Closed Thread
Old 10-26-2005, 11:14 AM   #1
Bambi Tire Pressure
My owner's manual says to set tire pressure on my 16' Bambi (1 axle) to 60-65PSI cold. My tire store guy says 45.... I'm guessing Airstream is right, ....???
Desert Bear
drmmlien is offline
Old 10-26-2005, 11:35 AM   #2
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Check your manual
Per Goodyear ST Marathon ratings for the ST215/75R14 tires used on your 16' Bambi, a pressure of 45 PSI would provide a load carrying capacity of a bit over 1790# per tire. Your 16' Bambi gross weight is 3500# so you would be covered, BUT just barely. I think if you will look carefully in your manual Airstream is actually recommending 50PSI for the 16' Bambi, as the ST215/75R14 tire has a MAX inflation pressure of 50 PSI per Goodyear. Airstream has been recommending running at max pressure in the Marathons as they run cooler and will last longer. On the 19' and some other models with higher per tire loadings, 15" wheels and D-rated tires, 65PSI is mandatory just to meet the loading.
BTW, I am pulling the info directly from current Airstream documentation.
David Tidmore
GM Roger Williams Airstream
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline
Closed Thread
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
dual wheel tire pressure jpurdy Tires 2 10-14-2006 11:03 PM
Tire Pressure TBYRNE Tires 11 08-09-2002 09:04 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
