09-27-2010, 12:32 PM
Common Sense
Anyone Using These LT Tires?
It's been a while back, but I remember some people using the Yokahama 7R15 LT tires on their Airstreams, and I wonder if anyone can give an update on their performance/logivity in trailer use?
Yokohama RY215
Regards,
Steve
09-27-2010, 12:56 PM
Silver Mist
Riverhead
, New York
May not be able to since they are not ST's
09-27-2010, 01:27 PM
1958 26' Overlander
Mesa
Yokohama RY215
I put these on my '58 Overlander a few months ago. Sorry, but I can't give you an honest appraisal of their performance yet since I really haven't towed much with them. In the short 40 miles I've towed it on the Interstate and around town they appear to be doing fine, but that's not much of testing period. I'll give a full report next Spring after my restoration is complete.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
1967 26' Overlander
Winston Salem
, North Carolina
Before the ST's were introduced owner's would usually run 7:00 15 LT's bias ply.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
09-27-2010, 01:56 PM
Common Sense
One of the "reviews" on the tires
Initial Review, 15,000 Miles on Tires
January 19, 2009I bought a set of 4 for my 28ft .enclosed work trailer... having been thru MANY kinds of trailer tires... Carlisle,Goodyear,Towmaster.. they were ALL sub standard .. didn't last very long before they came apart .. local tire dealer said to try these and they are GREAT ... never had a tire go more than 10,000 miles these will go much further than that ... anyone looking for a TOUGH trailer tire .. this is it.
Regards,
Steve
09-27-2010, 03:33 PM
Lin
, Ne
I put 6 yokohamas on my F350 yrs ago and could not wear them down half way,,, they blew out before then.
09-27-2010, 09:06 PM
1963 19' Globetrotter
Orion
I run them on my trailer and they have been an excellent tire . In fact this is my third set . Replacement was due to age not wear in both instances .What I really like is that thay look like a bias tire but are actually a radial . Tire Rack stocks them.
09-27-2010, 09:18 PM
Common Sense
Thanks for your input, 63air. Might I ask at what age you replaced your previous sets?
Regards,
Steve
09-28-2010, 03:06 PM
Vintage Kin
Fort Worth
I put them on my 8k GVWR tandem axle 34' Silver Streak, ran about 5k miles. Previous owner had also used them. Heavy construction, narrow tread, never squirmed on full lock turns. Never ran hot, either. Added new shock absorbers and CENTRAMATIC balancers, very happy with package for the short time used (have posted on them several times).
We were full-timing and trailer weight stayed around 7,400#.
SILVER STREAK spec'd a Load Range C tire, and these were perfect, IMO.
09-29-2010, 09:25 PM
Orion
Replaced each set when they were between 4-5 years old. The first set was on the trailer when I bought it . Sure I could run them longer and they were certainly not anywhere near worn out. I have at least 50,000 miles of travel on this model of tire.
09-30-2010, 01:23 AM
1979 30' Argosy
Havelock
, where we park it
I have a set on our trailer a little over 2 yrs. and 15,000 miles and they are very good tires on a trailer, really like the tires will buy another set in a couple years because of age.
Another good LT tire is Toyo, they make a 15" also.
Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
10-02-2010, 07:48 AM
Common Sense
Marvin
Thanks Happycampers, I'll look into the Toyo LT tires also.
Regards,
Steve
10-02-2010, 02:11 PM
1977 27' Overlander
Trotwood
, Ohio
You will also find those tires on the front of thousands of BIG TRUCKS accross the country. Both are good brand tires.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
10-02-2010, 02:54 PM
Common Sense
Marvin
I went to Toyo's web site, and could not find any 15" "D" rated tire. I did find one 235/75 15 tire in a "C" rating, but no "D".
Regards,
Steve
10-03-2010, 05:17 AM
1979 30' Argosy
Havelock
, where we park it
Steve; I have never looked up Toyo tires, I know a few people that are using them on their trailers and going by what they say about them. I am at the Fall Colors Rally at Penwood Pa now and I know one person that is here that has the Toyo tires, as soon as everyone is up and around I will check and see what the rating is on his I do know they are 700.15 LT tires.
Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
10-03-2010, 07:46 AM
1979 30' Argosy
Havelock
, where we park it
Toyo M 53 7.00 R15 105L 8PR BSW Summer tires: Automotive at Bizrate.
Try this Steve, I looked at my friends tires and they say 8pr and it says the same thing on their web site, I don't know if that means 8ply or not.
Hope this helps.
Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
10-03-2010, 08:02 AM
Corpus Christi
Marvin, great find! Sure looks like a good solution for a number of 'streamers.
So Long!
10-03-2010, 02:29 PM
Vintage Kin
Fort Worth
The specs appear the same with both YOKOHAMA RY-215 and TOYO M-53 (the load rating is 2040#)
Yokohama Tire
http://marktg.toyotires.com/file/30068.pdf
Except that the TOYO is tube type!
I don't see the M53 listed at
LIGHT COMMERCIAL TRUCK | Toyo Tires
I ordered my 7R-15 (7.00 x 15) YOKOHAMA RY-215's thru Tire Rack, had them road-force balanced and installed them with Centramatic balancers. Those (and new shock absorbers) made a world of difference after an axle alignment.
10-03-2010, 04:04 PM
1976 Argosy 24
now being enjoyed by Heath and Mary in
, Vermont
Steve,
I have them on my ARGOSY. See post #455 here for more information:
http://www.airforums.com/forums/f227...tml#post557019
Good looking tires.
Sergei
