Old 07-14-2019, 08:18 AM   #1
2015 16' Sport
Prineville , Oregon
Bambi Uneven Tire Wear
2015 Bambi Sport 16. Attached photo shows uneven tire wear on original tires after 20000 miles. The wear was the same on inside of both tires on my Sport 16.
Caught this on service check and had tires replace.
What would cause this?
stephendy is offline   Reply With Quote
Old 07-14-2019, 10:02 AM   #2
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Camber appears to be excessive, but? Suggest an alignment at a qualified truck/trailer shop to verify axle is correctly set up.
Those look like GYMs. Four/five years on the ground would have been past time to replace based on current thoughts. However, your experience adds data to the file which supports the concept that GYMs produced in later runs like 2015 were better quality than the ones produced prior. Or that concept is flawed and you were just lucky. In any case, good you moved on.
The tire experts may be able to give you a better answer. Maybe there was a belt slippage. My knowledge falls short there. Certainly worth asking. Pat
Old 07-14-2019, 03:29 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It's my understanding that 20,000 miles on a trailer tire is above average. (that's a reason why I run LTs)
There is some feathering, but the truth is, my examination of the photo's the tire doesn't look that bad for a worn out trailer tire.
Sometimes a trailer tire will wear unevenly for unknown reasons.....
If I were you and I'd just gotten 20K out of a set of ST tires I'd just put a new set on and forget about what I'm seeing as minor uneven wear.
Old 07-15-2019, 07:42 AM   #4
2015 16' Sport
Prineville , Oregon
Thank you PKI and JMorgan for feedback. I am surprised how little is expected from the GYM tires. Anyway I will keep a close eye on new tires.
Old 07-15-2019, 08:12 AM   #5
1981 31' Excella II
New Market , Alabama
I would say you have an alignment problem. I would also say that tire may have been underinflated since most of the wear is on the outside edges with the worst being on one side. Were both tires worn on the inside edge? Another possibility is the trailer was way overloaded. Trailer axles are usually bent in the middle so the tires would actually be father apart at the top and as the trailer is loaded that bow in the axle straightens out. If the wear is on the outside edge it maybe the axle is under loaded. If the wear is on the inside then the axle is over loaded. 20k miles is not bad for a trailer tire.
Perry
Old 07-15-2019, 08:43 AM   #6
PKI
PKI's Avatar
The GYM was a respected tire as ST tires go when it was manufactured in the US. Goodyear transferred the production of the Marathon to China and folks started having quite bad road performance from those tires. The loss of a tire on an AS causes extensive damage as the shredded tire destroys the plastic fender well, aluminum around the wheel well and plumbing/wiring as well.
ST tires in general are not well respected. The Maxis and a few other brands have fared a bit better. It helps a lot to never exceed their 65 mph speed rating. Several designs are now rated for towing speed faster than 65mph. That is expected to help the longevity of those tires. There are folks who claim 10 years life. Others 10 miles. Neither is likely generally true, but the belief is that ST tires will have a short life. That may not be justified, but the risk of damage outweighs the cost of replacement tires. The single axle tires fare better than dual axle, because they do not scrub the side wall when turning. That is a point in your favor.
If you are really interested, there are a lot of threads that discuss the issues and experiences in depth. Tire experts post on the threads and are quite helpful.
Good luck with your new shoes. Pat
Old 07-15-2019, 08:53 AM   #7
2013 20' Flying Cloud
Westerly , Rhode Island
You didn't end up with a new set of Marathons did you? Goodyear replaced them with the Endurance trailer tire and so far has had good reports. I'm sure there is still some NOS Marathons floating around.
smithcreek is offline   Reply With Quote
Old 07-15-2019, 10:49 AM   #8
1981 31' Excella II
Weigh the trailer with it loaded.
Perry
Old 07-15-2019, 11:17 AM   #9
2017 16' Sport
Canyon Country , California
Causes of premature wear on tires:
1. Way heavier than GVWR
2. Alignment in need of adjusting
3. bend axle caused by several reasons
4. Bearings gone bad
5. Brake Control needs to be adjusted
6. Brakes may need to be adjusted (rare)
7. Sharp curves in high speed
8. Improper air pressure (too high or too low)
9. Bad tire manufacturing process
10. Low tire quality
11. …….
2014 Ford Explorer XLT with factory installed Tow Package.
2017 M16 Bambi
Halford1 is offline   Reply With Quote
Old 07-15-2019, 11:43 AM   #10
1967 26' Overlander
Spartanburg , South Carolina
I have run GYM's on a dual axle trailer many years having once run a set for 13 years and many miles with no problems. I am now running a set made in China which look good and run well with no sign of uneven wear after about 10,000 miles. I usually set tire pressures 10% above GoodYear's load range charts which are available on their web site. I stay under the 65 mph ST speed limit. The tires in the pic appear to have been run under inflated and I wonder if the pressures were maintained according to GY's recommendation. Other comments about bent axle, mis-alignment etc are valid and deserve consideration.
Jacob D is offline   Reply With Quote
Old 07-15-2019, 12:08 PM   #11
batman's Avatar
1964 22' Safari
modesto , California
Stephendy,
always good to keep an eye on the tires.
Interestingly we have an other thread going right now by a terrific resource here on the forums (Tireman9). Dealing with tire failure.
http://www.airforums.com/forums/f438...ml#post2264768
Tireman also has a fairly comprehensive web-page/blog
http://www.rvtiresafety.net/search/label/Failure
-Dennis
batman is offline   Reply With Quote
Old 07-15-2019, 12:51 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I would put on a new set of good tires and watch them for wear. I go by years instead of miles for trailer tires. And I suspect under-inflation is part of the wear problem shown. But I would not want to bend or align based on how a set of the old GYMs wore.
Old 07-15-2019, 06:21 PM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I've read that the life expectancy of ST tires, (i.e. trailer tires) is about 12,000 miles.
Old 07-30-2019, 08:56 AM   #14
2015 16' Sport
Prineville , Oregon
Thank you Batman J Morgan Bill M. And Everybody for your input.
I think I can trace my tire wear a problem to chronic under inflation.
I will more carefully monitor wear, pressure etc. this time around on my new tires.
Old 07-30-2019, 09:13 AM   #15
waninae39's Avatar
2017 22' Sport
NCR , Ontario
it looks like under inflation based on the wear pattern
waninae39 is offline   Reply With Quote
Old 07-31-2019, 06:42 AM   #16
CapriRacer
CapriRacer's Avatar
I'm in the , US
Opps. I forgot how to read.
Nevermind!
CapriRacer
Please visit my website: http://www.barrystiretech.com/index.html
CapriRacer is offline   Reply With Quote
Uneven Tire Wear Jwestman On The Road... 2 04-04-2016 05:09 PM
Uneven tire wear!! claybags Tires 46 01-08-2015 10:37 AM
Uneven tire wear Lumatic Tires 7 07-19-2012 09:08 AM
uneven tire wear 64globetrot Axles 4 09-13-2009 02:01 PM
Uneven tire wear..Yikes!! daydreamer36535 Tires 18 07-09-2007 10:17 AM
