View Poll Results: Note: This poll must be completed in one session.
Has a tire failed on your Airstream in the past 5 years – Yes. 150 51.02%
Has a tire failed on your Airstream in the past 5 years – No. 146 49.66%
Reason for tire failure: Valve stem leak/failure. 6 2.04%
Reason for tire failure: Bubble in sidewall. 18 6.12%
Reason for tire failure: Bubble in tread area. 11 3.74%
Reason for tire failure: Belt/tread slipped, but still relatively intact. 16 5.44%
Reason for tire failure: Tread separated, but still partially attached to tire body. 29 9.86%
Reason for tire failure: Tread completely separated, but tire body still inflated. 12 4.08%
Reason for tire failure: Blowout, sidewall. 17 5.78%
Reason for tire failure: Blowout, with tread separation. 59 20.07%
Reason for tire failure: Other reason(s), not stated above. 18 6.12%
Ambient/outdoor temperature when tire failure occurred or was noticed: Subfreezing to freezing temperatures. Note: Please, select only one “ambient/outdoor temperature”. 1 0.34%
Ambient/outdoor temperature: Freezing to 70-degrees Fahrenheit. 26 8.84%
Ambient/outdoor temperature: 70 to 90-degrees Fahrenheit. 82 27.89%
Ambient/outdoor temperature: 90 to 110-degrees Fahrenheit. 37 12.59%
Ambient/outdoor temperature: 110+ degrees Fahrenheit. 1 0.34%
The tire failed: Before driving. Note: Please, select only one “tire failure time”. 11 3.74%
The tire failed: While driving. 114 38.78%
The tire failed: After driving. 19 6.46%
Number of axles on your Airstream: 1. Note: Please, select only one “number of axles” response. 46 15.65%
Number of axles on your Airstream: 2. 162 55.10%
Number of axles on your Airstream: 3. 11 3.74%
Position of tire that failed: Axle #1 (front or single axle), left side. Note: Please, select all “failed tire positions” that apply. 48 16.33%
Position of tire that failed: Axle #1 (front or single axle), right side. 66 22.45%
Position of tire that failed: Axle #2, left side. 33 11.22%
Position of tire that failed: Axle #2, right side. 41 13.95%
Position of tire that failed: Axle #3, left side. 4 1.36%
Position of tire that failed: Axle #3, right side. 5 1.70%
Did a road hazard, hitch failure or vehicle accident cause or contribute to the tire failure: Yes. 10 3.40%
Did a road hazard, hitch failure or vehicle accident cause or contribute to the tire failure: No. 117 39.80%
Did the tire failure cause or contribute to a vehicle accident: Yes. 0 0%
Did the tire failure cause or contribute to a vehicle accident: No. 136 46.26%
Number of tires that failed during the original incident: 1. Note: Please, select only one “number of tires that failed during original incident” response. 123 41.84%
Number of tires that failed during the original incident: 2. 15 5.10%
Number of tires that failed during the original incident: 3. 6 2.04%
Number of tires that failed during the original incident: 4 or more. 3 1.02%
Number of additional tires that failed within 30 days or 1,000 miles of the original incident: 1. Note: Please, select only one “number of additional tires, within 30 days or 1,000 miles” response. 20 6.80%
Number of additional tires that failed within 30 days or 1,000 miles: 2. 4 1.36%
Number of additional tires that failed within 30 days or 1,000 miles: 3. 1 0.34%
Number of additional tires that failed within 30 days or 1,000 miles: 4 or more. 0 0%
Number of additional tires that failed within 12 months or 12,000 miles of the original incident: 1. Note: Please, select only one “number of additional tires, within 12 months or 12,000 miles” response. 11 3.74%
Number of additional tires that failed within 12 months or 12,000 miles: 2. 4 1.36%
Number of additional tires that failed within 12 months or 12,000 miles: 3. 4 1.36%
Number of additional tires that failed within 12 months or 12,000 miles: 4 or more. 2 0.68%
Type of tire that failed: ST. Note: Please, select only one “type of tire that failed” response. 117 39.80%
