View Poll Results: AIRSTREAM *NON-ST* TIRE POLL – Applicable only to Airstreams with NON-ST tires
TYPE OF TIRE INSTALLED – Please select only one response in this category:
15 |
14.71% |
Type of Tire Installed: ST (Special Trailer tire) – ATTENTION: DO NOT PROCEED – THIS POLL IS FOR *NON-ST* TIRES ONLY!
6 |
5.88% |
Type of Tire Installed: P (Passenger car tire)
9 |
8.82% |
Type of Tire Installed: XL (Extra Load passenger car tire)
11 |
10.78% |
Type of Tire Installed: LT (Light Truck tire)
64 |
62.75% |
Type of Tire Installed: Other or unknown
2 |
1.96% |
TIRE MANUFACTURER – Please select only one response in this category:
3 |
2.94% |
Tire Manufacturer: BF Goodrich – Commercial T/A
1 |
0.98% |
Tire Manufacturer: BF Goodrich – Other tire models
0 |
0% |
Tire Manufacturer: Bridgestone
1 |
0.98% |
Tire Manufacturer: Carlisle
1 |
0.98% |
Tire Manufacturer: Continental
1 |
0.98% |
Tire Manufacturer: Cooper
1 |
0.98% |
Tire Manufacturer: Dick Cepek
0 |
0% |
Tire Manufacturer: Dunlop
1 |
0.98% |
Tire Manufacturer: Firestone
3 |
2.94% |
Tire Manufacturer: Fuzion
0 |
0% |
Tire Manufacturer: General
1 |
0.98% |
Tire Manufacturer: Goodyear
3 |
2.94% |
Tire Manufacturer: Hankook
0 |
0% |
Tire Manufacturer: Kumho
0 |
0% |
Tire Manufacturer: Maxxis
1 |
0.98% |
Tire Manufacturer: Michelin – LTX M/S (older model; NOT the Defender) only
7 |
6.86% |
Tire Manufacturer: Michelin – LTX M/S2 only
57 |
55.88% |
Tire Manufacturer: Michelin – LTX A/T2 only
0 |
0% |
Tire Manufacturer: Michelin – Defender LTX M/S only
7 |
6.86% |
Tire Manufacturer: Michelin – XPS Rib only
6 |
5.88% |
Tire Manufacturer: Michelin – Other tire models
2 |
1.96% |
Tire Manufacturer: Nexen
0 |
0% |
Tire Manufacturer: Nokian
3 |
2.94% |
Tire Manufacturer: Pirelli
0 |
0% |
Tire Manufacturer: Sumitomo
0 |
0% |
Tire Manufacturer: Toyo
1 |
0.98% |
Tire Manufacturer: Uniroyal
0 |
0% |
Tire Manufacturer: Yokohama
2 |
1.96% |
Tire Manufacturer: Other
1 |
0.98% |
MANUFACTURING COUNTRY – Please select only one response in this category:
1 |
0.98% |
Manufacturing Country: Canada
12 |
11.76% |
Manufacturing Country: China
3 |
2.94% |
Manufacturing Country: Europe
9 |
8.82% |
Manufacturing Country: Mexico
0 |
0% |
Manufacturing Country: Other Far Eastern Countries (e.g., Japan, Taiwan, Korea, Malaysia, etc.)
