Old 06-02-2013, 01:44 PM   #1
interstateflyer's Avatar
2017 25' International
Los Osos , California
Anyone use a InfraRed Pyrometer?
I have an InfraRed pyrometer left over from my kart racing days. Thought I'd take it along next week to track temps on the new Michelin LTX M/S 16s @ 80psi on my International 19.
We expect to drive in ambient temps at or near 100F. Does anyone have suggestions on how to use the temp data on an Airstream single axle in hot weather?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 06-02-2013, 02:05 PM   #2
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
I have one, and tire temps down south in mid July can run above 110 on my '69 TradeWind. As long as they are running within a few degrees of the tow vehicle's tires and your two tires are about the same temp, everything is pretty much running the way it should be.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 06-02-2013, 02:14 PM   #3
Thanks. Is that 110 ambient or on the trailer tires?
Old 06-02-2013, 02:19 PM   #4
dznf0g's Avatar
Oswego , Illinois
Yes, keep in in the center console and use it at each fuel stop.
-Rich-
Old 06-02-2013, 02:19 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I would worry less about the actual temp and concentrate more on the range between different tires, if you have one running noticeably hotter than another one I would be concerned. I would check hub temps too. FWIW I have seen tire temps in the 125* range on a 100* day after a long run at 70mph.
Aaron
WBCCI #XXXX AIR #2495
Old 06-02-2013, 02:21 PM   #6
dznf0g's Avatar
Oswego , Illinois
I hit the tire at the shoulders and the hubs and calipers.
-Rich-
Old 06-02-2013, 03:38 PM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have one and check the hubs at each gas stop in hot weather.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-02-2013, 03:47 PM   #8
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Expect the sunny side to be a few degrees warmer on both the TV and the trailer.
John W. Irwin
WBCCI #9632
Old 06-02-2013, 05:33 PM   #9
Journalist's Avatar
1969 25' Tradewind
The tires themselves will run above 110 with the ambient temp in the 80s.
AIR #8891
Old 06-02-2013, 05:47 PM   #10
Skater's Avatar
1995 30' Excella
Bowie , Maryland
With temperatures in the low 90s Friday, our tires were running at 115-120 degrees all the way around after highway speeds, as a point of reference. Love the laser thermometer.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-02-2013, 06:16 PM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Yep...
Now I know just how hot the DW really is.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-02-2013, 07:12 PM   #12
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I check the tires and wheel bearings at every stop when the quick walk around is done before remounting the TV. I look for a basic uniformity in the temperatures. Odd man out gets a closer look.
Old 06-02-2013, 10:35 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
+1 for using this temp gauge.
Peace and Blessings..
Channing
WBCCI# 30676