Type of tire that failed: LT. 4 1.36%
Type of tire that failed: Other/unknown. 8 2.72%
Tire size of failed tire: 215/75. Note: Please, select only one “tire size”. 13 4.42%
Tire size: 225/75. 115 39.12%
Tire size: 235/75. 16 5.44%
Tire size: Other. 4 1.36%
Wheel size of failed tire: 14 inch. Note: Please, select only one “wheel size”. 17 5.78%
Wheel size: 15 inch. 140 47.62%
Wheel size: 16 inch. 8 2.72%
Wheel size: Other. 0 0%
Load range of tire that failed: C. Note: Please, select only one “load range”. 16 5.44%
Load range: D. 93 31.63%
Load range: E. 33 11.22%
Load range: Other. 3 1.02%
Normal tire pressure for tire that failed: 36 psi or less. Note: Please, select only one “normal tire pressure” response. 0 0%
Normal tire pressure: 36-44 psi. 4 1.36%
Normal tire pressure: 50 psi. 26 8.84%
Normal tire pressure: 55-60 psi. 25 8.50%
Normal tire pressure: 65 psi. 92 31.29%
Normal tire pressure: 72 psi. 6 2.04%
Normal tire pressure: 80 psi. 15 5.10%
Normal tire pressure: 80+ psi. 0 0%
Tire was inflated to “normal tire pressure” above, at time of failure. 116 39.46%
Tire was inflated to a lower pressure. 6 2.04%
Tire was inflated to a higher pressure. 1 0.34%
Tire pressure was unknown at time of failure. 5 1.70%
Manufacturer of failed tire: BG Goodrich. Note: Please, select only one “manufacturer of failed tire” response. 6 2.04%
Manufacturer of failed tire: Carlisle. 21 7.14%
Manufacturer of failed tire: Goodyear Marathon. 104 35.37%
Manufacturer of failed tire: Goodyear (other than Marathon). 0 0%
Manufacturer of failed tire: Greenball. 2 0.68%
Manufacturer of failed tire: Maxxis. 5 1.70%
Manufacturer of failed tire: Michelin. 2 0.68%
Manufacturer of failed tire: Towmax. 8 2.72%
Manufacturer of failed tire: Other. 14 4.76%
Manufacturing country of failed tire: Canada. Note: Please, select only one “manufacturing country” response. 11 3.74%
Manufacturing country: China. 54 18.37%
Manufacturing country: Europe. 0 0%
Manufacturing country: Mexico. 1 0.34%
Manufacturing country: Other Far Eastern Countries (e.g., Japan, Taiwan, Korea, Malaysia, etc.). 3 1.02%
Manufacturing country: USA. 14 4.76%
Manufacturing country: Other/unknown. 52 17.69%
Tire age at failure: Less than 1 year. Note: Please, select only one “tire age” response. 10 3.40%
Tire age: 1-2 years. 29 9.86%
Tire age: 2-3 years. 41 13.95%
Tire age: 3-4 years. 43 14.63%
Tire age: 4-5 years. 14 4.76%
Tire age: 5-6 years. 9 3.06%
Tire age: 6-7 years. 10 3.40%
Tire age: More than 7 years. 7 2.38%
Tire age: Unknown. 1 0.34%
Tire mileage at failure: Less than 1,000 miles. Note: Please, select only one “tire mileage” response. 2 0.68%
Tire mileage: 1,000-5,000 miles. 39 13.27%
Tire mileage: 5,000-10,000 miles. 59 20.07%
Tire mileage: 10,000-15,000 miles. 24 8.16%
Tire mileage: 15,000-20,000 miles. 2 0.68%
Tire mileage: More than 20,000 miles. 13 4.42%
Tire mileage: Unknown. 20 6.80%
Was the failed tire balanced by the tire installer: Yes. 107 36.39%
Was the failed tire balanced by the tire installer: No (or unknown). 30 10.20%
Did the tire that failed use a dynamic balancing device (Centramatic or similar): Yes. 27 9.18%
Did the tire that failed use a dynamic balancing device: No. 82 27.89%
Parking surface for failed tire during extended storage (longer than 30 days): Concrete. Note: Please, select only one “parking surface” response. 45 15.31%
Parking surface: Asphalt. 25 8.50%
Parking surface: Gravel or dirt. 59 20.07%
Parking surface: Wood. 8 2.72%
Parking surface: Synthetic material (rubber, plastic, etc.). 1 0.34%
Parking surface: Other. 9 3.06%
Cost of roadside assistance, towing, etc. due to tire failure: $0 Note: Please, include costs reimbursed by insurance. However, do not include tires, wheels, etc. Also, please select only one “cost of roadside assistance...” response. 81 27.55%
Cost of roadside assistance, towing, etc.: Up to $100. 20 6.80%
Cost of roadside assistance, towing, etc.: $100 - $500. 17 5.78%
