View Poll Results: Note: This poll must be completed in one session.
Has a tire failed on your Airstream in the past 5 years – Yes. 151 50.84%
Has a tire failed on your Airstream in the past 5 years – No. 148 49.83%
Reason for tire failure: Valve stem leak/failure. 6 2.02%
Reason for tire failure: Bubble in sidewall. 18 6.06%
Reason for tire failure: Bubble in tread area. 11 3.70%
Reason for tire failure: Belt/tread slipped, but still relatively intact. 16 5.39%
Reason for tire failure: Tread separated, but still partially attached to tire body. 29 9.76%
Reason for tire failure: Tread completely separated, but tire body still inflated. 12 4.04%
Reason for tire failure: Blowout, sidewall. 18 6.06%
Reason for tire failure: Blowout, with tread separation. 59 19.87%
Reason for tire failure: Other reason(s), not stated above. 18 6.06%
Ambient/outdoor temperature when tire failure occurred or was noticed: Subfreezing to freezing temperatures. Note: Please, select only one “ambient/outdoor temperature”. 1 0.34%
Ambient/outdoor temperature: Freezing to 70-degrees Fahrenheit. 26 8.75%
Ambient/outdoor temperature: 70 to 90-degrees Fahrenheit. 83 27.95%
Ambient/outdoor temperature: 90 to 110-degrees Fahrenheit. 37 12.46%
Ambient/outdoor temperature: 110+ degrees Fahrenheit. 1 0.34%
The tire failed: Before driving. Note: Please, select only one “tire failure time”. 11 3.70%
The tire failed: While driving. 115 38.72%
The tire failed: After driving. 19 6.40%
Number of axles on your Airstream: 1. Note: Please, select only one “number of axles” response. 46 15.49%
Number of axles on your Airstream: 2. 164 55.22%
Number of axles on your Airstream: 3. 11 3.70%
Position of tire that failed: Axle #1 (front or single axle), left side. Note: Please, select all “failed tire positions” that apply. 48 16.16%
Position of tire that failed: Axle #1 (front or single axle), right side. 66 22.22%
Position of tire that failed: Axle #2, left side. 33 11.11%
Position of tire that failed: Axle #2, right side. 42 14.14%
Position of tire that failed: Axle #3, left side. 4 1.35%
Position of tire that failed: Axle #3, right side. 5 1.68%
Did a road hazard, hitch failure or vehicle accident cause or contribute to the tire failure: Yes. 10 3.37%
Did a road hazard, hitch failure or vehicle accident cause or contribute to the tire failure: No. 118 39.73%
Did the tire failure cause or contribute to a vehicle accident: Yes. 0 0%
Did the tire failure cause or contribute to a vehicle accident: No. 137 46.13%
Number of tires that failed during the original incident: 1. Note: Please, select only one “number of tires that failed during original incident” response. 124 41.75%
Number of tires that failed during the original incident: 2. 15 5.05%
Number of tires that failed during the original incident: 3. 6 2.02%
Number of tires that failed during the original incident: 4 or more. 3 1.01%
Number of additional tires that failed within 30 days or 1,000 miles of the original incident: 1. Note: Please, select only one “number of additional tires, within 30 days or 1,000 miles” response. 20 6.73%
Number of additional tires that failed within 30 days or 1,000 miles: 2. 4 1.35%
Number of additional tires that failed within 30 days or 1,000 miles: 3. 1 0.34%
Number of additional tires that failed within 30 days or 1,000 miles: 4 or more. 0 0%
Number of additional tires that failed within 12 months or 12,000 miles of the original incident: 1. Note: Please, select only one “number of additional tires, within 12 months or 12,000 miles” response. 11 3.70%
Number of additional tires that failed within 12 months or 12,000 miles: 2. 4 1.35%
Number of additional tires that failed within 12 months or 12,000 miles: 3. 4 1.35%
Number of additional tires that failed within 12 months or 12,000 miles: 4 or more. 2 0.67%
Type of tire that failed: ST. Note: Please, select only one “type of tire that failed” response. 117 39.39%
Type of tire that failed: LT. 5 1.68%
Type of tire that failed: Other/unknown. 8 2.69%