1 |
0.98% |
Manufacturing Country: USA
20 |
19.61% |
Manufacturing Country: Other or unknown
26 |
25.49% |
TIRE SIZE – Please select only one response in this category:
1 |
0.98% |
Tire Size: 205
3 |
2.94% |
Tire Size: 215
4 |
3.92% |
Tire Size: 225
59 |
57.84% |
Tire Size: 235
29 |
28.43% |
Tire Size: Other
1 |
0.98% |
TIRE ASPECT RATIO – Please select only one response in this category:
1 |
0.98% |
Tire Aspect Ratio: 70
11 |
10.78% |
Tire Aspect Ratio: 75
78 |
76.47% |
Tire Aspect Ratio: 80
1 |
0.98% |
Tire Aspect Ratio: Other
2 |
1.96% |
WHEEL SIZE – Please select only one response in this category:
1 |
0.98% |
Wheel Size: 14 inch
0 |
0% |
Wheel Size: 15 inch
41 |
40.20% |
Wheel Size: 16 inch
58 |
56.86% |
Wheel Size: Other
0 |
0% |
TIRE LOAD RANGE – Please select only one response in this category:
1 |
0.98% |
Tire Load Range: Standard
5 |
4.90% |
Tire Load Range: C or XL
19 |
18.63% |
Tire Load Range: D
9 |
8.82% |
Tire Load Range: E
51 |
50.00% |
Tire Load Range: F
1 |
0.98% |
Tire Load Range: G
0 |
0% |
NORMAL TIRE PRESSURE (cold) – Please select only one response in this category:
2 |
1.96% |
Normal Tire Pressure: 36-44 psi
8 |
7.84% |
Normal Tire Pressure: 50 psi
25 |
24.51% |
Normal Tire Pressure: 55-60 psi
10 |
9.80% |
Normal Tire Pressure: 65 psi
14 |
13.73% |
Normal Tire Pressure: 72 psi
16 |
15.69% |
Normal Tire Pressure: 80 psi
25 |
24.51% |
Normal Tire Pressure: 80+ psi
1 |
0.98% |
TIRE AGE (in years) – Please select only one response in this category:
4 |
3.92% |
Tire Age (in years): 0-1 year
27 |
26.47% |
Tire Age (in years): 1-2 years
15 |
14.71% |
Tire Age (in years): 2-3 years
20 |
19.61% |
Tire Age (in years): 3-4 years
12 |
11.76% |
Tire Age (in years): 4-5 years
11 |
10.78% |
Tire Age (in years): 5-6 years
6 |
5.88% |
Tire Age (in years): 6-7 years
2 |
1.96% |
Tire Age (in years): 7+ years
4 |
3.92% |
Tire Age (in years): Unknown
1 |
0.98% |
TIRE AGE (in miles) – Please select only one response in this category:
4 |
3.92% |
Tire Age (in miles): 0-1,000 miles
12 |
11.76% |
Tire Age (in miles): 1,000-5,000 miles
14 |
13.73% |
Tire Age (in miles): 5,000-10,000 miles
22 |
21.57% |
Tire Age (in miles): 10,000-15,000 miles
14 |
13.73% |
Tire Age (in miles): 15,000-25,000 miles
17 |
16.67% |
Tire Age (in miles): 25,000-50,000 miles
11 |
10.78% |
Tire Age (in miles): 50,000-75,000 miles
2 |
1.96% |
Tire Age (in miles): 75,000-100,000 miles
0 |
0% |
Tire Age (in miles): 100,000+ miles
0 |
0% |
Tire Age (in miles): Unknown
2 |
1.96% |
ARE TIRES BALANCED – Please select only one response in this category:
7 |
6.86% |
Are Tires Balanced: Static (bubble) balance
9 |
8.82% |
Are Tires Balanced: Spin balance (tire spun on balancing machine or Airstream)
79 |
77.45% |
Are Tires Balanced: No or unknown
7 |
6.86% |
ARE DYNAMIC BALANCING DEVICES USED – Please select all responses that apply in this category:
4 |
3.92% |
Dynamic Balancing Devices Used: Centramatics (or similar)
32 |
31.37% |
Dynamic Balancing Devices Used: DynaBeads (or similar)
1 |
0.98% |
Dynamic Balancing Devices Used: Other less common devices or methods
1 |
0.98% |
Dynamic Balancing Devices Used: None or unknown
28 |
27.45% |
NUMBER OF AXLES ON YOUR AIRSTREAM – Please select only one response in this category:
3 |
2.94% |
Number of Axles on Your Airstream: 1
6 |
5.88% |
Number of Axles on Your Airstream: 2
81 |
79.41% |
Number of Axles on Your Airstream: 3
5 |
4.90% |
WEIGHT OF AIRSTREAM (fully loaded, including tongue weight) – Please select only one response in this category:
4 |
3.92% |
Weight of Airstream: 1,000-2,000 pounds
0 |
0% |
Weight of Airstream: 2,000-3,000 pounds
1 |
0.98% |
Weight of Airstream: 3,000-4,000 pounds
3 |
2.94% |
Weight of Airstream: 4,000-5,000 pounds
8 |
7.84% |
Weight of Airstream: 5,000-6,000 pounds
17 |
16.67% |
Weight of Airstream: 6,000-7,000 pounds
19 |
18.63% |
Weight of Airstream: 7,000-8,000 pounds
16 |
15.69% |
Weight of Airstream: 8,000-9,000 pounds
23 |
22.55% |
Weight of Airstream: 9,000-10,000 pounds
9 |
8.82% |
Weight of Airstream: 10,000-11,000 pounds
3 |
2.94% |
Weight of Airstream: 11,000-12,000 pounds
0 |
0% |
Weight of Airstream: 12,000+ pounds
0 |
0% |
PARKING SURFACE – Please select only one parking surface for tires during extended storage (longer than 30 days):
3 |
2.94% |
Parking Surface: Dirt, rock, gravel, sand (or similar)
28 |
27.45% |
Parking Surface: Asphalt
12 |
11.76% |
Parking Surface: Concrete
36 |
35.29% |
Parking Surface: Wood, cardboard, paper, etc.
