Old 02-07-2012, 05:06 PM   #1
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Any reason to NOT use bias ply tires?
I've read as many of the tire threads as possible over the last month in preparation for my impending purchase of 7 new tires for my AS. Its obvious every tire radial or bias can experience a blow-out. Radial tire failures seem to play havoc with the AS itself by tearing out wheel wells, plumbing, and side moldings and more. Bias tire failures are not usually associated with the same catastrophic events. I know there are some limitations w/ bias ply such as flat spots after sitting and maybe some difference in performance in ride or road footprint. But avoiding the potential damages associated with a radial tire failure seem well worth the few limits that come with a bias tire. So is there any substantial safety/ performance related reason to NOT use bias ply tires on my AS? Difference in cost is not an issue. What say ye?
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 02-07-2012, 05:10 PM   #2
dznf0g's Avatar
Oswego , Illinois
I don't think so.
They will "flat spot" more than a radial, but that works out after a few miles if it's just been sitting for a few weeks. Long term storage, put it up on stands. (I do this with radials as well)
They have more rolling resistance than a radial.....but is it significant????
Depending on construction and materials...the sidewalls may be stiffer than a radial, so a harsher ride....again...is it significant?
I see no reason not to use a proper bias tire....personal preference.
-Rich-
Old 02-07-2012, 05:22 PM   #3
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
I agree, road and wind conditions are likely to have more influence on total resistance to movement and the harshness of the ride. I'm guessing in an ST tire the difference in sidewall stiffness is not meaningful.
Air Cid
Reese WD Hitch
Old 02-07-2012, 05:30 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
In general, bias ply tires are more prone to blowouts as a result of road hazards that result in a puncture. I believe that overall they are less safe as a result. I would not have one on a valuable trailer. They're fine for farm equipment and other vehicles that operate at lower speeds.
Old 02-07-2012, 05:41 PM   #5
r carl's Avatar
Lin , Ne
Checking your air pressures and staying away from china tires will go a long way in preventing blowouts.
Old 02-07-2012, 05:55 PM   #6
dznf0g's Avatar
Oswego , Illinois
That's not been my personal experience with boat trailers and my first pop-up with 12" wheels and bias plys. I'd run 70mph, so with a 12" what does that translate into with a 15" AS wheel?
It was my Dad's pop up before I bought it....in 22 years of ownership, we had several flats...never a blowout nor self destructing tire. I did throw about 8" of tread on one, but it didn't lose any air before I noticed a vibration and pulled over.
I hear what you're saying, but it's just not been my experience... I think quality is relevant for bias ply....just like it is for radials.
-Rich-
Old 02-08-2012, 05:36 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Same'o kind'a....
Had a bias fail on the 63 Safari, first trip home, age? Section of tread separation, no damage. Replaced with bias D range, 18 Season's W/O problem's.
Have had bias on the 53 Ford since new with no problems, first replacement 1976 and again in 2009. Noticeable improvement in construction quality on the '09 switch.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-08-2012, 05:50 AM   #8
1981 31' Excella II
New Market , Alabama
I would rather put radial passenger rated tires on because more of them are made and quality control is better because of the potential liability issues. Trailer specific tires are a nitch that is filled with off brand chinese and other overseas manufactures with little or no quality control. If I remember my earlier days, bias ply tires tended to overheat at high speeds and had inferior ride and traction compared to radials. Evidence of Airstreamer's experiences on this forum confirms that.
A properly constructed radial should never fail catastrophically. I don't include any trailer specific radial tire as properly constructed. I have never had a radial tire explode or come apart. Most that do come apart because they were run at highway speeds with 5psi of air in them. You have no reason not to run car tires because you have 6 of them to carry the load, none of them are going to see a lot of load.
Perry
Old 02-08-2012, 05:58 AM   #9
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Assuming like for like - meaning a quality bia-ply vs radial
From a performance aspect radials are better than bias ply that is why they are on the market today. They have less rolling resistance, more flex and as such willl consume less energy to get them and keep them moving.
I do not believe they are any more or less safe.
I believe bias ply tires may not be as readily available so if you are traveling you may have issues with servicing. (Warranty, replacements and ????)
>>>>>>>Action
Old 02-08-2012, 02:51 PM   #10
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Even if under the exact same circumstances a bias ply is more prone to a blow out it is less likely to cause catastrophic damage - at least according to the tire threads on the forum. How much more prone I don't know but it seems when a blow out occurs bias ply are less likely to damage the AS -again according to the treads on the forum. In those same threads I don't recall hearing of anyone losing control of their trailer due to a blow out - might have missed it though.
Air Cid
Reese WD Hitch
Old 02-08-2012, 02:58 PM   #11
2004 16' International CCD
Orem , Utah
Over at walleyecentral
Many of guy's have gone with bias ply's at $65 tire they can be replaced twice as much. They offer stiffer wall and better going over dirt roads. Less performance on freeway.
starcraft is offline   Reply With Quote
Old 02-08-2012, 03:09 PM   #12
1981 31' Excella II
Folks are running Michelins on here and I have never heard of one failing.
Perry
Old 02-08-2012, 03:23 PM   #13
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
>>>>>>>Action
I was thinking of buying my tires from discount tire since they have 100s of stores around the US. If I go bias I'm thinking of the Carslile USA Trail ST 225 75D so obtaining a replacement should be a little easier... i think.
Air Cid
Reese WD Hitch
Old 02-08-2012, 03:27 PM   #14
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
As I have said here before, I use 700 x 15 bias on all but one of my trailers. I over ten years I have never had a flat or blowout. I use 'em on all my farm and ranch vehicles too. The Airstreams are old and light. The others are new and heavy and used on all types of roads and unimproved land.
Bias vs Radial perryg114 Tires 29 08-15-2012 08:20 PM
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
A Bias to Radial Question Eagle & Bear Tires 9 10-05-2011 05:32 PM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