Tire size of failed tire: 215/75. Note: Please, select only one “tire size”. 13 4.38%
Tire size: 225/75. 115 38.72%
Tire size: 235/75. 16 5.39%
Tire size: Other. 4 1.35%
Wheel size of failed tire: 14 inch. Note: Please, select only one “wheel size”. 17 5.72%
Wheel size: 15 inch. 140 47.14%
Wheel size: 16 inch. 9 3.03%
Wheel size: Other. 0 0%
Load range of tire that failed: C. Note: Please, select only one “load range”. 16 5.39%
Load range: D. 93 31.31%
Load range: E. 34 11.45%
Load range: Other. 3 1.01%
Normal tire pressure for tire that failed: 36 psi or less. Note: Please, select only one “normal tire pressure” response. 0 0%
Normal tire pressure: 36-44 psi. 4 1.35%
Normal tire pressure: 50 psi. 26 8.75%
Normal tire pressure: 55-60 psi. 25 8.42%
Normal tire pressure: 65 psi. 92 30.98%
Normal tire pressure: 72 psi. 6 2.02%
Normal tire pressure: 80 psi. 15 5.05%
Normal tire pressure: 80+ psi. 1 0.34%
Tire was inflated to “normal tire pressure” above, at time of failure. 117 39.39%
Tire was inflated to a lower pressure. 6 2.02%
Tire was inflated to a higher pressure. 1 0.34%
Tire pressure was unknown at time of failure. 5 1.68%
Manufacturer of failed tire: BG Goodrich. Note: Please, select only one “manufacturer of failed tire” response. 6 2.02%
Manufacturer of failed tire: Carlisle. 21 7.07%
Manufacturer of failed tire: Goodyear Marathon. 104 35.02%
Manufacturer of failed tire: Goodyear (other than Marathon). 0 0%
Manufacturer of failed tire: Greenball. 2 0.67%
Manufacturer of failed tire: Maxxis. 5 1.68%
Manufacturer of failed tire: Michelin. 3 1.01%
Manufacturer of failed tire: Towmax. 8 2.69%
Manufacturer of failed tire: Other. 14 4.71%
Manufacturing country of failed tire: Canada. Note: Please, select only one “manufacturing country” response. 11 3.70%
Manufacturing country: China. 54 18.18%
Manufacturing country: Europe. 0 0%
Manufacturing country: Mexico. 1 0.34%
Manufacturing country: Other Far Eastern Countries (e.g., Japan, Taiwan, Korea, Malaysia, etc.). 3 1.01%
Manufacturing country: USA. 14 4.71%
Manufacturing country: Other/unknown. 52 17.51%
Tire age at failure: Less than 1 year. Note: Please, select only one “tire age” response. 11 3.70%
Tire age: 1-2 years. 29 9.76%
Tire age: 2-3 years. 41 13.80%
Tire age: 3-4 years. 43 14.48%
Tire age: 4-5 years. 14 4.71%
Tire age: 5-6 years. 9 3.03%
Tire age: 6-7 years. 10 3.37%
Tire age: More than 7 years. 8 2.69%
Tire age: Unknown. 1 0.34%
Tire mileage at failure: Less than 1,000 miles. Note: Please, select only one “tire mileage” response. 2 0.67%
Tire mileage: 1,000-5,000 miles. 40 13.47%
Tire mileage: 5,000-10,000 miles. 59 19.87%
Tire mileage: 10,000-15,000 miles. 24 8.08%
Tire mileage: 15,000-20,000 miles. 2 0.67%
Tire mileage: More than 20,000 miles. 13 4.38%
Tire mileage: Unknown. 20 6.73%
Was the failed tire balanced by the tire installer: Yes. 107 36.03%
Was the failed tire balanced by the tire installer: No (or unknown). 31 10.44%
Did the tire that failed use a dynamic balancing device (Centramatic or similar): Yes. 27 9.09%
Did the tire that failed use a dynamic balancing device: No. 82 27.61%
Parking surface for failed tire during extended storage (longer than 30 days): Concrete. Note: Please, select only one “parking surface” response. 46 15.49%
Parking surface: Asphalt. 25 8.42%
Parking surface: Gravel or dirt. 59 19.87%
Parking surface: Wood. 8 2.69%
Parking surface: Synthetic material (rubber, plastic, etc.). 1 0.34%
Parking surface: Other. 9 3.03%
Cost of roadside assistance, towing, etc. due to tire failure: $0 Note: Please, include costs reimbursed by insurance. However, do not include tires, wheels, etc. Also, please select only one “cost of roadside assistance...” response. 81 27.27%
Cost of roadside assistance, towing, etc.: Up to $100. 20 6.73%
Cost of roadside assistance, towing, etc.: $100 - $500. 17 5.72%
Cost of roadside assistance, towing, etc.: $500 - $1,000. 1 0.34%
Cost of roadside assistance, towing, etc.: $1,000 - $5000. 2 0.67%
Cost of roadside assistance, towing, etc.: More than $5,000. 0 0%