7 |
6.86% |
Parking Surface: Synthetic material (rubber, plastic, floor tiles, carpeting, etc.)
4 |
3.92% |
Parking Surface: Off floor (Airstream on jacks)
5 |
4.90% |
Parking Surface: Tires removed and stored off Airstream
0 |
0% |
Parking Surface: Other
7 |
6.86% |
AIRSTREAM TOWING CONDITIONS – Please select all responses that apply in this category:
4 |
3.92% |
My Airstream is towed on: Interstate and multilane highways
85 |
83.33% |
My Airstream is towed on: State and other improved two-lane highways, with shoulders
79 |
77.45% |
My Airstream is towed on: Mostly paved and well-maintained lesser-used "backroads"
56 |
54.90% |
My Airstream is towed on: Poorly/minimally maintained "backroads" and off-road
19 |
18.63% |
0 |
0% |
HAS A *NON-ST* TIRE FAILED ON YOUR AIRSTREAM – If YES is selected, please continue with this poll. However, if your answer is NO; please stop, and do not proceed further. The questions that follow pertain only to NON-ST tire failures.
4 |
3.92% |
Has a NON-ST tire failed on your Airstream in the past 10 years? – Yes (Please continue.)
9 |
8.82% |
Has a NON-ST tire failed on your Airstream in the past 10 years? – No (Please stop here.)
59 |
57.84% |
0 |
0% |
TIRE PRESSURE AT FAILURE – Please select only one response in this category:
0 |
0% |
Tire Pressure at Failure: Tire was inflated to “normal tire pressure” (previously entered)
9 |
8.82% |
Tire Pressure at Failure: Tire was inflated to a lower pressure
0 |
0% |
Tire Pressure at Failure: Tire was inflated to a higher pressure
0 |
0% |
Tire Pressure at Failure: Tire pressure was unknown at time of failure
0 |
0% |
AMBIENT/OUTDOOR TEMPERATURE when tire failure occurred or was noticed – Please select only one response in this category:
1 |
0.98% |
Ambient/Outdoor Temperature at Failure: Subfreezing to freezing temperatures
0 |
0% |
Ambient/Outdoor Temperature at Failure: Freezing to 70-degrees Fahrenheit
2 |
1.96% |
Ambient/Outdoor Temperature at Failure: 70 to 90-degrees Fahrenheit
7 |
6.86% |
Ambient/Outdoor Temperature at Failure: 90 to 110-degrees Fahrenheit
0 |
0% |
Ambient/Outdoor Temperature at Failure: 110+ degrees Fahrenheit
0 |
0% |
TIRE FAILURE DESCRIPTION – Please select all responses that apply in this category:
0 |
0% |
Tire Failure Description: Valve stem leak/failure
1 |
0.98% |
Tire Failure Description: Bubble in sidewall
0 |
0% |
Tire Failure Description: Bubble in tread area
0 |
0% |
Tire Failure Description: Belt/tread slipped, but still relatively intact
1 |
0.98% |
Tire Failure Description: Tread separated, but still partially attached to tire body
0 |
0% |
Tire Failure Description: Tread completely separated, but tire body still inflated
0 |
0% |
Tire Failure Description: Blowout, sidewall
0 |
0% |
Tire Failure Description: Blowout, with tread separation
3 |
2.94% |
Tire Failure Description: Other, not described above
4 |
3.92% |
TIRE FAILURE TIME – Please select only one response in this category:
2 |
1.96% |
Tire Failure Time: Before driving
2 |
1.96% |
Tire Failure Time: While driving
5 |
4.90% |
Tire Failure Time: After driving
1 |
0.98% |
POSITION OF TIRE THAT FAILED – Please select all responses that apply in this category:
1 |
0.98% |
Position of Tire that Failed: Axle #1 (front or single axle), left side
6 |
5.88% |
Position of Tire that Failed: Axle #1 (front or single axle), right side
