Old 05-03-2011, 10:21 PM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
American made tires? RY215?
Newbee question...
Will these fit a 1972 31' Sovereign?
Yokohama
Darkspeed is offline   Reply With Quote
Old 05-06-2011, 06:51 PM   #2
Darkspeed's Avatar
1972 31' Sovereign
Well the Yokohamas arrive on tuesday from tirerack...
Old 05-06-2011, 08:30 PM   #3
2005 28' Safari
saline , Michigan
They are a great looking tough tire with a very good reputation. I almost got them for my 28 footer but my rims were a little to big(wide) for them. I did a lot of research on them and couldn't find anyone who did not like them. Only negative is they are not always readily available while you are on the road.
Kosm1o is offline   Reply With Quote
Old 05-07-2011, 08:45 AM   #4
2005 19' Safari
GLENDALE , AZ
Could you please provide details (size, load range, tire pressure, etc.) when you get these mounted? --Thanks.
Old 05-07-2011, 09:34 AM   #5
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Specs. from TireRack for the Yokohama RY215 7R15 D
Load 2040 lbs.
Max. Inflation Press. 65 psi
Tread Depth 13/32"
Tire Weight 32 lbs.
Rim Width Range 5-6.5"
Meas. Rim Width 5.5"
Sect.Width 7.7"
Tread Width 4.9"
Overall Diam. 29.4"
Revs Per Mile 706
Country of Origin* JAPAN
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 05-15-2011, 09:34 AM   #6
Darkspeed's Avatar
1972 31' Sovereign
Yes they did have Japan on the side.
Better than china in my opinion.
Old 01-06-2012, 03:24 PM   #7
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
I just got these installed on Maxwell today. I like the looks as it seems more "vintage-ish" with a truck tire that's a bit taller and bit more narrow than the GYMs.
I changed since I don't trust GYMs on anything, let alone on hot Texas summer highways.
Now have a some piece of mind with a Japanese made commercial LT tire and no longer have that pesky 65 Mph limitation...
ID:	148397   Click image for larger version
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 01-06-2012, 04:58 PM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I had these on my 8k Silver Streak and am happy to recommend them. I have posted on them elsewhere at some length (and on Tire Rack). There are several others here on AIR with them. Throw some CENTRAMATICs on with them.
Eddie Bauer AS uses Michelin Tires? Secguru Tires 67 05-29-2014 12:33 AM
Nitrogen filled tires mysecondjoy Tires 69 04-19-2013 08:48 AM
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
White letter tires on Airstream Road Ruler Tires 2 03-09-2011 07:14 PM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