Cost of replacement tire, wheel, shipping, ext warranty, mount/balance, etc. due to tire failure: $0 Note: Please include cost reimbursed by insurance. Also, please select only one “cost of replacement tire, wheel, etc.” response. 13 4.38%
Cost of replacement tire, wheel, shipping, etc.: Up to $250. 90 30.30%
Cost of replacement tire, wheel, shipping, etc.: $250 - $500. 16 5.39%
Cost of replacement tire, wheel, shipping, etc.: $500 - $1,000. 8 2.69%
Cost of replacement tire, wheel, shipping, etc.: $1,000 - $2,000. 5 1.68%
Cost of replacement tire, wheel, shipping, etc.: $2,000-$3,000. 1 0.34%
Cost of replacement tire, wheel, shipping, etc.: More than $3,000. 1 0.34%
Additional damage to your Airstream, if any: None. 84 28.28%
Additional damage to your Airstream: Minor cosmetic damage, not repaired. 22 7.41%
Additional damage to your Airstream: Functional damage to other tires, wheels, suspension parts, etc., repaired/replaced. 8 2.69%
Additional damage to your Airstream: Functional damage affecting safety, including brake lines/parts, electrical wiring, propane lines, etc., repaired/replaced. 6 2.02%
Additional damage to your Airstream: Major damage to exterior or interior of Airstream, including body panels, rock guards, hot water heater, refrigerator, etc. 20 6.73%
Additional damage: Damage to tow or other vehicles. 0 0%
Additional damage: Personal injury, property or other damage not usually associated with tire failure. 0 0%
Cost of additional damage to Airstream: $0 (no damage). Note: Please, select only one “cost of additional damage to Airstream” response. 62 20.88%
Cost of additional damage to Airstream: Up to $100 (estimate, if not repaired). 9 3.03%
Cost of additional damage to Airstream: $100 - $500 (estimate, if not repaired). 9 3.03%
Cost of additional damage to Airstream: $500 - $1,000 (estimate, if not repaired). 7 2.36%
Cost of additional damage to Airstream: $1,000 - $5000 (estimate, if not repaired). 15 5.05%
Cost of additional damage to Airstream: $5000 - $10,000 (estimate, if not repaired). 2 0.67%
Cost of additional damage to Airstream: More than $10,000 (estimate, if not repaired). 1 0.34%
Cost of personal injury, property, tow vehicle or other damage associated with tire failure: $0 (no other damage). Note: Please, select only one “cost of other damage” response. 71 23.91%
Cost of other damage: Up to $100. 2 0.67%
Cost of other damage: $100 - $500. 0 0%
Cost of other damage: $500 - $1,000. 0 0%
Cost of other damage: $1,000 - $5000. 0 0%
Cost of other damage: $5000 - $10,000. 0 0%
Cost of other damage: More than $10,000. 0 0%
Did your tow vehicle also experience TIRE damage in conjunction with the tire failure on your Airstream: Yes. 1 0.34%
Did your tow vehicle also experience TIRE damage in conjunction with the tire failure on your Airstream: No. 135 45.45%
My Airstream is towed on: Interstate and multilane highways. 184 61.95%
My Airstream is towed on: State and other improved two-lane highways, with shoulders. 165 55.56%
My Airstream is towed on: Mostly paved and well-maintained lesser-used "backroads". 91 30.64%
My Airstream is towed on: Poorly/minimally maintained backroads and offroad. 27 9.09%
Multiple Choice Poll. Voters: 297. You may not vote on this poll
Old 01-05-2015, 04:28 AM   #71
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by Phoenix View Post
Note: The information below is re-posted on the behalf of AirForums member "Gecko".
Our home base is Los Angeles. We take two large trips each year-the first to South Texas, through AZ and NM, and the second northbound, with first stop in NoCal and second in Hood River, OR. Here we can see extreme temps in late summer, but not usually more than high 90's, and we see 7% grades all the time. TV was a 2500 Suburban, replaced with a 3500 Sprinter. We use the same Equalizr 4 pt with both vehicles. We have a heavy tongue weight due to 4 large AGM batteries--two in the original position, built up 1/2 inch to accommodate, and the other two on the left side forward under couch near inverter and circuit breakers on our 28' International 2009.
