Old 04-01-2017, 10:22 AM   #21
2008 19' Bambi
Carlsbad , California
Wow Bill! You really get around. Thanks for the link to your work. I enjoyed traveling via your shots.
Russ
Ruscal is offline   Reply With Quote
Old 04-01-2017, 12:27 PM   #22
TCwheels's Avatar
2019 25' International
Traverse City , Michigan
Originally Posted by WKPwildlife View Post
Hi Russ,
I called Michelin help line (1-866-866-6605) to ask about correct tire pressures for a 4,500 lb AS. He told me that the info wasn’t on their website so he listed it for me:
Michelin Defender LTX M/S2 225/75R16 115R tires:
50 psi = 1,940 lbs
55 psi = 2,060 lbs
60 psi = 2,190 lbs
63 psi = 2,250 lbs
65 psi = 2,335 lbs
70 psi = 2,440 lbs (2,250 lbs)(110%) = 2,475 lbs
75 psi = 2,560 lbs
80 psi = 2,680 lbs
These are minimum recommended pressures. He suggested using the max pressure (not very helpful). I’ve decided to start with 110% of the minimum (63 psi for 2,250 lbs) for each tire: 70 psi. I haven’t given these tires a rigorous test yet.
Bill
I chose 72 psi with exactly the same tires (on FC20) and have run about 12k miles on that combination/pressure. Ride does not bounce the AS around nor is it squirrelly. Tire temps are not elevated.
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 04-02-2017, 05:54 PM   #23
2008 19' Bambi
TC,
Thanks for that report. At 72 PSI you have almost 500 pounds of reserve capacity per tire, and enough air to subdue sway. Mine show virtually no sidewall pucker at 75 PSI. If the ride quality is good at these high pressures we can benefit from the low rolling resistance and not shake the trailer apart. Always nice to save on the pop rivet budget!
Russ
2016 Bambi Sport 16 tire upgrade to 15" Viggen 2005 and newer - Bambi all models 24 02-27-2019 07:26 AM
2016 Sport Bambi 22FB Tire Upgrade ? jcole 2005 and newer - Bambi all models 7 02-23-2016 06:11 AM
13" tire upgrade to 14; Bambi jrsygrl 1961 - 1963 Bambi 5 08-25-2013 09:45 PM
14" 215/75 to 15" 225/75 wheel & tire upgrade Ray Eklund Wheels, Hubs & Bearings 19 03-29-2008 11:12 AM
16' Bambi Axle/tire/brake upgrade ljmiii Axles 2 02-26-2007 04:46 PM