Cost of roadside assistance, towing, etc.: $500 - $1,000. 1 0.34%
Cost of roadside assistance, towing, etc.: $1,000 - $5000. 2 0.68%
Cost of roadside assistance, towing, etc.: More than $5,000. 0 0%
Cost of replacement tire, wheel, shipping, ext warranty, mount/balance, etc. due to tire failure: $0 Note: Please include cost reimbursed by insurance. Also, please select only one “cost of replacement tire, wheel, etc.” response. 13 4.42%
Cost of replacement tire, wheel, shipping, etc.: Up to $250. 89 30.27%
Cost of replacement tire, wheel, shipping, etc.: $250 - $500. 16 5.44%
Cost of replacement tire, wheel, shipping, etc.: $500 - $1,000. 8 2.72%
Cost of replacement tire, wheel, shipping, etc.: $1,000 - $2,000. 5 1.70%
Cost of replacement tire, wheel, shipping, etc.: $2,000-$3,000. 1 0.34%
Cost of replacement tire, wheel, shipping, etc.: More than $3,000. 1 0.34%
Additional damage to your Airstream, if any: None. 84 28.57%
Additional damage to your Airstream: Minor cosmetic damage, not repaired. 21 7.14%
Additional damage to your Airstream: Functional damage to other tires, wheels, suspension parts, etc., repaired/replaced. 8 2.72%
Additional damage to your Airstream: Functional damage affecting safety, including brake lines/parts, electrical wiring, propane lines, etc., repaired/replaced. 6 2.04%
Additional damage to your Airstream: Major damage to exterior or interior of Airstream, including body panels, rock guards, hot water heater, refrigerator, etc. 20 6.80%
Additional damage: Damage to tow or other vehicles. 0 0%
Additional damage: Personal injury, property or other damage not usually associated with tire failure. 0 0%
Cost of additional damage to Airstream: $0 (no damage). Note: Please, select only one “cost of additional damage to Airstream” response. 62 21.09%
Cost of additional damage to Airstream: Up to $100 (estimate, if not repaired). 9 3.06%
Cost of additional damage to Airstream: $100 - $500 (estimate, if not repaired). 9 3.06%
Cost of additional damage to Airstream: $500 - $1,000 (estimate, if not repaired). 7 2.38%
Cost of additional damage to Airstream: $1,000 - $5000 (estimate, if not repaired). 15 5.10%
Cost of additional damage to Airstream: $5000 - $10,000 (estimate, if not repaired). 2 0.68%
Cost of additional damage to Airstream: More than $10,000 (estimate, if not repaired). 1 0.34%
Cost of personal injury, property, tow vehicle or other damage associated with tire failure: $0 (no other damage). Note: Please, select only one “cost of other damage” response. 71 24.15%
Cost of other damage: Up to $100. 2 0.68%
Cost of other damage: $100 - $500. 0 0%
Cost of other damage: $500 - $1,000. 0 0%
Cost of other damage: $1,000 - $5000. 0 0%
Cost of other damage: $5000 - $10,000. 0 0%
Cost of other damage: More than $10,000. 0 0%
Did your tow vehicle also experience TIRE damage in conjunction with the tire failure on your Airstream: Yes. 1 0.34%
Did your tow vehicle also experience TIRE damage in conjunction with the tire failure on your Airstream: No. 135 45.92%
My Airstream is towed on: Interstate and multilane highways. 183 62.24%
My Airstream is towed on: State and other improved two-lane highways, with shoulders. 164 55.78%
My Airstream is towed on: Mostly paved and well-maintained lesser-used "backroads". 90 30.61%
My Airstream is towed on: Poorly/minimally maintained backroads and offroad. 27 9.18%
Multiple Choice Poll. Voters: 294. You may not vote on this poll
Old 03-09-2015, 11:27 AM   #127
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
Sorry about the wording. Bad editing on my part. The trend has been to deregulate industry but if that was not enough, industry has representatives embedded in government agencies that are charged with oversight responsibilities. Just think about the make up of government agency boards. They are often weighed down with people who are from the industries that they are supposed to have oversight of.