Incident #1
TV Suburban, Goodyear marathon, front left, 65 psi recommended and maintained, new from dealer, not sure of balance method. 3.5 years of use (was going to replace in two months along with the whole set of originals and spare). Interstates, highways, back roads, and very little off road--dirt roads primarily, for distances under 1/2 mile. Stored on asphalt in winter. Approx mileage at time of failure--25K. Complete tread separation, no damage to Airstream (phew!), Autoclub so free roadside service. All tires replaced at nearby Les Schwab (Bend, OR) with their 10 ply Towmax as that was the best they had in stock. (Had requested Michelins, relatively ignorant, didn't know we'd need 16" wheels.")
2nd incident
Towmark, again left front. (Suspecting heavy battery weight now.) When pulling out of gas station, my wife noticed a bubble in the sidewall near tread in her side view. Fortunately, there was a tire place next door who changed it our for us before blowout, and a Les Schwab about 20 miles away. 80 psi max, ran at about 75 psi. 2 years old, about 14K miles. They warranteed, and also warranted another tire that they said was problematic (don't remember where it was). Total cost about $100. No damage, of course.
Currently thinking about (a) relocating batteries and (b) possibly changing up to 16" and Michelins for added safety, too.
Your thoughts would be appreciated, as well as any recommendation for a reputable source in Southern California for new wheels and tires. We do need to do something about our tongue weight. I am concerned that moving all four batteries aft (under the foot of our bed) will use up our little storage space and while taking 320 lbs off the front of the trailer, will move the same 320 for more trailer sway--effectively a 640 lb shift!
Our current tongue weight was measured by dealer last year at 1260 lbs, which is clearly over the 1095 15% max, so a 320lb shift aft should be OK for trailer sway while obviously taking load off the hitch, load leveling, and front trailer tires, particularly the left side with the extra weight there.
Suggestions?
First, weigh the trailer. I suspect that already has been done. I recommend that the load on the tires be no more than 85% of the load carrying capacity of the tire (accounting for side to side and front to rear load variation AND the inflation pressure actually in use.)
Second, speed isn't mentioned. If towing faster than 65 mph, then the load on the tires needs to be reduced even further beyond the 85% I recommended.
CapriRacer is offline   Reply With Quote
Old 01-06-2015, 07:22 AM   #72
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I have weighed both our 25FB and our 31' Classic on my individual wheel scales.
In the 25FB situation, the right rear weight was 200 pounds heavier that the others. I chatted with another chap in Texas and his 25FB "eats" right rear tires quicker than the others. We wondered why this was a common trait.
The Classic before our modifications had a similar weighing situation.
From hours of reading this forum before buying the first Airstream and especially the tire related threads, we converted the 25FB to the Michelin LTX (P) 235/75R15 XL tires as soon as we got her home and ran 44 psi in the tires. We had a derated 7,940 pounds of tire load capacity attached to the two 3,700 pound load rated each axles. Crossing the scales when loaded for camping, the trailer axles were carrying 5,860 pounds. We had plenty of reserve tire load capacity.
The "images" under my avatar show photos of the stock GYM ST225/75R15D tire beside the 15" Michelin tire and the Michelin LT225/75R16/E LTX M/S2 tire we installed on the Classic on the 16" SenDel T03-66655T aluminum wheels (each wheel rated 3,580 pounds at 80 psi). The Classic spare tire is mounted on a galvanized steel SenDel S62-66655TG wheel rated at 3,500 pounds at 80 psi.
The four 16" Michelins have a load rating of 10,720 pounds and are attached to two axles, each rated 5,000 pounds.
The trailers were/are stored under roof and the tires have a cover for sunlight protection. There is a piece of particle board under the tires to keep them off the asphalt. We have the Dill #1506 TPMS system installed to monitor things on the trailer tires.
BTW. When getting the TPMS system installed, make sure the installer notes which sender letter is in each wheel or otherwise there is a major problem getting the right receiver chip in the correct location. We had to break the tires down to get that information and then re-balance them.
Also, as a pre-drive check, use a tire valve tool to be sure the tire valve is fully seated in the valve stem. We have found that the technician did not fully seat one tire valve which created a slow leak.
Other than a road hazard screw in the corned of the tread, we have had no tire issues with our Michelin tires. We are based in the Phoenix area.
Old 01-08-2015, 02:40 PM   #73
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Airstream Tire Failure Poll
Switz, did you weigh at wheel position both with and without WD applied on your scales?
CapriRacer, so if I wish to run 65+ on a Texas summer day I ought to aim at 80% or less of rated capacity given full sidewall pressure?
