Old 01-10-2014, 11:49 AM   #1
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Airstream recommended torque 16" SenDel wheels
Here is the straight information on torque value: 125 to 130 ft pounds
Name:	SenDel wheel torque.jpg
Old 01-11-2014, 06:49 AM   #2
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Thank you, sir, for the torque specification.
But max load spec for the tires is incorrect, and also the 5-lug reference for that wheel.
Just like in their manuals, Airstream literature continues to be fraught with inaccuracies and type-o's. Really attacks Airstream's legitimacy as a top of the line brand. Are you listening, Airstream?
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 01-12-2014, 06:35 AM   #3
switz's Avatar
2014 31' Classic
Images: 8
That image has the correct wheel specification for the SenDel T03-66655T wheel which was the point of my post. Looking at the model number:
the first "6" is a 16" wheel
the second "6" is the width rating
The next "6" is the number of lug bolts
The "55" references the bolt circle diameter
The wheel has zero offset and a center bore of 4.25"
The wheel is rated four a 3,580 pound load at 80psi
Here is the link to that specific design wheel model and it'a size variations on the SenDel website.
T03SM | Sendel Wheels
Notice the Airstream photos in the literature. This wheel is used by Airstream as an option on the two Eddie Bauer models.
Note that the same five digits are used when describing the steel wheels like the galvanized one I purchased to us as a spare.
S62G | Sendel Wheels
The point of the post was the torque value for the lug nuts when installing the wheels, not specifically the tire information. However, the Michelin LT225/75R16/E LTX M/S2 is rated 2,680 pounds @ 80 psi.
