Old 07-28-2013, 12:44 PM   #71
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
Originally Posted by switz View Post
I keep coming back to the point that Airstream is offering the Michelin LT 225/75R16E tires rated at 2,680 pounds at 80psi as a factory installed option on the Eddie Bauer using SenDel T03-66655T wheels rated 3,580 pound at 80 psi. These tires and wheels are at the front door of the factory store as you walk in and a sign says they will install that tire and wheel combination onto any current Airstream (probably more recent trailers with 15" wheels).
If I retrofit the same tires and wheels the factory installs to my trailer, then Airstream would have a very difficult time denying some warranty issue by claiming the wrong tires and wheels were on the trailer.
That was not necessarily the same fact issue on our 25FB where I installed five Michelin LTX (P) 235/75R15 XL tires on the factory rims.
Hi switz,
All these reports of the OEM Goodyear Marathons failing has me thinking I would be wise to replace my tires. I have not had any issues with mine but I do like to drive a little faster than 65 MPH when the conditions allow.
Were you happy with the P-rated tires on your 25 FB? If you were to do it again for a 25 footer, would you use those or go to the 16 inch LT option?
-evan
eheffa is offline   Reply With Quote
Old 07-28-2013, 05:35 PM   #72
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I would gladly go again with the Michelin LTX (P) 235/75R15 XL tires on a 25FB as they have more than enough reserve capacity for that trailer and, at 50 psi max pressure, the ride is softer and there is a larger foot print for braking than the ST tire. Plus one can reuse the existing 15" factory metal wheels. The trailer is raised about 0.3" over the GYM ST tires. The side walls show 2,183 pound load capacity but that is derated to 1,985 pounds per federal regulation 49 CFR 571.110 paragraphs S4.2.2.1 to S4.2.2.3. The four tires have a derated load capacity of 1,985 x 4 = 7,940 pounds.
We are migrating to a 27FB Classic. The GVW will increase from 7,300 to 9,000 pounds with probably nearly the same tongue weights, and the Classic empty weight of 6,672 is slightly less than the GVW on the 25FB. Thus we have to go to the Michelins LT 225/75R16E LTX M/S2 tires and 16" SenDel T03-66655T wheels to get the necessary reserve load capacity. The four tires have a load capacity of 10,720 pounds at 80 psi and will raise the trailer about 0.45" higher than the GYM ST tires.
I have not seen threads complaining about Michelin tire failures, but the other brands, especially the GYM ST tires, are constantly in the lime light for one failure after another and many times generating significant damage that is very expensive to repair.
The Michelin 15" tires will do the job, but the Michelin 16" tires are factory installed. There is implicit factory approval of the Michelin 16" tires and SenDel wheels. You spend about $800 to $900 more for the larger tires and new wheels.
Old 07-29-2013, 06:32 AM   #73
eheffa's Avatar
Victoria , BC
Thanks switz.
I think the 15 inch option appeals to me more. Cheaper & probably a little easier on the trailer with the softer ride.
Did you have any trouble getting the tire dealer to mount these tires on your trailer? (Not ST tires...not approved etc.)
-evan
Old 07-29-2013, 03:09 PM   #74
switz's Avatar
2014 31' Classic
Images: 8
I did not bring the trailer to Costco where I purchased the tires. I brought two tires at a time and they did a switch. I installed those two and brought the other side in and then finally brought the spare in. The manager and I go back a long time, so there was no issue. Have already reserved the 16" tires for early February and will bring in the virgin SenDel wheels then for installation. I will install them personally on the new trailer.
Any questions? Just say you purchased these used tires and wheels for your old chevy .
Old 07-29-2013, 03:46 PM   #75
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
16 inch LT E rating tires all the way. Lift it if you have to. Blown tires tear up your rig, been there done it and fixed it.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 07-30-2013, 04:42 PM   #76
eheffa's Avatar
Victoria , BC
Thanks.
I have done a little more research & looked at my own trailer tires again now that it's out of storage & back home.
My current tires are Chinese made GYM's. They have not caused me any trouble & have good remaining tread; but, they are getting on to 6 yrs old now.
(I do like to drive at highway speeds & do not hesitate to cruise at 110 km/hr (65-70 MPH) when conditions allow. )
The OEM GYM's are load range D tires with a 2500 lb load rating so I do not see P-rated XL tires at ~1985 lb rating as an adequate replacement... Maybe it is good enough but I think I want/should have more reserve than that...It's tough to find LT Load Range D tires in 15 inch so the bill to fix this with new 16 inch rims & 16 LTE tires starts hitting the $1500 mark (c installation & taxes).
OTOH I could just replace the old GYM's with the same again.
Unfortunately, we don't have any good statistics - just anecdotal reports. Do they need to be replaced at all? Am I just being paranoid?
- evan
Old 07-30-2013, 04:59 PM   #77
K.C. , Missouri
Originally Posted by eheffa View Post
Thanks.
- evan
How much does your trailer weigh ? More specific, how much weight is on the trailer axles ?
gmw photos is offline   Reply With Quote
Old 07-30-2013, 05:00 PM   #78
Thanks.
- evan
Evan.
Safety, is the issue.
Some owners abide by it, others kick it to the curb.
In terms of tire safety, it's a rule of thumb to replace them, regardless of how much tread is left, when they are 5 years old.
It's your call.
Old 07-30-2013, 05:00 PM   #79
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
- evan
Hi, I'm still running Marathons on my trailer. After about three years I noticed two of them had a small sidewall bubble. I replaced those two with Chinese Marathons. At about seven years, I replaced the other two original tires due to tire separation. [during our Alaska trip] I still have the original Canadian Marathon spare. I now have three Chinese Marathons and one Carlisle on the ground. I have never had a flat or blow out. [yet] I check my tires at home, at every gas stop, at every rest stop, and at every camp ground; This may be the reason that I have replaced these tires right away before they came apart. Keep an eye on them!
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-30-2013, 05:18 PM   #80
K.C. , Missouri
Regarding 15", does anybody have any experience with or comments on the Continental Vanco 2 ?
In a 215/70-15 it is load rated as 2271 pounds at 65 psi. ( load range D ).
Looks to be marketed for light truck and utility van on the Conti site.
EDIT:
How about a GoodYear cargo G26 ? In a 225/70-15 rated for 2470lbs at 65 psi.
I believe it too is marketed as a cargo van tire.
Old 07-30-2013, 05:20 PM   #81
eheffa's Avatar
Victoria , BC
GVWR = 7300lbs - ~700lb TW = 6600 lbs
- evan
Old 07-30-2013, 05:30 PM   #82
K.C. , Missouri
- evan
Sounds like either the Conti or the GY G26 would give adequate extra capacity. Hopefully CapriRacer will chime in. His experience and background give him a decided edge in these discussions.
Old 07-30-2013, 05:33 PM   #83
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
EDIT:
It looks like both of these tires are not to be used in freezing temps. Everything continues to push me toward a 16" something.
Greg
Roadtoaster is offline   Reply With Quote
Old 07-30-2013, 07:00 PM   #84
r carl's Avatar
Lin , Ne
EDIT:
Add Yokohama RY215 to your list, they look good on older trailers. These are summer tires which will take the heat.