Even if we have standards and regulations there is little that is done to enforce them unless there is a catastrophic event that media just will not let loose of. Since the tire industry sees oversight as a threat (not an opportunity to improve a product) any preventative measures (the compilation and analysis of data) and enforcement will never happen. This problem is compounded when tires are not produced in the US. If a defective product from China is discovered they shut down the company, claim bankruptcy and start their production of the same product under another name.
Up until now I did not know that NHTSA took information about tire failures. I don't remember any tire dealers telling me that if a tire fails that I should report it to NHTSA. I guess I will need to read the fine print next time I buy tires.
In additon, private non profits like Consumer Reports do not have the funding to conduct studies of niche products like tires used on Airstreams. What we are left with is our ability to identify the tires that fail the least. I was trained as an epidemiologist and understand the development and administration of surveys. Surveys take a lot of time and money to develop and administer. This survey can only offer inferential data but it is better than nothing and I applaud Phoenix's efforts and all of the supportive comments that have been made here.
Eagle & Bear is offline   Reply With Quote
Old 03-09-2015, 12:23 PM   #128
Ravenna , Ohio
Originally Posted by r carl View Post
I don't think NHTSA is interested in a trailer tire like they would be in a LT tire.
The issue is that NHTSA has to prioritize. Fatalities of course take presidence followed by big damage claims. But numbers also play an important part.
People simply saying "My tire blew-up when I was driving across Arizona." is not going to count as there is not enough information to allow NHTSA to accumulate complaints from others who had a failure of the same product but can't link the two different complaints because the people failed to provide actionable information.
Lots of complaints here about GY Marathons but the number in NHTSA database is single digit if I recall correctly. It certainly is not past 100.
Retired tire engineer (40 years). Write a blog on RV tires.
Tireman9 is offline   Reply With Quote
Old 03-09-2015, 01:54 PM   #129
CapriRacer
CapriRacer's Avatar
I'm in the , US
I am of the opinion that NHTSA is actually MORE stringent than in the past.
When I retired 2 years ago, EVERY tire manufacturer and importer, every quarter, had to report on what tires were returned to them. Yes, they can exclude certain non-street tires, low volume tires, old tires, and tires returned for certain conditions (like wearout). But they had to report EVERYTHING. Tires simply returned, tires that caused damage, tires involved in fatalities (and those are the ones NHTSA really focused on).
They also require production volumes, so they can do failure rates. This was somewhat controversial as this is vital information about how well the tires are performing and any tire manufacturer would sell their soul for that info on a competitor (assuming, of course, they hadn't already sold their soul earlier for something less valuable!) Not only would knowing what a competitor's failure rate was compared to your be something you could advertise (discreetly, of course), it would also point to which tires should be your benchmark. That would save Millions of bucks in R&D costs.
Needless to say, the tire manufacturers wanted secrecy in exchange for giving up that information. They got it.
As Roger said, if there is a shortcoming, its that not enough people do a good job of reporting problems to NHTSA. They can't know there is a problem without that - and they will not act on rumor.
CapriRacer is offline   Reply With Quote
Old 03-09-2015, 03:26 PM   #130
1976 29' Ambassador
Good to know about the NHTSA reporting. Like everyone else we have no storage so I have done what I could to get rid of the dead tire. Since I have TPMS and know what information NHTSA needs I can provide them with all of the information.
Old 03-16-2015, 10:28 AM   #131
Ravenna , Ohio
Eagle & Bear Grab a few pictures too. This means both overall and close-up. Full Sun is best and be sure to use highest resolution possible.
Tires are difficult to photograph properly. NHTSA may or may not ask for the pictures but if/when you file a complaint it doesn't hurt to say you have pictures available.
Old 05-24-2015, 01:22 PM   #132
mrfrank9's Avatar
completed survey.
TT still in shop - should be out this week. getting a spare put on , as 1998 excella did not have
a bracket or spare.
side note: all of the shop people i spoke with said that after about three years, you are taking
your chances on an ST tire anyway.
mrfrank9 is offline   Reply With Quote
Old 05-24-2015, 02:40 PM   #133
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by mrfrank9 View Post
completed survey.
a bracket or spare.
