Old 03-05-2012, 05:39 AM   #43
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Here's some pretty good vid's on the subject.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-05-2012, 09:22 AM   #44
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
Road force explaination
Road force measures the tire/wheel assembly for the amount of force (in pounds) the tire's high spot exerts on the road. Think of the tire as oval shaped (most are to a degree) when it is rotating, when the high spot hits the pavement, it pushes back into the vehicles suspension causing a vibration at road speeds. An acceptible road force measurement for a passenger car is no more than 25 pounds. I have seen tire assemblys read zero- i.e. a "perfect" tire. Trucks, I believe were no more than 35 pounds. If the roadforce measurement is high- say 68 pounds, you first mark the tire to the rim, dismount the tire, and use the machines program to measure the rim for straightness. Once the rim is proven, the machine tells you where to put your previous marks in relation to the assembly. It could be anywhere from 270 degrees or 15 degrees depending. I performed the operation when I mounted any tire personal or for a customer. I have seen a tire balance perfectly but cause a vibration due to excessive road force. I have also seen the machine recommend tire replacement due to excessive out of round conditions, yet still balance.
72 tradewind is offline   Reply With Quote
Old 03-05-2012, 05:54 PM   #45
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Hunter GSP9700 Wheel vibration Control System solves wheel vibration and tire pull problems that balancers and aligners can't fix.
Some techs are good with them, and some are outstanding. DISCOUNT TIRE tends to always have them. The link has a locator.
Old 03-05-2012, 08:16 PM   #46
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Is this new technology? Seems like it would produce a better balanced tire. Thanks for the info.
desertair27 is offline   Reply With Quote
Old 03-06-2012, 05:18 AM   #47
Well it's at least 3yrs old,(9700), we had one at the Chevy Store I retired from.
PFC
RLC
Old 03-06-2012, 08:05 AM   #48
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Goes back ten years or more.
Old 03-25-2012, 10:15 AM   #49
1972 25' Tradewind
Willis , Texas
Images: 8
Bias ply update
I finally finished installing new brakes and bias ply tires (Carlisle) on our Airstream. I balanced the wheel assemblies on a tire balancer (no road force) and also installed Centramatics. The result is the best tow I have ever expeirenced. No shimmy's felt at all on a 40 mile run at 63-5 MPH. Plus, the increased tire pressure (from 45-old tire rating to the 65 rated on the new tires) made for an eaiser pull.
Old 03-25-2012, 03:22 PM   #50
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Originally Posted by 72 tradewind View Post
I finally finished installing new brakes and bias ply tires (Carlisle) on our Airstream. I balanced the wheel assemblies on a tire balancer (no road force) and also installed Centramatics. The result is the best tow I have ever experience. No shimmy's felt at all on a 40 mile run at 63-5 MPH. Plus, the increased tire pressure (from 45-old tire rating to the 65 rated on the new tires) made for an easier pull.
Did you buy the USA Trail bias ply? I'm going the bias route too and will be buying Carlisle USA Trail tires for my 91. Thanks for sharing your experience - it adds up with the posts of several others on this thread.
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 03-26-2012, 04:30 AM   #51
1972 25' Tradewind
Willis , Texas
Images: 8
yes
they are bias, thanks for the feedback.
Bias vs Radial perryg114 Tires 29 08-15-2012 08:20 PM
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
A Bias to Radial Question Eagle & Bear Tires 9 10-05-2011 05:32 PM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
