radials or bias ply tires larry b Tires 22 06-27-2010 05:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