My belt separation on my first Marathon happened on the last trip of year three. My belt separations on my E rated Maxxis tires occurred on the first trip of year 4. Dependent on how heavy your trailer is, I think ST's become marginal after 3 years of use.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-03-2015, 01:53 PM   #134
Tom T
Tom_T's Avatar
Orange , California
Note that I had no tire failure(s) in the past 5 years on our restored 1960 Avion T20 vintage kin since we bought it in July 2012 on our MAXXIS 8008 ST225/75R15-E 8PR tires, nor had the PO since they restored it in 2007 in same size GYMs from CW (so an 8 year history on this TT).
However, I did fill in those questions on tire size, load, mfgr, # axles, etc. which would give info on the tires & TT. Hopefully that doesn't skew or give erroneous results - as they were for info only - not failure counts.
If it does cause errors, then the Moderator(s) can feel free to cancel those entries causing problems.
BTW - this type of poll would be far more helpful in identifying the GOOD tires & mfgrs. - if it actually were a 2 sided survey - showing both the NON-failure tires & counts.
Also, a few blank line spaces between the questions - or between the sets of answers of same Q's - would be extremely helpful in getting through this survey!
Some things to think about in the future!
Cheers!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner)
Tom_T is offline   Reply With Quote
Old 10-02-2016, 05:07 AM   #135
Long Island , New York
The Non-ST Tire Failure Poll thread caught my attention this morning due to recent activity and further instructions from Phoenix:
http://www.airforums.com/forums/f438...ll-157690.html
This older thread has no similar recent instructions, but I am guessing that it should be completed by ST tire folks who have not had any tire failures, like us. Thus I have checked the 2nd line for No failures, and have not checked any other boxes. [Edit -- 48.53% report No failures in the poll results]
Right, Phoenix?
There are certain lines which are worded in such a way that it would be logical to answer [tire pressure, roads normally driven etc.] but it is not clear that folks with NO failures should complete them. I am guessing (like others have on many tire threads) that many GYM ST tire owners have not had failures, and that it would be helpful to have a gauge of this subset of the AS population. But this more general poll does not appear to be the right place to do that.
Thanks for doing your best to get some data on all tire failures, Phoenix, even if the results are somewhat anecdotal.
Peter
PS -- Edit -- The posts on the first page do not seem to answer the questions raised above, although in Post #6 Phoenix does recognize the need for more polls to fine-tune things. I have not seen any other new polls, but will look for them next.
Old 10-02-2016, 11:36 AM   #136
1967 26' Overlander
Spartanburg , South Carolina
Originally Posted by TinLoaf View Post
I'm still running my original 2005 Marathons that were made in Canada. I'm very careful about keeping them at 65 psi and haven't had a single tire issue in over 50,000 miles.
I clipped a curb and my front curbside vertical alignment is off so that tire (only that tire) is wearing hard on the outside edge. I have an Alumapalooza service appointment next month to fix the alignment and replace the tires.
The Canadian Marathons have been so good to me that I'm really hesitant to change them, but the time has come. Only time will tell how well the Chinese Marathons hold up, but I'm hopeful.
Hello Tin Loaf....I had similar experience with Canadian GYM's. Ran a set for 13 years and about 40,000 miles. Had a near crash in a rough construction zone near St. Louis in the 13th year that apparently affected the front right tire that did not fail, but began to wear a bit on the outside edge. There was little wear on the other three, even though at home I have to cut sharply into my driveway while backing. I replaced the set because of the age (and one tire wearing) with Chinese GYM's. So far I remain happy with the Chinese GYM's after 3 years and about 4,000 miles. When parked at home They are on pavement outside. If parked for more than a month I cover them and spray them once a month with Armor All Tire Foam when not covered.
Jacob D is offline   Reply With Quote
Old 10-02-2016, 04:17 PM   #137
2005 19' Safari
GLENDALE , AZ
Below is the link to the sister-poll that was created in May 2011, "for travel trailers with no tire failures". Like this thread, the data on "good tires" are mostly limited to ST tires; because 16" wheels and LT tires had not gained much traction by 2011.
