Old 12-16-2012, 08:05 PM   #1
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Another Airstream Tire / Wheel Surprise
Today was the day to switch all five Good Year Marathon ST 225/75R15D tires (with about 450 miles on them) for the previously purchased Michelin LTX (P) 235/75R15 XL tires. I have a combination jack-stand/bottle jack that I used to raise one side of the trailer after dropping the spare tire. I took off the front tandem and installed the spare just snugging the wheel nuts. Then I removed the rear tandem tire and loaded the two tires into my TV. I noticed undulations in the sidewalls of all five GYM tires.
After switching the tires at the tire store, I returned to the trailer. I had noticed that there was paint on the inside of the Airstream 15" wheel on the bolt circle that had come from the Centramatic wheel balancers. While using a manual wire brush to remove the paint, I noticed there was information cast on the inside of the wheel in each of the several reinforcing rib sections.
The contents of the circle are listed below with a dash between each group to represent the raised web in the casting:
Made In China - HT - DOT/T - 104 - SenDel and a logo - Max Load - 5/2150 & 6/2540 pounds - 15XJJ ET + 0 - XR
I read this as a wheel with a 2,150 pound rating in tandem applications (5 or less wheels) and 2,540 pound rating with three axles or six wheels. I also see a 104 load rating. My Michelin tires have a 108 load rating and carry more load per the sidewall (2,183 pounds) than the wheel at it's lower rating.
It appears that these same 15" wheels are used by Airstream for all trailers except the Eddie Bauer units with 16" wheels.
Tomorrow will be Cat scales day with several 40 mile each way trips.
The first will be basically an empty trailer (virtually no water in the fresh water tank and neither the gray or black have been used) and none of my stuff aboard except for the wrenches needed for the trip (Torque wrench to check every 10 miles a couple of times then every 50 a couple of times) and the Wrench to adjust the Hensley. The TV tank will be filled at the scales.
The second trip will have a full fresh water tank and all of my tools and stuff stowed where I think it should be. The TV tank will be filled again at the scales. I may find that I need to move stuff around for another pass to get the proper weight distribution.
One may wish to inspect their wheels to ensure the wheel is also rated for the load. A great tire on a not so great wheel still ends up as a not so great assembly.
Old 12-16-2012, 08:32 PM   #2
SteveH's Avatar
Common Sense , Texas
Not 100% sure, but I think it means 5 lug/2150 lbs, 6 lug/2540 lbs rating.
Regards,
Steve
Old 12-16-2012, 08:34 PM   #3
2006 30' Classic
Milton , Florida
A Potential NHTSA Safety Recall Issue?
Originally Posted by switz View Post
...I noticed there was information cast on the inside of the wheel in each of the several reinforcing rib sections.
It appears that these same 15" wheels are used by Airstream for all trailers except the Eddie Bauer units with 16" wheels....
If your interpretation of the information on the castings is correct, and these wheels are used on 30` and above AS TT, then the wheel rating seems to be exceeded.
Was there any information on the wheels concernibg maximum inflation pressure?
Why would the wheel rateing per wheel for six tires on the ground be higher than the wheel rateing per wheel for four tires on the ground for the exact same wheel?
How many lug bolt holes does the wheel have?
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 12-16-2012, 08:52 PM   #4
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I had posted this in another tread, the Alcoa 15" aluminum wheels that came stock on the trailer have stamped max load 2200lbs.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 12-17-2012, 06:35 AM   #5
switz's Avatar
2014 31' Classic
Images: 8
These are the Airstream factory six lug wheels that came on my 2013 25FB International with a late June 2013 build date. In looking at the 2013 sales literature, these wheels may be specific to the International trim level which can reach 30' 11" and 8,800 pounds GVW.
The information I posted is not stamped, but cast into the wheel from the mold so one sees raised letters. No inflation information is provided, but Airstream's use of GYM ST tires would require 65 psi.
BTW, the spare has a steel wheel. Thus one has supper deep lug nuts to accommodate both thick aluminum wheels and thin steel wheels.
Old 12-17-2012, 07:47 AM   #6
K.C. , Missouri
If you look on the sendel site they spec the load rating and pressure, Here is an example:
Sendel
gmw photos is offline   Reply With Quote
Old 12-17-2012, 10:00 AM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
So with 6 lug wheels rated at 2500 lbs you should be good to go, right? Load range C XL tires at 50 psi. Ought to work fine.
Old 12-17-2012, 11:05 AM   #8
CapriRacer
CapriRacer's Avatar
I'm in the , US
A couple of thoughts:
First, you have to reduce the load carrying capacity of P type tires by a factor of 1.1 when using them on pickup tracks, vans, and trailers - making a 235/75R15 XL have a load carrying capacity of 1984# at 41 psi.
Note: You do NOT have to reduce the load carrying capacity of LT type tires for trailer application.
Another note: LT and ST type tires come in Load Ranges (A, B, C, etc) and P type tires come in Standard Load (SL) and Extra Load (XL), so an XL is NOT the same as a Load Range C!!
2nd thought: An ST225/75R15 Load Range D has a load carrying capacity of 2540# at 65 psi.
So if I am reading this right, the tires that just went on Switz's trailer are overloaded.
CapriRacer is offline   Reply With Quote
Old 12-17-2012, 11:07 AM   #9
SteveH's Avatar
2500 lbs/wheel will carry the heaviest Airstream built today, 30/31' Classic with a GVWR of 10,000 lbs.
Regards,
Steve
Old 12-17-2012, 11:40 AM   #10
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Switz' signature lists a 2013 25' International. Airstream lists a max gross weight of 7300 lb for that trailer. So no, the tires that just went on Switz' trailer are not overloaded, even if he runs them underinflated at the 41 PSI you specified.
David
Old 12-17-2012, 11:28 PM   #11
switz's Avatar
2014 31' Classic
Images: 8
Just returned from the scales.
With basically no fluids and no personal stuff aboard, the rear axles are supporting 5,300 pounds. The next trip included all my tools at the rear of the trailer, lots of kitchen stuff, a full tank of diesel fuel in the TV, the wife in the front seat of the TV, full 39 gallons of fresh water in the tank, and a 40 pound air compressor and 20 pound jack in the back of the TV and the rig total weight went up 820 pounds but the load on the trailer axles increased only 560 pounds to 5,860 pounds. That works out to about 1,465 pounds per tire with a sidewall rating of 2,183 and a derated load capacity 1,985 pounds or a 27% safety margin on the derated capacity or a 33% safety factory based upon the sidewall number.
Tomorrow will weigh the tongue weight again to see where I am.
Old 12-18-2012, 03:39 AM   #12
CapriRacer
CapriRacer's Avatar
I'm in the , US
Just one little quibble. P metric XL tires aren't under unflated at 41 psi. That's where the max load carrying capacity occurs. This is different than ST and LT tires where Load Range C tires have the load carrying capacity occurs at 50 psi.
Old 12-18-2012, 05:21 AM   #13
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
The max pressure listed on the sidewall of the Michelin LTX M/S2 P 235/75/15 XL 108T is 50 PSI.
Lance
Top is offline   Reply With Quote
Old 12-18-2012, 05:56 AM   #14
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
.......hey I'll take those 450mi GYM's.
too bad JC is now using china wheels.
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Airstream of Mississippi Overlander & Sea Commercial Listings 46 03-03-2014 08:24 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