Is there a relation also to the tires on the truck doing the towing?
Old 01-09-2015, 04:13 AM   #74
CapriRacer
CapriRacer's Avatar
I'm in the , US
I tend to think of this the other way - that the tire's load carrying capacity ought to be no less than 115% of the max load on an individual tire.
And yes, that applies to the tow vehicle as well. I think you will see (if you do the math), that the tow vehicle manufacturer has already sized the tires that way - so usually the tow vehicle isn't a problem. Trailers on the other hand ........
Old 01-09-2015, 06:06 AM   #75
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Thank you
Old 01-09-2015, 06:59 AM   #76
switz's Avatar
2014 31' Classic
Images: 8
The trailers were weighed detached with scales under each tire and the jack stand.
Old 01-09-2015, 09:05 AM   #77
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
TowMax failure on the way to the balloon festival in 2014. Two front tires were little older than the rears. The rears were wearing faster than the fronts. Axel weights were very close to the same. Now I rotate the tires every 5K miles. I'm saving for 16" rims and Michelins.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 02-22-2015, 03:57 PM   #78
JimGolden's Avatar
1977 31' Excella 500
A+
This looks to me to be a very thorough and well thought out poll.
Good job Phoenix!
Unfortunately, I didn't have much to offer you....as I've never had a blowout.
I run 235/75-15 D-rated tires. Six of them. At 60psi. Floats like a butterfly with this setting. I run Maxxis UE-168's which are rated as both ST and LT as a Commercial tire.
They are approaching the age where we usually replace them. I'm considering going to 16" or 17" wheels (17 is preferred by me if they will fit...but doubt it) and then BFG or Michelin.
But, I've had such success with these Maxxis tires over the past 7 years and 25,000 miles that it makes a good case to just buy another set of them.
Best of luck to you all, and see you on the road,
- Jim
JimGolden is offline   Reply With Quote
Old 02-23-2015, 04:55 AM   #79
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
JG, replace the spring equalizers with Dexter or Mor/Ryde. Should raise trailer just barely (and better ride + greater wheel travel).
But with your wheel loads even at max, the Yokohama RY215 is a premium choice with far more than enough load reserve in 7R-15. I had them on one Silver Streak.
9500lb TT needing 1600-lbs plus 15% reserve is 1800+. The RY is at 2000. Add a set of Centramatics.
Check wheel load rating. If they're 1800 Id not sweat it. If you've got room then the Bstone 250 is worth a look in 16.
Old 02-25-2015, 07:59 PM   #80
Ravenna , Ohio
Attachment 230079
Attachment 230080
Attachment 230081
It appears you do not run TPMS so had no idea you were running on a tire that exhibits signs of being run flat. i.e. tread degradation, melted body cord, abraded innerliner.
Retired tire engineer (40 years). Write a blog on RV tires.
Tireman9 is offline   Reply With Quote
Old 02-25-2015, 09:03 PM   #81
Ravenna , Ohio
An observation on this "poll" from a tire engineer experienced in failed tire forensics.
Most of the "reasons" for failure are in fact an approximation of the condition of a tire and should not be considered an indication of "why" the tire failed.
In problem analysis, if you do not understand the real reason for the "why" then in all probability you will not take the appropriate or necessary corrective action to prevent or at least decrease the chances of a recurrence.
Now this doesn't make the poll has no value, but it is important that everyone keeps in mind that using the results to make some decisions is like asking the guy parked next to you in the campground the best thing to do to avoid having a 2nd heart attack.
Old 02-25-2015, 09:20 PM   #82
TheCabin's Avatar
Liberty Corner , New Jersey
Tireman9,
Excellent comment.
TheCabin is online now   Reply With Quote
Old 03-02-2015, 03:51 PM   #83
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Yes. You will see the result, but maybe not the cause. And there may be more than one cause, for ex., hit a rock, but the tread was going to slip sometime in the future if you didn't hit the rock. Not sure that's the best analogy.
Gene
Gene
Old 03-03-2015, 10:23 AM   #84
Ravenna , Ohio
Originally Posted by macofpei View Post
My tire failed in the fall of 2011 as we were returning from the Rally at PTown, aprox Oct 14th. I had never had a blow out before and was quite supprised how much my Airstream shook. I took pictures and hope I can post them on here.
Looks like Run Low Flex failure as covered in the July 22, 2012 post on my RV tire Safety Blog.
st tire failure poll
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Where not to buy an airstream scorpiontimo Off Topic Forum 25 04-27-2011 05:09 AM
