Old 05-06-2014, 07:06 PM   #1
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Average tire temp above ambient
I've seen some conflicting information in this and other forums regarding tire temperature above ambient.
With the friction of the tire against the road, which itself is probably higher than ambient air temperatures, I'm wondering what range is acceptable for tire temps.
With my TPMS system, I'm seeing an average of 30 degrees above ambient (consistently over the 4 trailer tires) This doesn't bother me when ambient temps are 70 or below, but above 70, my trailer tires start registering triple digits. I've seen them get as high as 120 during 90+ degree weather.
My TPMS manufacturer recommends a warning at 154 (I believe) as much above that (180? ) is where failure occurs.
Any thoughts? Thanks!
SteveSueMac is online now   Reply With Quote
Old 05-06-2014, 07:56 PM   #2
SteveH's Avatar
Common Sense , Texas
I think tire temperature will be depend on lots of variables like speed, load, air pressure, direct sun light, etc., so there's probably no set or predictable temperature above ambient.
I can tell you on our last trip, I saw temps from 10 to 15 degrees above ambient with 16" load range E LT tires inflated to 70 pounds, and running an average of 65 MPH.
Regards,
Steve
Old 05-06-2014, 08:44 PM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I usually see about 30f degrees above ambient. It is a combination of road temp plus friction. I am not concerned as long as it stays below 140f. Yes, tires,will fail at about 180f
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 05-06-2014, 09:44 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The ST tires that were on my Argosy when I bought it (Carlisle Radial Trails) ran about 25F above ambient (as measured with an infrared thermometer).
The Michelin LTXs I replaced the Carlisles with when they aged out run about half that... 10-15F above ambient.
David
Old 05-07-2014, 10:04 AM   #5
2016 30' Classic
Erie , Colorado
15" Marathons with the TST TPMS system are usually 30 degrees above OAT running at 65mph.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 05-12-2014, 03:32 PM   #6
Ravenna , Ohio
Tire operating temperature primarily comes from the internal molecular friction of bending the rubber. The temperature will increase until the heat generation rate matches the cooling from the surrounding air and heat flow through the internal air in the tire to the wheel and to outside air.
Multi-axle trailers should use the tire sidewall pressure as the cold "set" pressure.
I have written in my blog about how this max pressure will keep the rubber flexing and internal shear forces as low as possible for the load you are running.
Cooler running and storage under white tire covers also will lower the tire aging rate which means more service before possible failure.
There is no way you can use the info from a different RV to know what the "correct" answer is for your tires. Speed, inflation, load, air flow, tread depth type of wheel (steel or aluminum) even wheel design can all impact the steady state running temperature.
The 150 - 160F range for TPM warning is reasonable but you should never see that if you are running less than 85% of the maximim tire load and are running the tire max inflation.
Retired tire engineer (40 years). Write a blog on RV tires.
Tireman9 is offline   Reply With Quote
Old 05-14-2014, 07:03 AM   #7
CapriRacer
CapriRacer's Avatar
I'm in the , US
A couple of thoughts:
First is that there is a difference between measuring the surface temperature of a tire (by using an infrared thermometer) and the temperature of the air chamber. Don't confuse the 2.
Second a 30F build up (about 10% pressure buildup) is a good operating number. Concern should be paid if the values gets over either of those.
CapriRacer is offline   Reply With Quote
Old 05-14-2014, 09:09 AM   #8
andreasduess's Avatar
1984 34' International
Toronto , Ontario
I do a quick touch check on my tires after towing, so far from accurate, but I can say that 30 above ambient seems high to me.
Then again, on the triple axles the tire load is relatively low, so they can, and should, be run at slightly lower pressure.
andreasduess is offline   Reply With Quote
Old 05-14-2014, 11:19 AM   #9
W , New England
Thanks - those are both what I'm seeing - about 30 degrees F above ambient and about 10% increase in pressure (consistently). My TV TPMS doesn't show temp, only pressure and those tend to rise about 10% as well.
Thanks for the insights! Very helpful!
Old 05-14-2014, 10:23 PM   #10
Ravenna , Ohio
With over half on 5th wheel RVs having one or more tires overloaded I am not sure you can be confident a triple axle is not overloaded.
Load is never balanced equally between all axles and side to side on all axles.
Many times there are unbalance loads of over 500#.
Internal tire structure temperatur can run 20 to 60F above ambient depending on the many variables of load, inflation speed, type of wheel etc.
Average speed you tow at? John Community Polls 294 10-24-2015 02:45 PM
US Average Low Temp Maps EvelynDickinson Full-Timing, Winter Living & Workamping 1 10-06-2010 07:26 PM
Low temperature ambient switch jcanavera Refrigerators 4 11-02-2007 05:47 PM
Average Age? dsawyer Community Polls 67 04-19-2005 10:42 AM
HELP! average price for a 1976 Caravanner BabyStreamer Trailer Values 9 01-13-2004 07:24 AM
