Old 09-03-2016, 07:00 PM   #1
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
Alternative to GYM 225/75R15
Just replaced the GYM 225/75R15 tires on our 2015 Bunk with Nokian Rotiiva AT All Season LT235/75R15 116/113 S (up to 112 mph, max load 2760 lb) and could not be happier.
https://www.nokiantires.com/all-seas...an-rotiiva-at/
Purchased from Discount Tires for $719.92, steel valve stems, mounted and balanced minus $100 rebate so actually $619.92. Should get $200 for the GYMs so grand total $419.92.
One of the cheap plastic lug nut caps split off so I put new Gorilla solid chrome splined lug nut kit on for $45.00.
Got a couple of weeks to go before we get back on the road.
Name:	New Nokian Rotiiva AT 4.JPG
ID:	270729   Click image for larger version
Name:	New Nokian Rotiiva AT 2.JPG
Name:	New Nokian Rotiiva AT 3.JPG
ID:	270731   Click image for larger version
Name:	New Nokian Rotiiva AT Splined Lug.JPG
Name:	Trailer Lug Nut.JPG
ID:	270735   Click image for larger version
Name:	New Nokian Rotiiva AT 1.JPG
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 09-03-2016, 07:37 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Looks like a great choice. I am glad to see there is a 15" tire with that much load capacity available.
Old 09-03-2016, 09:13 PM   #3
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
Just so we're clear: This tire enjoys the same load capacity rating at the Michelin Defender LTX M/S 235/75R15/XL 109T. Here's a URL that should work: http://cdn.acceleration.michelinman....tail-sku-table
Not passing judgement or anything, just making sure we don't get confused.
Glad you like it so far, hope the tire works out great for you!
Rocinante is our 2014 International Signature 27FB
Old 09-03-2016, 09:41 PM   #4
Tincampers's Avatar
Sneedville , Tennessee
What tire pressure are you going to run?
Tincampers is offline   Reply With Quote
Old 09-03-2016, 09:45 PM   #5
1991 25' Excella
Stanfield , Oregon
Michelins have a 109 load index which is 2271 and being P rated needs reduced according. The tires mentioned above are an Lt rated tire with an 116 load range. Theres big difference between then and the Michelins.
SpletKay06 is offline   Reply With Quote
Old 09-03-2016, 09:58 PM   #6
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
I used to run Nokians on my Touareg and they were a good tire on and off road. They were a softer compound so wore a little faster but that shouldn't be an issue. Keep us posted on how they do.
This is the strangest life I've ever known - J. Morrison
The Nest Egg - 2015 Airstream International Serenity 27FB
Quicksilver - 2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 09-03-2016, 10:43 PM   #7
Rivet Slave
Rocinante's Avatar
Ah ha, thanks for that, very cool.
Old 09-03-2016, 11:07 PM   #8
2015 30' FB FC Bunk
Golden , Colorado
I am starting at 70psi. See how it does.
Old 09-04-2016, 03:48 AM   #9
Long Island , New York
Good move for your neck of the woods IMO, as I have read great things about the Nokian line on other forums, especially about the softer rubber compound "gripping" the pavement better when needed. We may consider a set of Nokian pure snow tires for our van tow vehicle if winter conditions warrant.
The worst blizzard I ever drove through, with chains on an older van, was coming into Flagstaff from the east, a long time ago. A gruesome trip. We finally found a motel and slept for a day while the storm passed. They had to close down the Interstate.
The new Nokian tires will be a good investment for your travels over the winter, as you noted in the other thread, offering good braking and control on curves, especially downhill curves with camber to be dealt with IMO.
Happy Trails, and thanks for starting this thread and the excellent photos! We look forward to further reports down the road.
Peter
From the other thread:
Originally Posted by 2012FB View Post
I am often pulling in and out of the snow, sometimes heavy, visiting family in Phoenix over Christmas and Spring Break so I like the aggressive nature of the tread and its bent toward being more of a winter tire. I am not concerned about tread life as age will win over miles.
Thoughts?
Old 09-04-2016, 07:36 AM   #10
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Typically Discount Tire locations will not mount non ST tires on a trailer according to other member's experiences. Looks like your DT location was more enlightened. Looks like a good choice and more than competitive with Michelin. Thanks for sharing.
Kelvin
Old 09-04-2016, 08:00 AM   #11
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
My local discount tire store in Colorado mounted my Michelin LTX tires without question. Must be up to the particular franchise/store to make the call....
wulfraat is offline   Reply With Quote
Old 09-04-2016, 09:41 AM   #12
AirstreamJim's Avatar
2007 25' Safari FB SE
Baldwin Harbor , New York
...as did the Salt Lake City location when I picked up our new (to us) Airstream and wanted great tires for the 2,500 mile trip home. They knew to properly derate them before agreeing they are adequate for the load (they told me they wouldn't have installed them if they were not).
WBCCI 1433
Long Island, NY
Silver Meteor - 2007 Airstream Safari SE LS 25FB
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 09-04-2016, 10:08 AM   #13
2014 25' FB International
Metuchen , New Jersey
WOW!!!
You get a higher load rating without having to upgrade to a larger rim. Count me in.
Thanks for posting this.
B.T.W Where are they manufactured?
GenXair is offline   Reply With Quote
Old 09-04-2016, 11:43 AM   #14
Via the link in Post #1, Helsinki Finland is the HQ, and the press page says they are opening a new distribution facility in Canada.
https://www.nokiantires.com/company/about-us/
https://www.nokiantires.com/tires/pa.../winter-tires/
https://www.nokiantires.com/company/...ions/releases/
https://www.nokiantires.com/company/about-us/history/
225/75r15 lr-d recall Tireman9 Tires 3 02-23-2014 08:44 AM
Goodyear Marathon ST225/75R15 LRD nickmeloy Tires 3 05-06-2010 05:55 PM
Fitting LT235/75R15 LR C on our '71 Tradewind... barts Tires 7 04-18-2010 07:17 PM
225/75R15 Goodyear Marathons do not fit. Silver 81 Tires 13 11-07-2009 12:00 PM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 08:41 PM
