Old 10-06-2017, 01:33 PM   #29
Ravenna , Ohio
Originally Posted by SeaLevel View Post
https://www.tirerack.com/tires/tiret...jsp?techid=219
Keep in mind this was written before the Goodyear Endurance tires were released, and those tires carry a higher "N" (87mph) speed rating. Not that you should ever pull a trailer that fast, but it's good to know they are a better engineered tire than the Marathons.
You do realize that the load formula the tables are based on are based on a 65 mph max speed. DOT does not have a new high speed test for ST tires. In fact ST tires are tested to standards from the 70's while Passenger and LT tires have new tests from 2002.
The SAE speed test is only a 30 minute step speed test. pretty easy to pass. Even many used tires can pass the test.
Since it is the air that supports the load I know of no magic rubber that will allow an ST tire on a trailer to support more load than an LT on a pickup which are both driven on same roads and same speeds.
If in fact it was "better engineering" at GY one has to wonder why first line LT tires don't have the same load rating as the ST tires made by GY.
Retired tire engineer (40 years). Write a blog on RV tires.
Tireman9 is offline   Reply With Quote
Old 10-06-2017, 02:08 PM   #30
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
"If in fact it was "better engineering" at GY one has to wonder why first line LT tires don't have the same load rating as the ST tires made by GY."
Perhaps because they test them to markedly different standards?
Old 10-07-2017, 11:12 AM   #31
Ravenna , Ohio
Originally Posted by lwinkler View Post
This is a blowout near Durango on the way back from Chimney Rock. No place to pull over. Luckily the blowout was on the curbside. Changed tire on the road in 10 minutes - No damage. Heard the blast and saw the puff of black smoke came to an immediate stop. Our traveling companions thought my engine had blown up. We had walkie talkies and were able to control traffic. Carlisle tires.
FYI
What I see in not a "Blowout" AKA Run Low Flex Failure
but is a Belt/Tread separation.
Two different conditions have two different causes. If we don't know the cause of the problem we may not take the proper corrective action.
Another way to think of this would be to say someone is having of a heart attack when in reality it was stroke which is not the same thing and the corrective steps are not the same.
Old 10-07-2017, 07:58 PM   #32
KK4YZ's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
Originally Posted by Tireman9 View Post
FYI
@tireman, what do you see as the most common causes of belt/tread separation, and how would you avoid it?
KK4YZ is offline   Reply With Quote
Old 10-08-2017, 05:10 PM   #33
Ravenna , Ohio
You should have read my post HERE on Why Tires fail.
I wrote this just for this Airstream forum as I am not allowed to post direct links to my RV tire blog that has some 270, company neutral posts on tires and related components.
Sorry but I simply can not re-post all my blog posts. I started to do that on one forum but that ended up getting me banned from an RV forum for offering too much fact based information that didn't support the forum sponsors products.
Old 10-09-2017, 11:04 AM   #34
2007 27' Classic FB
Ridgefield , Washington
Images: 8
Did you ever make it to Portland?
John & Lisa
Woosch is offline   Reply With Quote
Old 10-17-2017, 10:19 AM   #35
Hugh
zapper's Avatar
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland , California
You were lucky. Good to hear you were/are safe. Also appears as though there was no damage. Lucky twice. Endurance GY tire are a new GY product not much feed back on them yet. Hope they are better than the GYM. Luck gets you by only for so long. Good luck.
zapper is offline   Reply With Quote
Old 10-18-2017, 03:59 PM   #36
1996 25' Excella
Port Stanley , Ontario
Why on earth do you want to go 75 mph ?
Aprilrivet is offline   Reply With Quote
Old 10-19-2017, 06:19 AM   #37
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
Tireman so now you have me interested in this pressure thing.
what is main difference between tire pressure on Trailer vs MH when it comes to load weight on tires?? the VIN tag on my unit shows the ST tires at 65 PSI. I run by LT tires at 68 psi according to tire load info at Michelin and the weight of my TT with water in tanks, loaded ready to go camping food and all.etc.
the LT tires show a max of 80 psi which would bang the crap out of every thing in the AS going down the road, especially in SC on I95, such a rough road.
I read post of guy using LT tires going thousands of miles with PSI's at 65 to 70 with no issues they report..
I have read some of your blog post and understand your experience in this field but think that the max psi on trailer tires might need to be reevaluated with all the evidence saying other wise.
thanks for your input on this issue.
Sorry but inflating to the measured load is correct for Motorhomes but not trailers. Trailer tires should be inflated to the psi molded on the tire sidewall. You will also see that number on the trailer certification label. The belt Interply Shear in trailer application is 20 to 24% higher for trailers. Sorry I can't post the pink so you will need to Google "Interply Shear tires" if you want the details.
Having said that the OP picture has some signs of a Run Low Sidewall Flex failure. Would need better & more pictures of the failed tire to confirm. If you lose air it doesn't matter where the tire is made. It will fail.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
Timeshare owner/user since '99
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 10-19-2017, 08:00 AM   #38
CapriRacer
CapriRacer's Avatar
I'm in the , US
Carl,
If you and Roger will allow me to join the conversation:
First, you have to be very careful about nomenclature. I suspect when Roger is talking about inflating trailer tires to the max on the sidewall, he is referring to ST tires, and not LT tires on a trailer.
Ya' see, the way ST tire loads are calculated is different than the way LT tires are calculated. If you do the math, you'll find that an LT tire carries less load for a given pressure than a similarly sized ST tire. So if you are using an LT load table, you are in essence inflating the tire more than a comparable ST tire - and that is what Roger was getting at (I think).
Further, I am of the opinion that the problem with high inflation pressure causing a rough ride in the trailer is a trailer suspension problem. Frankly, travel trailers have pretty crude suspensions systems - ones that do not result in a soft ride. I think the idea of using a lower inflation pressure is just a way to deal with a shortfall of such a crude layout.
A better way to cope with the crude suspension would be to use a much larger tire and inflate it to a lower pressure - but the trailer manufacturers generally don't give you enough room to do that. Take a look at how much room there is under the fenders of a pickup truck that uses LT tires (although some of that is due to the larger diameter tires compared to the base vehicle.)
CapriRacer is offline   Reply With Quote
Old 10-19-2017, 02:12 PM   #39
Ravenna , Ohio
Because they can. At least for a while and they do pay the price with shorter tire life.
Old 10-19-2017, 02:13 PM   #40
Ravenna , Ohio
Originally Posted by CapriRacer View Post
Carl,
^x2
^^ X3
^^^x4
Old 10-19-2017, 02:19 PM   #41
Ravenna , Ohio
Seems like you did not read my blog posts on "Interply Shear" as I suggested.
These forces apply to trailer application to ANY type tire applied to trailer use with multi axles. (not 100% sure about single axle trailers being as bad as multi axle)
I suspect 3 axle trailers are worse than 2 axle trailers I did the math on.
Continental Vanco 2 225 / 70R15C tires RLS Tires 35 06-02-2013 12:15 PM
Crossing the Great Divide Santart On The Road... 12 07-12-2008 09:40 AM
Continental Travel Trailer coo978 Off Topic Forum 0 11-18-2007 01:51 PM
Trans-continental trip winner On The Road... 6 10-27-2002 08:49 AM
