Old 09-16-2014, 06:43 AM   #15
SteveH's Avatar
Common Sense , Texas
Originally Posted by Silverflames View Post
Got new Axels 2 years ago, still have not welded on the shock brackets yet. Otherwise a smooth ride.
I'm at 4 years on my tires, I think I need to start saving for a new set.
To the folks with LT tires, has anyone developed flat spots from the trailer sitting unused months at a time?
Been running 16" LT's for a few years now, and no flat spots. However, I did have a 2 1/2 year old B F Goodrich LRE come apart this summer and do about $3K damage to the trailer. Have since switched to Michelins, and time will tell.
Seems to me with tires, this is no panacea.
Regards,
Steve
Old 09-16-2014, 08:25 AM   #16
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
So are LT tires steel belted, and if so do they do more or less damage VS ST tire when the pull apart?
Silverflames is offline   Reply With Quote
Old 09-16-2014, 08:28 AM   #17
SteveH's Avatar
Yes, most all of them are steel belted, and they do just about as much damage, but historically so far, it hasn't happened that often. As a matter of fact, I know of no other LT failure but the one I had.
Regards,
Steve
Old 09-16-2014, 03:37 PM   #18
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
So far the information has been very helpful as reading past forums can be some what confusing to a simple man who does not understand tires. I have decided to replace the wheels and tires at the same time. I am going to get rid of the old steel rims and hub caps for aluminum wheels. The question is:: 15 or 16 inch?
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
GAT is offline   Reply With Quote
Old 09-16-2014, 03:40 PM   #19
SteveH's Avatar
This is just my opinion, but if you are going to replace the wheels anyway, why not go to 16" and have a much bigger selection of LT tires to choose from?
I think the cheapest LT tire is better than the most expensive ST tire.
Regards,
Steve
Old 09-16-2014, 03:48 PM   #20
dznf0g's Avatar
Oswego , Illinois
No flat spots. I do put it on jack stands for the deep winter months.
-Rich-
Old 09-16-2014, 04:07 PM   #21
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
These are the ones I put on my 34' Excella
Goodyear¬*Wrangler HT
Highway All-Season
Size:
LT215/75R15 106/103Q
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-17-2014, 07:16 PM   #22
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
After a catastrophic failure of a GYM ST tire in May, I did the full monty in July - new axles, new 16" Sendel wheels & Michelin LTX 225/75R16(E) tires at 80 psi - all done at the mothership. I also had Centramatics installed (and had them installed on the TV too). Was out last week for a rally and drove 1,000 miles - ride was as smooth as silk, tires were maybe 5 degrees above ambient when we stopped after driving for several hours at 60 mph.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 09-17-2014, 07:54 PM   #23
1969 29' Ambassador
What's the load rating on the LTX tires?
Old 09-18-2014, 10:03 PM   #24
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
1120 Kg @ 80 psi (2,469 lbs @ 80 psi)
VE3JDZ
AIR 12148
Old 09-18-2014, 10:51 PM   #25
1969 29' Ambassador
That sounds like what I need.
Old 09-19-2014, 05:22 AM   #26
r carl's Avatar
Lin , Ne
My local tire shop told me that Lt tires would develop flat spots since they are not designed to sit unused. Any problems so far? It sounded odd to me.
I don't think steel belted radials have a problem getting flat spots, its the tires with nylon cords. (Bias ply)
Old 09-19-2014, 06:45 AM   #27
1981 31' Excella II
New Market , Alabama
Any tire will thump a little after sitting a while. Most of the time, it settles out after the tire gets warm.
Perry
Old 09-19-2014, 10:37 AM   #28
GAT
GAT's Avatar
1976 31' Sovereign
Reading the codes
Can someone with knowledge of Michelin explain the codes. Lt, ltx, any other codes that distinguish difference especially weight limits. Is the LTX the top of the line?
Ball Ground Ga.
6.6 Duramax Diesel
Well, well, well...you'll never guess what followed us home today! InsideOut Vintage Kin 85 11-28-2017 07:58 PM
Hello All - fixing up an 84 Grandpapa Member Introductions 12 07-21-2009 06:40 AM
Well, Well, Well........ Jim & Susan Off Topic Forum 54 06-12-2005 12:46 PM
Well, Dometic "D-day" has arrived..... Silver Bullet Refrigerators 1 07-19-2003 03:11 PM