1 |
0.98% |
Position of Tire that Failed: Axle #2, left side
2 |
1.96% |
Position of Tire that Failed: Axle #2, right side
2 |
1.96% |
Position of Tire that Failed: Axle #3, left side
1 |
0.98% |
Position of Tire that Failed: Axle #3, right side
1 |
0.98% |
CAUSES & CONTRIBUTING FACTORS:
0 |
0% |
Did a road hazard, hitch failure or vehicle accident cause or contribute to the tire failure: Yes
3 |
2.94% |
Did a road hazard, hitch failure or vehicle accident cause or contribute to the tire failure: No
4 |
3.92% |
Did the tire failure cause or contribute to a vehicle accident: Yes
0 |
0% |
Did the tire failure cause or contribute to a vehicle accident: No
7 |
6.86% |
NUMBER OF TIRES THAT FAILED IN ORIGINAL INCIDENT – Please select only one response in this category:
1 |
0.98% |
Number of Tires that Failed in Original Incident: 1
8 |
7.84% |
Number of Tires that Failed in Original Incident: 2
0 |
0% |
Number of Tires that Failed in Original Incident: 3
0 |
0% |
Number of Tires that Failed in Original Incident: 4
0 |
0% |
Number of Tires that Failed in Original Incident: 5
0 |
0% |
Number of Tires that Failed in Original Incident: 6
0 |
0% |
NUMBER OF ADDITIONAL TIRES THAT FAILED WITHIN 30 DAYS OR 1,000 MILES OF ORIGINAL INCIDENT – Please select only one response in this category:
1 |
0.98% |
Number of Additional Tires that Failed within 30 Days or 1,000 Miles: 1
0 |
0% |
Number of Additional Tires that Failed within 30 Days or 1,000 Miles: 2
0 |
0% |
Number of Additional Tires that Failed within 30 Days or 1,000 Miles: 3
0 |
0% |
Number of Additional Tires that Failed within 30 Days or 1,000 Miles: 4
0 |
0% |
Number of Additional Tires that Failed within 30 Days or 1,000 Miles: 5
1 |
0.98% |
Number of Additional Tires that Failed within 30 Days or 1,000 Miles: 6
0 |
0% |
NUMBER OF ADDITIONAL TIRES THAT FAILED WITHIN 12 MONTHS OR 12,000 MILES OF ORIGINAL INCIDENT – Please select only one response in this category:
1 |
0.98% |
Number of Additional Tires that Failed within 12 Months or 12,000 Miles: 1
1 |
0.98% |
Number of Additional Tires that Failed within 12 Months or 12,000 Miles: 2
0 |
0% |
Number of Additional Tires that Failed within 12 Months or 12,000 Miles: 3
0 |
0% |
Number of Additional Tires that Failed within 12 Months or 12,000 Miles: 4
0 |
0% |
Number of Additional Tires that Failed within 12 Months or 12,000 Miles: 5
0 |
0% |
Number of Additional Tires that Failed within 12 Months or 12,000 Miles: 6
0 |
0% |
COST OF ROADSIDE ASSISTANCE, TOWING, ETC. (including expenses reimbursed by insurance; however, do not include cost of new tires, wheels, etc.) – Please select only one response in this category:
1 |
0.98% |
Cost of Roadside Assistance, Towing, etc.: $0
4 |
3.92% |
Cost of Roadside Assistance, Towing, etc.: $1-100
0 |
0% |
Cost of Roadside Assistance, Towing, etc.: $100-250
0 |
0% |
Cost of Roadside Assistance, Towing, etc.: $250-500
0 |
0% |
Cost of Roadside Assistance, Towing, etc.: $500-1,000
0 |
0% |
Cost of Roadside Assistance, Towing, etc.: $1,000-2,500
0 |
0% |
Cost of Roadside Assistance, Towing, etc.: $2,500-5,000
0 |
0% |
Cost of Roadside Assistance, Towing, etc.: $5,000-10,000
0 |
0% |
Cost of Roadside Assistance, Towing, etc.: $10,000+
0 |
0% |