Airstream Tire Poll for Travel Trailers with No Tire Failures
Originally, I thought that we could pick up tips from those who had somehow avoided the tire problems most of us had experienced. However, as time passed, most members bypassed the "no tire failures" poll. I can only guess at why it languished; perhaps, because the questions did not address a topic that people were interested in at the time, and more likely that it's just boring with few (or no) earth-shattering insights. It simply states, "My tires are fine", which is not nearly as compelling as "My GYMs exploded and damaged my Airstream!"
In any case, I think the poll is still open for those who wish to add their experiences with "good" ST tires.
Old 10-03-2016, 08:23 AM   #138
Ravenna , Ohio
Setting aside the question of the accuracy of the tire condition reporting one very critical item is missing and that is the full DOT serial number for every tire along with the date of failure or removal from service.
Date of removal would provide insight to tire age at removal.
The DOT also includes information on exactly which tire plant made the tire. Many times a given size or line of tires may be made at more than one plant If you get many "failures" from one plant and very few from another plant that provides critical information for investigators.
Lacking the above facts makes this poll just a random collection of comments and of no real value.
If you do not have training is product failure analysis or statistics maybe you can understand the idea of also reporting the state of manufacturer of the RV. Bet we would find a very strong correlation of tire failures on RVs made in the state of OHIO.
Old 10-10-2016, 06:25 AM   #139
2005 19' Safari
GLENDALE , AZ
Response to "This poll is just a random collection of comments and of no real value"
Tireman9,
While originally ignoring your post, I have decided that your critical comments deserve responses. See my comments below, in BLUE TEXT:
  • "Setting aside the question of the accuracy of the tire condition reporting one very critical item is missing and that is the full DOT serial number for every tire along with the date of failure or removal from service. Date of removal would provide insight to tire age at removal. The DOT also includes information on exactly which tire plant made the tire. Many times a given size or line of tires may be made at more than one plant If you get many 'failures' from one plant and very few from another plant that provides critical information for investigators."
    Obviously, the data you seek would be used for tire failure analysis to determine root cause for feedback to a tire manufacturer. A tire company could then use this information to correct the design and/or manufacturing process at specific plants to reduce tire failure rates and improve reliability. I’m sure you would also like photos of the failed tires, and even the tire carcasses, if available.
    Unfortunately, this was not the goal of the Airstream Tire Failure Poll, which was written over five years ago. The purpose of this poll was to determine the scope of tire failures on Airstreams, which were constantly being reported on AirForums.com. Also, while DOT serial numbers, photos and failed tire samples are useful to you, these items are not commonly saved by Airstream owners after suffering catastrophic tire failures on the road. Plus, there was never any intent to feed collected information back to tire manufacturers, as it was highly unlikely that any corrective action would be taken, based on the feedback from a small poll of a couple of hundred Airstream owners.
  • "Lacking the above facts makes this poll just a random collection of comments and of no real value."
    Your criticism belittles the real-world experiences of the poll participants. Each entry is an Airstream owner’s perception of a tire failure; and while it may not provide the information you seek, perception is reality for that owner. The information collected from participants met the goal of this poll, which was to determine the tires that failed and the circumstances surrounding those failures. And, many AirForums members have used this poll data when making subsequent tire buying decisions.
    Therefore, this poll is not “just a random collection of comments and of no real value”; because many members have switched to non-ST tires, and they have had fewer problems with them.
  • "If you do not have training is product failure analysis or statistics maybe you can understand the idea of also reporting the state of manufacturer of the RV. Bet we would find a very strong correlation of tire failures on RVs made in the state of OHIO."
    While this last comment was probably meant to be facetious, please know that I am a retired quality assurance manager who worked in the electronics manufacturing industry for over 40 years, and I do have extensive experience in product failure analysis and statistics.
    And, to be clear, I am being facetious in stating that:
    For the purpose of this poll, “the state of manufacture of the RV” is unnecessary; as unlike you, who do not own an Airstream, AirForums members know that most of our Airstreams were manufactured in Jackson Center, Ohio.
Respectfully,
Phoenix
Old 10-10-2016, 08:31 AM   #140
r carl's Avatar
Lin , Ne
Maybe one or two guy's around here were on the ST design team that laid the egg that cracked.
st tire failure poll
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Where not to buy an airstream scorpiontimo Off Topic Forum 25 04-27-2011 05:09 AM
