Old 05-09-2013, 03:07 PM   #1
2003 25' Safari
:iyy;e Torch Key , Florida
bias vs radial
Thanks for the info on changing the load rating from "D" to "C". I will stick with "D".
What do you think of radial vs bias? I am looking at Greenball Tow-Master bias st225/75/D15. Thanks. Jeff
Capt Jeff is offline   Reply With Quote
Old 05-09-2013, 03:14 PM   #2
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I tend to lean towards the radical, although I am unbiased.
robert claus is offline   Reply With Quote
Old 05-09-2013, 03:20 PM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
If the trailer came with radial tires, I would continue to use radial tires. There is a difference in the thought process for suspension design from the 505/60s bias ply tires versus modern radials.
Old 05-09-2013, 03:40 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have TRC15225E Greenball Tow - Masters. Only rolled 800 miles so far. So no problems here. I am running 80 psi as recommended by Greenball.
Noise level inside on same roads no different than with GYMs.. I used cell phone on RECORD while pulling on test roads then compared with same roads using Greenball tires. That is if you trust your cellphone.
I.turned on the stereo.inside on same cassette tape while underway as a "level" set to compare.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-09-2013, 05:19 PM   #5
Wild-Air's Avatar
2012 25' FB Flying Cloud
Minden , Nevada
Why?
Russ
Wild-Air is offline   Reply With Quote
Old 05-09-2013, 05:23 PM   #6
TinCan
graysailor's Avatar
2016 30' Classic
As a life long truck driver I can assure you that radial tires are the only way to go. The only problem with radials is if they come apart they can do some real damage.
graysailor is offline   Reply With Quote
