08-21-2010, 05:27 PM
#21
Master of Universe
2008 25' Safari FB SE
Grand Junction
Originally Posted by 2airishuman
underinflation=bad stuff
inflate to 65 psi
maintain 65 psi
YaskwHy 65 psi.
cheers
2air'
This could be misinterpreted—cold pressure (not after driving, although I prefer early in the morning before driving) is 65. It will increase while driving, so don't "maintain 65". Leave it alone.
"YaskwHy" appears to be a language I am unfamiliar with.
Gene
08-21-2010, 05:31 PM
#22
Master of Universe
Grand Junction
Originally Posted by Garfield
My GYM are rated max 65 MPH.
Not true. Unlike passenger and many light truck tires, trailer tires are not speed rated. Airstream recommends not driving more than 65.
Gene
08-21-2010, 06:39 PM
#23
_
Originally Posted by CloudDancing
I Like the Maxxis E solution but can find a listing on the Maxxis web page. Can you please help me with a suggested source?
cloud'
should u decide NOT to buy another set of gyms,
you can read about the maxx tire here,, post 95-~122...
including a good mail order source that will ship and provide road hazard replacement coverage...
http://www.airforums.com/forums/f438...s-27999-2.html
cheers
2air'
08-21-2010, 06:58 PM
#24
Lin
, Ne
Gene
True,
http://www.goodyear.com/rv/pdf/marat...nfo_032806.pdf
08-21-2010, 07:02 PM
#25
2004 25' Classic
Prescott
Originally Posted by r carl
LOL, I was just going to post that!
Julia & Bob
W/ Deedee & Boo
AIR #30685
08-21-2010, 08:55 PM
#26
Master of Universe
Grand Junction
Note that Goodyear says "speed restricted", not speed rated. I think their lawyers wanted that because they didn't want to say it was the same as the international speed ratings. Speed ratings are a source of much controversy and lack of clarity.
See, for example: Tire Speed Ratings
Just Google the topic and get confused. If I understand what I read, speed ratings are derived from other tests rather than from directly testing tires for performance at various speeds. And speed ratings were developed in Europe for cars and later extended to some LT tires.
Gene
08-22-2010, 04:48 AM
#27
2005 19' Safari
GLENDALE
, AZ
Someone asked about a source for Maxxis tires. We got ours at Discount Tire. Discount doesn't normally keep Maxxis in stock; but they ordered them, and the tires arrived the next day. Please note that this was in Phoenix, and there is probably a local wholesale distributor in town. You might have to wait a couple of days, if you need tires in a small town.
08-22-2010, 06:40 AM
#28
2007 25' Classic
marco island
i forgot to say....i hade $4,500 in damages to my unit when the first blowout occurred....and i had no idea that i could get any help from goodyear...not that i actually wanted to deal with them again.
08-23-2010, 05:54 AM
#29
2007 27' Classic FB
Castle Rock
Were these E rated Maxxis and if so do you have the model #.
Maxxis web page doesn't show an E rated trailer tire.
08-23-2010, 02:55 PM
#30
2005 19' Safari
GLENDALE
, AZ
CloudDancing, see info on the Web site below (click on SPECIFICATIONS tab). The 8 ply-rated tires are Load Range "D", and the 10 ply-rated are "E".
M8008 ST Radial
Also, as mentioned before, we purchased our Maxxis Load Range "E" tires through Discount Tire. I keep them inflated to 80 psi to reduce overheating (and blowouts) here in desert southwest where it is around 110 degrees right now.
08-24-2010, 05:15 AM
#31
2000 31' Excella
St Michaels
, Maryland
Well we did have another tire blowout. This time 1/2 hour from home, that's 2 in one week. So we unloaded trailer and went on home. We left it at a tire shop. The tire had lost all of its outer tread and was rolling on about 4" of rubber which was keeping the rim off the ground. Some small damage to wheel well but that was all. Now the decision is between Carlisle E or Maxxiis E. About $200 difference. We don't mind spending the $200 if it will be worth it. There isn't much written on the web about Maxxiis. While that appears to be good news, it could be that they are not used nearly as often as the other brands. Thanks for all the info. MJ
08-24-2010, 06:02 AM
#32
2007 25' Classic
marco island
i paid $104 each for my maxxis 10 ply. same price as the 8 ply marathons...bought 'em in punta gorda, fl from city tire..per their chart i keep them at 75lbs as this is adequate for my weight. max pressuere is 80 lbs cold.
08-24-2010, 08:37 AM
#33
2007 27' Classic FB
Castle Rock
Thanks for all the Maxxis feedback. I'm still concerned that they are not rated above 65 MPH as That doesnt seem much margin at 65-70 MPH expressway speeds. I also think that Goodyear and Airstream should bear some responsibilty for this situation. I plan to contact both.