COST OF TIRE REPAIR OR REPLACEMENT (including new tire and/or wheel, shipping, extended warranty, mounting & balancing and similar charges, even if reimbursed by insurance) – Please select only one response in this category:
1 |
0.98% |
Cost of Tire Repair or Replacement: $0
0 |
0% |
Cost of Tire Repair or Replacement: $1-100
3 |
2.94% |
Cost of Tire Repair or Replacement: $100-250
3 |
2.94% |
Cost of Tire Repair or Replacement: $250-500
2 |
1.96% |
Cost of Tire Repair or Replacement: $500-1,000
0 |
0% |
Cost of Tire Repair or Replacement: $1,000-1,500
0 |
0% |
Cost of Tire Repair or Replacement: $1,500-2,000
0 |
0% |
Cost of Tire Repair or Replacement: $2,000-2,500
0 |
0% |
Cost of Tire Repair or Replacement: $2,500+
0 |
0% |
ADDITIONAL DAMAGE TO AIRSTREAM – Please select all responses that apply in this category:
1 |
0.98% |
Additional Damage to Airstream: None
6 |
5.88% |
Additional Damage to Airstream: Minor cosmetic damage (even if not repaired)
2 |
1.96% |
Additional Damage to Airstream: Functional damage to other tires, wheels, suspension parts, etc.
0 |
0% |
Additional Damage to Airstream: Functional damage affecting safety, including brake lines/parts, electrical wiring, propane lines, etc.
0 |
0% |
Additional Damage to Airstream: Major damage to exterior or interior of Airstream, including body panels, windows, rock guards, water heater, refrigerator, etc.
0 |
0% |
Additional Damage: Tow vehicle or other vehicles
0 |
0% |
Additional Damage: Personal injury, property or other damage associated with tire failure
0 |
0% |
COST OF ADDITIONAL DAMAGE TO AIRSTREAM (estimate, if not repaired) – Please select only one response in this category:
1 |
0.98% |
Cost of Additional Damage to Airstream: $0
4 |
3.92% |
Cost of Additional Damage to Airstream: $1-100
0 |
0% |
Cost of Additional Damage to Airstream: $100-500
0 |
0% |
Cost of Additional Damage to Airstream: $500-1,000
1 |
0.98% |
Cost of Additional Damage to Airstream: $1,000-2,500
0 |
0% |
Cost of Additional Damage to Airstream: $2,500-5,000
1 |
0.98% |
Cost of Additional Damage to Airstream: $5,000-7,500
0 |
0% |
Cost of Additional Damage to Airstream: $7,500-10,000
0 |
0% |
Cost of Additional Damage to Airstream: $10,000-15,000
0 |
0% |
Cost of Additional Damage to Airstream: $15,000-25,000
0 |
0% |
Cost of Additional Damage to Airstream: $25,000+
0 |
0% |
Cost of Additional Damage to Airstream: Total loss (scrap/salvage)
0 |
0% |
COST OF OTHER DAMAGE (including personal injury, property, tow vehicle or other damage associated with tire failure) – Please select only one response in this category:
1 |
0.98% |
Cost of Other Damage: $0
6 |
5.88% |
Cost of Other Damage: $1-100
0 |
0% |
Cost of Other Damage: $100-500
0 |
0% |
Cost of Other Damage: $500-1,000
0 |
0% |
Cost of Other Damage: $1,000-2,500
0 |
0% |
Cost of Other Damage: $2,500-5,000
0 |
0% |
Cost of Other Damage: $5,000-10,000
0 |
0% |
Cost of Other Damage: $10,000-25,000+
0 |
0% |
Cost of Other Damage: $25,000-50,000
0 |
0% |
Cost of Other Damage: $50,000+
0 |
0% |
Cost of Other Damage: Total loss (tow vehicle, other vehicles and/or property)
0 |
0% |
TOW VEHICLE TIRE DAMAGE – Please select only one response in this category:
1 |
0.98% |
Tow Vehicle Tire Damage – Were tires also damaged on your tow vehicle: Yes
0 |
0% |
Tow Vehicle Tire Damage – Were tires also damaged on your tow vehicle: No
5 |
4.90% |
